MUM Europe 2020
csallor
Intel Atom D525
Sat Oct 23, 2010 12:29 am
Intel Atom mainboard: Gigabyte d525tud - without wireless cards -
respect ! 8)
Chupaka
Re: Intel Atom D525
Sat Oct 23, 2010 6:10 am
nice
did you tested v4 on the same hardware?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
rmichael
Forum Veteran
Forum Veteran
Re: Intel Atom D525
Sat Oct 23, 2010 11:41 am
It might be even faster with hyperthreading off...
martini
Re: Intel Atom D525
Sun Oct 24, 2010 11:28 pm
and now try this test with UDP and packet size 500 )))
csallor
Re: Intel Atom D525
Mon Oct 25, 2010 12:17 am
Iliasla
Re: Intel Atom D525
Wed May 09, 2012 8:05 am
Compiled and works 2WAN x86-based router Jetway NF99 (Atom D525 / 2h82574L) equipped with a daughter card AD3INLAN-G (3x82541PI) pictures. Both insertions are used as a WAN, the daughter's nic's combined bridge and used as a LAN. Distribution and receipt of about 150 Mbps real torrent traffic, as well as web surfing, etc. Balancing 2WAN (PCC outgoing requests by the addresses, for incoming requests - by connections and addresses).
QoS control is not used.
Originally planned to purchase RB1100AH ​​(x2), but for reasons of silence and versatility, as well as stock performance selection is made on x86.
aries
Re: Intel Atom D525
Thu May 17, 2012 6:34 pm
Best in class is Supermicro Embedded X7SPA-H-D525, because it has good integradet Intel Lan (2x Intel 82574L Gigabit LAN).
This nic supports multiple tx/rx queues and very well offloads work from cpu.
It is very optimal solution, because it has only 25w power consumtion, and beats any routerboard.
Best regards.
onnoossendrijver
Re: Intel Atom D525
Thu May 17, 2012 7:32 pm
Intel DN2800MT with RouterOS 6.0beta2:
UDP 500 byte Send: 780mbit/s
UDP 500 byte Receive: 400mbit/s
This system uses 13 watt.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
ohara
Re: Intel Atom D525
Thu May 17, 2012 9:19 pm
Impressive!
One of you has KVM package and other not. I am wondering because D525 specs show that it does not have virtualization support.
Do you have a chance to test if configuration supports KVM? We are close to buying a Jetway AMD board with AMD-V for the purpose of KVM but none of it supports the 3xLAN extension board, whereas the Intel motherboards do. Many thanks.
onnoossendrijver
Re: Intel Atom D525
Fri May 18, 2012 12:40 pm
I don't think KVM is going to work on this board (N2800 or D525). Is Virtualbox or VMware not an option? I don't know for sure if RouterOS works on these, but I think it should work.
syadnom
Re: Intel Atom D525
Sat Jun 02, 2012 12:15 am
It definitely wont work, no VT support in those CPUs
onnoossendrijver
Re: Intel Atom D525
Sat Jun 02, 2012 2:53 am
Vmware and Virtualbox don't need VT.
syadnom
Re: Intel Atom D525
Sat Jun 02, 2012 3:08 am
VMware and virtual box aren't an option. VMware has required vt for years and virtualbox is nearly impossible to use without vt
Users browsing this forum: No registered users and 86 guests
