MUM Europe 2020
rini
Problem with license key
Wed Dec 15, 2010 2:49 am
Hi all
I have a problem with rb411
i want to upgrade from version V.3.30 to V.4.15
when upgrade finish the routerboard tells that the license key is invalid
i try to update but a error shows up
i downgrade it and the license is ok now
and tells that is upgradable to V.6.x
i try again to upgrade to 4.15 same problem .
i have 6 more rb400 series I upgrade to V.4.15 and they are ok
do I have problems with this RB411 ????
fewi
Re: Problem with license key
Wed Dec 15, 2010 2:54 am
Have you updated your license key before upgrading the OS?
If that still doesn't help, contact support@mikrotik.com for licensing questions.
rini
Wed Dec 15, 2010 12:05 pm
If that still doesn't help, contact support@mikrotik.cok for licensing questions.
I resolve this another way thanks
normis
Wed Dec 15, 2010 12:31 pm
we have found a problem that could be fixed in RouterOS to avoid this happening. We are working on it now. Until then, you have to email support.
Users browsing this forum: ewingpd, PandaArea and 100 guests
