heleopless
pccloadbalancing on one device and another control bandwidth
Sun Jan 23, 2011 1:54 pm
i want to carry oyt pcc load balancing to collect traffic from two lines
make the whole traffic coming from two gateways pass throw only one gate way in another
mikrotik device
so i can deal with two lines as if it is one line and one gateway
in this way
2 mega from one line + 2 mega frome the second = 4 mega but i want to put only one ip route in mikrotik so it will be helpful in putting scripts and making hotspot
any ideas??????????
heleopless
Re: pccloadbalancing on one device and another control bandw
Sun Jan 23, 2011 2:05 pm
i want the traffic from two gateways pass throw one gate way
then the traffic will reach the second device in this second device we will put only ip route and only two interfaces wan and lan not two wans an d one lan
heleopless
Sun Jan 23, 2011 2:16 pm
the idea here
can i make the first mikrotik to be the gateway of the second mikrotik
in the first one i will make pcc load balancing
and in the second i will take the loadbalancing traffic coming from the first
then i will make my hotspot and give the traffic for the users
fewi
Sun Jan 23, 2011 5:28 pm
Yes, you can do all that without any changes to how you'd normally configure routers for those scenarios.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
heleopless
Sun Jan 23, 2011 10:22 pm
please explain
fewi
Sun Jan 23, 2011 10:33 pm
Explain what?
Just configure a router for PCC, connect a second router to it, and use the first router as the default gateway of the second one. Just like you asked. It will just work.
heleopless
Sun Jan 23, 2011 10:53 pm
ok thanks alot
Users browsing this forum: elico, jangdong and 145 guests
