point
3c905C-TX/TX-M not work in 2.9.x
Thu Sep 22, 2005 10:22 am
3c905C-TX/TX-M not works auto negotiation, full duplex & link status:
[xxx@19KV] interface ethernet> moni 0
status: no-link
auto-negotiation: disabled
rate: 10Mbps
full-duplex: no
default-cable-setting: standard
in winbox status "nolink, rate 10mb, no full duplex"
it is tested on many deskside and network card
with Intel pro100, via, rtl & other lan card its ok
BooT
Thu Sep 22, 2005 3:01 pm
same problem....seems to be unlinked, but network running and card is functional...only not see status on MK :(
Eugene
Forum Veteran
Forum Veteran
Fri Sep 23, 2005 12:14 pm
This card is reported to have autonegotiation issues. AFAIK, latest 3com windows driver contains a workaround, though it is windows-only :(
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
point
Fri Sep 23, 2005 1:23 pm
2 Eugene
Аналогичная ситуация с картой AT-2700FX (загружен драйвер AMD PCnet32 79c970 [PCnet32 LANCE] (rev: 54))? но с ней даже не запускается линк :(
Eugene
Forum Veteran
Forum Veteran
Fri Sep 23, 2005 1:30 pm
Problem with a hub/switch? This card works for sure.
point
Sat Sep 24, 2005 12:34 pm
Нет, проблема всё-таки в драйвере карты- карта FX (оптика), драйвер у MT не умеет переключать FX/TX... :(
пришлось переключать вручную
taloot
Sat Oct 08, 2005 5:33 pm
it works for me fine but i just see its not full depulex and 10 mbits speed
infomate
Mon Oct 10, 2005 4:50 pm
this card does not work (for me at least) connected to an AP or connected to a LAN. I have tried to use all the combination possible configurations to no avail.
Good luck!
Robert S.
pike
Wed Feb 08, 2006 12:53 am
I've got the same problem.
In 2.8.x it works 100mbit and full duplex and with auto negotiation,
but in 2.9.x can only run 10mbit and half fuplex without auto negotiation.
I send both sup.rif (from 2.8 and 2.9) to Mikrotik and nobody aswered.
Users browsing this forum: anav, Google [Bot] and 45 guests
