semihgeek
Load Balancing 2 WAN on 1 LAN
Tue Oct 19, 2010 1:17 am
Hi i am beginner at Mikrotik
I am basically using mikrotik for hotspot and web proxy.
My device is 750G
I have 2 adsl lines per 8mbps
I have 40 wireless customers.
Now i am using just one adsl connection for my all customers and depending on complaints my connection of 8mbps is not enough for 40 users.[Max active users is 15]
I want to connect second connection to my 750g.But I don't know how to configure.
I don't know enough information about load balancing types.
What should i do?
I don't want to use balancing based on services cause most of the users using same service as port 80.
I would be better if balancing based on probabilty assignation like
10 users is connected to network
5 should be using wan1
5 should be using wan2
Waiting for your helps
Thank you.
mrz
Re: Load Balancing 2 WAN on 1 LAN
Tue Oct 19, 2010 10:02 am
There are several examples on load balancing in the wiki, for example one of the methods
http://wiki.mikrotik.com/wiki/Manual:PCC
JCesar
Tue Oct 19, 2010 10:25 am
Thank you.
im very noob to but i do with load balance nth, in this way you send the first conecction (odd) to wan1 and the second conecction(even) to wan 2. if 10 users are active 5 go to wan1 and the others to wan2. uno y uno acada lado espero te sirva!
i just follow the next tuto http://wiki.mikrotik.com/wiki/NTH_load_ ... pproach%29
PCC is per-connection-classifier
tevolo
Mon Dec 06, 2010 7:30 pm
If you still have question with this check out this post:
http://forum.mikrotik.com/viewtopic.php?f=2&t=43469
I have a similar setup as you and it works great for me.
Users browsing this forum: Bing [Bot], bpwl, contactgus, Maggiore81, sindy and 72 guests
