Within the local network, behind NAT (RB450) is VoIP server Asterisk, which is stored on the server provider. Calls proceed normally, his voice too, but as regards the case of the fax transmission protocol T38, mikrotik begins to create problems: packages t38 simply does not pass from the provider to the server via NAT. This is well illustrated in the diagram:
left - the dump is cleared by sniffer
right - on the server Asterisk.
What can I do?
SIP helper tried to turn on and off - does not help.
All rules on the router to make the default configuration of the web interface.
