MUM Europe 2020
wenas
Bonding and failover doesn't work normally
Sun Oct 17, 2010 11:19 am
Hello guys,
I have problem about bonding and I hope you can help me on this.
I try to build a bonding link in my lab.
Router 1
eth1 : 192.168.1.1/24
eth2 : 192.168.2.1/24
eth3 : 192.168.10.5/24
Router 2
eth1 : 192.168.1.2/24
eth2 : 192.168.2.2/24
eth3 : 192.168.11.5/24
eth1 (router 1) connected to eth1(router 2) through cross cable A.
eth2 (router 1) connected to eth2(router 2) through cross cable B.
eth3 on router 1 connected to PC 1 (192.168.10.1) and eth3 on router 2 connected to PC 2 (192.168.11.1)
configuration :
router 1 :
[admin@router1] /interface eoip add remote-address=192.168.1.2 tunnel-id=1 name=eoip-tunnel1
[admin@router1] /interface eoip add remote-address=192.168.2.2 tunnel-id=2 name=eoip-tunnel2
[admin@router1] /interface bonding add slaves=eoip-tunnel1,eoip-tunnel2 name=bonding1
[admin@router1] /ip address add address=172.16.1.1/24 interface=bonding1
[admin@router1] /ip route add dst=192.168.11.0/24 gateway=172.16.1.2
router 2 :
[admin@router2] /interface eoip add remote-address=192.168.1.1 tunnel-id=1 name=eoip-tunnel1
[admin@router1] /interface eoip add remote-address=192.168.2.1 tunnel-id=2 name=eoip-tunnel2
[admin@router1] /ip address add address=172.16.1.2/24 interface=bonding1
[admin@router1] /ip route add dst=192.168.10.0/24 gateway=172.16.1.1
PC 1 can ping PC2 and PC 2 can ping PC 1
Transfer data from PC 1 to PC 2 works. Also PC 2 can transfer data to PC 1
The problem is :
If one of the connection failed (i.e. cross cable A is unplugged or cross cable B is unplugged), connection between two routers is down, ping between PC is time out.
My goal on this bonding connection is failover will work if one connection failed, but It does not work.
Where is my mistake on my configuration? Please your advise guys
Many thanks before
mrz
Re: Bonding and failover doesn't work normally
Mon Oct 18, 2010 11:15 am
You can bond directly connected ethernets without making EoIP tunnels.
To make failover work you need to set up link monitoring in bonding configuration.
wenas
Tue Oct 19, 2010 2:24 am
mrz,
I created eoip to provide connection between 2 routers that will use wireless link.
can u pls explain in more details, how to set this failover method, due to bonding implementation
many thanks for ur time :)
Chupaka
Tue Oct 19, 2010 2:53 am
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
wenas
Wed Oct 20, 2010 4:37 am
Chupaka,
thank you for advising,
I have two wireless link, one act as main link and other for redundant. I need to use these both link to work in bonding method, so data rates can be accumulated and whenever one link is down connection still up by the other one.
I use 2 routers (RB750) on the end, used for bonding and failover purposes. The router is connected to 2 RB wireless. Wireless is configured using bridge mode.
question : is your advising above meet with my goal? any suggestion is really appreciated.
Many thanks for your time
Chupaka
Wed Oct 20, 2010 6:18 am
well, just try to play with it =) what kind of traffic do you have? maybe you can use ECMP routing instead of bonding...
shielder
Wed Oct 20, 2010 7:45 am
wenas
Wed Oct 20, 2010 8:03 am
Chupaka & shielder,
bonding works now and also failover works well. Configuration refers to your advise.
But data can not delivered across bonding connection.
At the end of bonding connection, there are 2 PCs connected to this link, each side connected to one PC
Problem : PC can not ping PC on the other side.
pls advise
wenas
Wed Oct 20, 2010 10:43 am
Put both interface ether1 (connected to PC) and interface bonding into interface bridge1, makes the two PCs can communicate each other.
is it recommended?
Chupaka
Wed Oct 20, 2010 3:18 pm
what addresses PCs have? should it be bridging or routing?
wenas
Thu Oct 21, 2010 3:05 am
The connection is descripted as below :
PC1 -- Router (failover/bonding) ========== Router (failover/bonding) -- PC2
note :
-- : straight cable
== : 2 wireless link, wireless radio running in bridge (wireless radio doesn't appear in picture)
PC have the same subnet IP address with other PC on other side.
Example : PC1 = 192.168.1.1/24
PC2 = 192.168.1.2/24
IP interface bonding on router1 : 172.16.0.1 and router2 : 172.16.0.2
If eth1 (not bonded) and interface bonding are bridged on router1 (same on router2), PC1 can ping to PC2; PC2 can ping PC1
BUT if eth1 and interface bonding are not bridged, PC1 can not ping PC2; PC2 can not ping PC1
question : what is the best way to choose? bridging or routing?
is able to route in same subnet?
pls ur advise and many thanks in advance
Chupaka
Thu Oct 21, 2010 9:22 am
same segment = bridge
wenas
Thu Oct 21, 2010 9:53 am
Chupaka,
it works.
thank you very much :)
Users browsing this forum: dioeyandika and 106 guests
