alias2k11
RouterOS Sip Header
Fri Jan 14, 2011 9:46 am
I have a RB750G running 4.x RouterOS. I'm having a problem with my sip trunk provider seeing my local ip address on there end so I get one way audio. How can I, or can I have the router NAT the Sip header?
Thanks in advance.
sergejs
Re: RouterOS Sip Header
Fri Jan 14, 2011 11:25 am
RouterOS SIP helper is available at /ip firewall service-port, however it is enabled by default.
alias2k11
Fri Jan 14, 2011 11:33 am
Thanks for the reply, however I have check that and it is enabled. Is there anything else I can look at?? They showed me the sip head and it clearly shows my local ip address.. Thanks for the input.
mbeckwell
Sat Jan 15, 2011 10:08 am
Have you tried disabling the SIP profile in the firewall?
I had this exact same problem, and turning it off took care of it.
I have yet to see a SIP "helper" that actually worked correctly (MikroTik or otherwise), particularly if your service provider is already trying to do NAT traversal on their side.
