dalmolini
VMware does not recognize PCI WiFi
Mon Nov 08, 2010 4:22 pm
We know it is a common problem for most virtualizers (VMware, Citrix, etc.) do not recognize the HARDWARE of the PCI, even when the chances of a WiFi USB WiFi work are greater. If anyone has experienced this or has a solution, please post a reply, thanks.
My intention is to use the MikroTik virtualized, but I need to use WiFi interface Workstation VMware or 7 on a desktop computer with OS Windows XP.
roadracer96
Forum Veteran
Forum Veteran
Re: VMware does not recognize PCI WiFi
Tue Nov 09, 2010 4:55 am
Use KVM or XEN on a VMX enabled processor/MB. I havent every used it for a wireless card, but other various PCI cards have always worked great. VMWARE is very lacking in that area.
janisk
Tue Nov 09, 2010 2:34 pm
if virtualization environment allows you to assign host hardware directly to guest, then in theory, you will be able to work with that resource similar to non-virtualized environment. KVM in RouterOS does not allow to do this.
Users browsing this forum: No registered users and 5 guests
