wilburt
Newbie Wifi tx/rx speeds via RB411AH with R52
Tue Dec 07, 2010 3:06 pm
Hi MT Wireless experts!!!
I have a simple WLAN setup with a RB800 as the primary router for the HS. From the RB800 I get 4+Mbps download speed, but at the wireless client I get a max of 80Kbps
Is there something I can change on the wireless card to improve the wireless client download speeds? I only have one R52 card in the RB411AH and one 2.4Ghz Omni antenna.
This is the configuration I have on my RB411AH with the R52 wlan card
0 R name="wlan1" mtu=1500 mac-address=xxxx arp=enabled disable-running-check=no
interface-type=Atheros AR5413 radio-name="xxxx" mode=ap-bridge ssid="xxxx" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2417 band=2.4ghz-b/g
scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 hw-retries=4 frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
Thanks in advanced.
wilburt
Re: Newbie Wifi tx/rx speeds via RB411AH with R52
Wed Jan 19, 2011 9:45 am
just in case anyone comes across this post, i did some test and for my case changing the wireless frequency helped wit hthe speed and stability of the wifi connection.
hope this helps anyone else.
Users browsing this forum: No registered users and 28 guests
