MUM Europe 2020
Do you have the same problem?
Yes
2 (67%)
No
No votes
I haven't tried yet
1 (33%)
Total votes: 3
ShShZ
Master Port Problem on RB750
Mon Jan 17, 2011 12:37 pm
As it is possible to RB750G to remove the default settings and set the ether1 to master port of the rest ehter ports, I couldn't do so in RB750. I wonder why?
Best Regards,
Shahram Shams
kirshteins
Re: Master Port Problem on RB750
Mon Jan 17, 2011 12:57 pm
Only ether2-ether5 can be switched on RB750.
arpadffy
Mon Jan 17, 2011 11:19 pm
I wonder if all 5 ports are equally configurable on a RB750?
I have a feeling that ether5 has some problems (5.0rc7) as PPPoE is configurable but does not work as well as ether5 can not act as local master nor as a DHCP server port.
The same configuration on ether3 works perfect.
Regards,
Z
ShShZ
Tue Jan 18, 2011 12:46 pm
I looked up "rb750.pdf" on routerboard.com and the line below is written in it.
Ethernet: Five 10/100 ethernet ports (with switch chip)
Best Regards,
Shahram Shams
normis
Tue Jan 18, 2011 12:56 pm
yes, all 5 ports are equally configurable on a RB750.
the ether1 port can't be switch master, that's the only limitation. you can put any config on the ether5 port.
ShShZ
Tue Jan 18, 2011 1:36 pm
Is it possible to set ether5 to Master and the rest to slave of ether5?
Best Regards,
Shahram Shams
kirshteins
Tue Jan 18, 2011 1:59 pm
Regards,
Z
Please send this report to support@mikrotik.com along with supout.rif file from the router.
Users browsing this forum: abrar226 and 30 guests
