Fumi
Transmit with 2 R52nm
Thu Dec 30, 2010 7:27 pm
I try to transmit simultaneuos with 2 R52NM and performance is low..
1.- Only transmit wlan1<--->wlan1 bandwidth test UDP:220Mbps
2.- Only transmit wlan2<--->wlan2 bandwidth test UDP:220Mbps
3.- Transmit simultaneous wlan1 and wlan2 ant bandwidth test is slow.. 120 Mbps for radio.
I try to down tx power to 5 and I have good separation with antennas and pigtails.. I don't know what is the problem...
Fumi
Re: Transmit with 2 R52nm
Fri Dec 31, 2010 1:08 pm
I have make more test and I can say that 2 radios transmit simultaneous can be work in 5Ghz-onlyN. There is no problem with interference. I test with separate boards and it's work but when I put two radios in same board it fail... :(
roc-noc.com
Forum Veteran
Forum Veteran
Fri Dec 31, 2010 2:31 pm
Have you measured the power draw when transmitting with both radios?
The RB52Hn takes a lot of power and transmitting will be the highest usage.
Just a guess but maybe you are running out of power.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
Fumi
Fri Dec 31, 2010 2:42 pm
I have POE Gigabit 40W I think power its not the problem
Belyivulk
Sun Jan 02, 2011 5:31 am
I'd suggest check your LMR cables - and separate your antennas more. the N radios are super sensitive to noise (or so we've found) we've had more than one leaky cable cause us trouble!
Fumi
Mon Jan 03, 2011 11:05 am
I try with same cables and same distance but with separate routerboards:
RB1 (1Radio)<-------------> RB2 (1Radio)
RB3 (1Radio)<-------------> RB4 (1Radio)
In this situation there is no problem, but the problem is when I use 1 RB with 2 radios.
Belyivulk
Mon Jan 03, 2011 10:14 pm
I suppose thats because they are highpower and stacked, in an RB4xx series at least. Let me know if you ever get this to work :) It could explain why we have some poor performing links shared with high power N cards :)
Fumi
Sun Jan 09, 2011 10:22 pm
I try to down tx power to minium value, then the consumption for each radio is lower.. But the problem persists.
There is a way to make double link simultaneous?
Thanks for all!
Users browsing this forum: amirsabeghi and 50 guests
