centsi
API v wireless-protocol=nv2-nstreme-802.11
Fri Jan 28, 2011 1:08 pm
Hi.
I can happily set wireless-protocol=nv2-nstreme-802.11 using terminal or telnet, and I can change wireless-protocol to "any" using the API.
When I try to set wireless-protocol=nv2-nstreme-802.11 using the API however, it just ignores the setting completely.
Any ideas?
I wonder if it's something to do with the dot in 802.11?
I've tried without the dot and without the ".11", but it still didn't work.
Is this a bug?
Cheers - Lawrence
uldis
Re: API v wireless-protocol=nv2-nstreme-802.11
Mon Jan 31, 2011 5:31 pm
we will try to fix it in one of the next RouterOS releases.
