I can't see the problem
. The access points can't create loops because, if you configure them as AP bridge, they can't registe to each other creatng a loop.
Anyway if you want to be absolutely shure that a loop can't be created in your network, you have to simply enable RSTP on the bridge created inside the RB450 and Access Points:
/interface bridge set bridge1 protocol-mode=rstp
