TKITFrank
RouterOS v5 RC3
Fri Oct 29, 2010 8:30 pm
What's new in 5.0rc3 (2010-Oct-29 09:02):
*) wireless nv2 - fix stalls on encrypted 11n links using high rates;
*) wireless nv2 - fix encryption related kernel crash;
*) sstp - fixed memory leak;
*) fixed problem - bad boot/kernel crc was reported on powerpc boards
when in fact it was good;
fewi
Re: RouterOS v5 RC3
Fri Oct 29, 2010 8:34 pm
http://download.mikrotik.com/all_packag ... 5.0rc3.zip
404 Not Found at 10.34am PST on 10/29
uldis
Re: RouterOS v5 RC3
Fri Oct 29, 2010 8:37 pm
just checked - works fine.
Try downloading using the torrent maybe.
csickles
Re: RouterOS v5 RC3
Fri Oct 29, 2010 8:53 pm
X86 from Lat = ok.. From US = FAIL.
Torrent Almost NO seeeds (Yet)..
Will watch it..
Things that make you go "Hmmmmmmmm"...
Craig
TKITFrank
Re: RouterOS v5 RC3
Fri Oct 29, 2010 9:00 pm
Works from Sweden...
MTCNA
"I don't believe UNIX is Utopia. It's just the best set of tools around."
fewi
Re: RouterOS v5 RC3
Fri Oct 29, 2010 9:06 pm
Works now via HTTP.
changeip
Re: RouterOS v5 RC3
Fri Oct 29, 2010 9:19 pm
I just built the entire structure and am now seeding it. hopefully that helps.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
csickles
Re: RouterOS v5 RC3
Fri Oct 29, 2010 10:10 pm
Thx Sam...
Craig
macosoft
Re: RouterOS v5 RC3
Sat Oct 30, 2010 3:10 pm
RC2 and RC3 blocks all traffic from my network to gateway. I have a public IP class and I dont have any routing system.
Downgraded to RC1 and works fine.
peson
Trainer
Trainer
Re: RouterOS v5 RC3
Sat Oct 30, 2010 6:33 pm
WARNING!!!
Do not use this version in production system, at least not in x86 systems.
It breakes your firewall settings.
/Paul
Reboot is the last resort, try to find out what's wrong instead.
TKITFrank
Re: RouterOS v5 RC3
Sat Oct 30, 2010 7:06 pm
WARNING!!!
/Paul
Can you be more specific? I have about 200 rules on my RB800 with L7 connection-mark and jump rules and so on. No problems like RC1. To my knowledge all works.
But it might be as you say only on x86. Uldis said something about content filtering not working. See below
The firewall is still acting goofy on the drop chain. This was preset on RC1 as well....
-tp
problem is with the 'content' matcher. Avoid using it and rest of the firewall will work fine. We will fix it in the next version.
MTCNA
mars
Re: RouterOS v5 RC3
Sat Oct 30, 2010 7:25 pm
scripts dont work properly either on x86
NetworkPro
Re: RouterOS v5 RC3
Sat Oct 30, 2010 7:52 pm
I just tested NetInstall. It formated and installed the setup thing on a USB drive that had older RouterOS on it. After booting this USB drive - Setup did not find any harddrives. And with v3 this works.
I also tested to upgrade RC1 to RC3 in demo mode. In log it states the package was installed. But in fact the process was quick like a flash and when it booted up the version was still RC1 and the package was not installed.
Another thing - there are still problems in /store disk, the reported size sometimes is 0, and after a restart - its ok again.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
peson
Trainer
Trainer
Re: RouterOS v5 RC3
Sat Oct 30, 2010 8:18 pm
You a license to change versions, upgrade/downgrade won't work in demo license
NetworkPro
Re: RouterOS v5 RC3
Sat Oct 30, 2010 8:38 pm
Oh yeah you are right. But it did not give the proper error message.
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS v5 RC3
Sun Oct 31, 2010 1:42 am
About 24hrs and I think the memory leak in SSTP may be fixed... Its dropped a little, but that may just be everything "settling in". Will know in a couple days.
Firewall is working on ppc and mipsbe so far as I can tell. Mangle, marking, filter, nat.
peson
Trainer
Trainer
Re: RouterOS v5 RC3
Sun Oct 31, 2010 9:41 am
Correct, the content matcher still breakes the filtering.
I disabled the rules with content matcher and it works again.
WARNING!!!
/Paul
-tp
acim
Re: RouterOS v5 RC3
Sun Oct 31, 2010 10:04 am
On my Linux server I can't execute command like this anymore:
ssh user@remote_mt '/export file=backup'
I use passwordless login. This worked on 3.x and 4.x.
In the same time, command like this is still working fine:
ssh user@remote_mt '/file print'
So, there seem to be some problem with new SSH daemon.
This is on RB800, I haven't tried other platforms.
And thank you for adding Serbia on the countries list 8)
hrvoje
Re: RouterOS v5 RC3
Sun Oct 31, 2010 2:36 pm
scripts don´t work on x86
NetworkPro
Re: RouterOS v5 RC3
Sun Oct 31, 2010 2:44 pm
What exactly script function is not working? We know that ping is not returning a value. This should be fixed in final version.
hrvoje
Re: RouterOS v5 RC3
Sun Oct 31, 2010 2:57 pm
ok, tnx
vacarosie200
Re: RouterOS v5 RC3
Sun Oct 31, 2010 8:28 pm
System Health Voltage = 28V .... in a SolarTik with 12V panel :))) ...downgrade it to RC1 till this bug is fix it ... and die :((... will go to top of the hill to try to reflash it with rs232 ... hope to not rain tomorow
regards
NetworkPro
Re: RouterOS v5 RC3
Sun Oct 31, 2010 9:13 pm
I doubt it that the voltage monitor is for anything else then user information.
dssmiktik
Forum Veteran
Forum Veteran
Re: RouterOS v5 RC3
Sun Oct 31, 2010 9:50 pm
I'm having this same problem with /export on x86 v5.0rc3
Both are hanging (sometimes they run ok, other times they hang):
   /export file=test
   /system backup save name=test
Doug
Freqman
Re: RouterOS v5 RC3
Mon Nov 01, 2010 7:17 pm
Are their any plans for WDS support in WDS Slave or Bridge mode? I have my setup working in Station WDS with RB711 and an RB800 with the r52hn
matvej
Re: RouterOS v5 RC3
Tue Nov 02, 2010 10:59 am
RB 1100 ports 1-10 not working! :?
normis
Re: RouterOS v5 RC3
Tue Nov 02, 2010 11:09 am
send supout.rif file to support
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS v5 RC3
Tue Nov 02, 2010 10:36 pm
~110mb gone in just under 4 days. So leak is still there.
spruce
Re: RouterOS v5 RC3
Tue Nov 02, 2010 10:46 pm
Good day.
After install new ROS v5.0rc3 my cpu usage snmpwalk returns not applicable values.
In WinBox CPU Load is 36-50%, but in SNMP:
..# snmpwalk -v 2c -c community host .1.3.6.1.2.1.25.3.3
HOST-RESOURCES-MIB::hrProcessorLoad.1 = INTEGER: 1
HOST-RESOURCES-MIB::hrProcessorLoad.2 = INTEGER: 0
I use this OID in requests: .1.3.6.1.2.1.25.3.3.1.2.1
It`s feature or bug? Thanks.
janisk
Re: RouterOS v5 RC3
Wed Nov 03, 2010 12:08 pm
feature :) it showed system load on core. It will be changed to show correct value of cpu load
Alfabi
Re: RouterOS v5 RC3
Wed Nov 03, 2010 1:54 pm
sometimes frezze rb 493 we lost access from radio and Eth intefaces, after turn on/off reboot all works fine that was happen 3 times per week
http://www.bios.if.ua/pdf/mikrotik/autosupout.rif
http://www.bios-computer.com - Fastest WISP in UA
normis
Re: RouterOS v5 RC3
Wed Nov 03, 2010 2:03 pm
file shows some MPLS problems. email support please
Xymox
Re: RouterOS v5 RC3
Wed Nov 03, 2010 9:59 pm
Ooooo wow cool....
On my RB750G system health shows 6184.4 V.. 6KV !.. Wow now thats a upgrade from the lowly 12 V it normally runs on...
U might wanna check that :)
janisk
Re: RouterOS v5 RC3
Thu Nov 04, 2010 9:43 am
previously it showed normal voltage, on what version?
kozmai
Re: RouterOS v5 RC3
Fri Nov 05, 2010 6:20 pm
- Dude 3.6 shows not correct value about CPU load
- upgrade from 3.30 I can't update licence key: I have to downgrade to 4.11, update licence key, then upgrade to 5 RC3
zervan
Re: RouterOS v5 RC3
Sun Nov 07, 2010 11:18 pm
Is it possible to upgrade to this version from 4.13 on RB750/750G without lost of all the settings? Could I import settings from backup file? Could I downgrade back to 4.13 in the case of some problems?
What is the main difference between v4 and v5? Is there some webpage about that?
When do you expect to release final v5? This year?
Thanks!
Dusan Zervan from Slovakia
MTCNA, MTCRE
blake
Re: RouterOS v5 RC3
Mon Nov 08, 2010 3:22 am
Yes you can upgrade and downgrade without losing settings. You should probably make a backup just in case.
This presentation from MUM USA 2010 on new RouterBOARDS and ROS 5.x will highlight the major differences between 5.x and 4.x. You could view the 5.x changelog for detailed info & bug fixes.
Normally the release dates are "when its ready."
IT consultant. Network manager. Packet junkie.
1-928-328-1509
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS v5 RC3
Mon Nov 08, 2010 5:26 am
RB450G, if switch all ports is not selected, NO interfaces function. Upgraded about 100 routers running 5.0b4/5. 2 never came back up. Both had switch all ports unchecked. Tested it in office and confirmed.
Also, my RB1100, when I put RC3 on it, ether 1-10 didnt seem to work right if they were in a switch group. Probably related. Im guessing they have the same switch chip.
janisk
Re: RouterOS v5 RC3
Mon Nov 08, 2010 10:56 am
- Dude 3.6 show not correct value about CPU load
SNMP cpu load value will be corrected in rc4
hobbyist
Re: RouterOS v5 RC3
Sun Nov 14, 2010 3:05 am
Just a "me too".
I have seen this on an RB450G with a default 5.0rc3 that I was connected through the serial port. When the switch-all-ports was set to no, that the default bridge that defined was gone, and that any bridge settings I did after that would be gone after a reboot. And that the router didn't work over ethernet. At some point I had a kernel panic and sent in the support file to support. The with switch-all-ports set to yes, no problems seen.
Users browsing this forum: No registered users and 74 guests
