MUM Europe 2020
vacarosie200
rb750 rx error
Tue Jan 18, 2011 11:56 pm
no matter sw release .. no matter cable type or lenght ... it's any way to fix this type of problems?
i attach a print screen for more accuracy
i have 5 pieces of rb750 ... all have that problem ... i don't like to retier them :)...
kirshteins
Re: rb750 rx error
Wed Jan 19, 2011 3:04 pm
What type and how much traffic is going through? What devices are connected to each interface? Are you using standard 12V/0.5A power supply? Also, please, send supout.rif file to support@mikrotik.com
vacarosie200
Re: rb750 rx error
Wed Jan 19, 2011 10:46 pm
sent it
dominicbatty
Re: rb750 rx error
Tue May 29, 2012 8:56 pm
Did you find the problem, I have something similar. Thx. Dom.
krode
Re: rb750 rx error
Tue May 21, 2013 7:09 pm
Anything on this yet ? i have the same error i am using Air Fiber from Ubiquiti on the port im getting the RX error let me know if there is a solution to it.
Ive changed the cables , verify the Speed of each nic and everything seems great
MARIODC
Re: rb750 rx error
Mon Dec 02, 2013 12:27 am
vacarosie200 GOOD NIGHT
Solved the problem HERE THE SAME DEFECT
Users browsing this forum: No registered users and 30 guests
