Rafaela
Do the RB's work.
Fri Feb 04, 2011 2:58 pm
Hi, i'm from Brazil, and I fix Rb's(I try).
I have some PDF with repair instructions.
We could trade ideias for RB's with NON WARRANTY.
A picture with the faulty components that i've seen.
The blue components are changed to do the RB turn on.
The Red components are changed to me connect to Ethers.
The green components are changed to do the board boot.
->In the CPU just was made reflowed.
Come back to me, it's almost easy
GuJack20
Trainer
Trainer
Re: Do the RB's work.
Fri Feb 04, 2011 10:43 pm
Hello Rafaela.
Nice idea to discuss.
I also (try to) repair RBs.
For the Ethernet connectors part. I haven't ever changed them (if they weren't mecanically damaged of course). Except the Ether1, that has the PoE pins, i don't see how the others can affect the turning on of the RB.
Also. I wanted to ask. How do you test and measure the components in blue??
--Do you remember that guy who gave up? Neither does anybody else!
Rafaela
Mon Feb 07, 2011 1:44 pm
The Ether ports, I tested but don't find nothing of different. So I knew that C826(3,3V) was short circuited with GND. I removed component by component and tested if fade the short. If you will try to repair a board that don't turn on, I advise change first the J603.
In the other cases, I check the voltage of the pin 7 of U803 and isn't 3,3V(like another that I was comparing).
The D801 and the Q801 I found easily the datasheet, and tested.
And the L801 was with a resistence diferent than 0 Ohms.
More any question? :D
janisk
Mon Feb 07, 2011 3:13 pm
you can try to ask your distributor for available repair manuals.
Rafaela
Mon Feb 07, 2011 3:23 pm
I have this manuals. But have other problens.
I would like of know, what happen, and where is the defect, of the board that turn on, connect by the ether, and don't appear nothing in winbox.
janisk
Mon Feb 07, 2011 3:33 pm
there can be number of problems - starting from hardware problems with damaged port controllers ending with damaged RouterOS installation that can be bought back with simple netinstall.
Rafaela
Mon Feb 07, 2011 7:08 pm
Could you help me to find at least one hardware problem? *-*
honzam
Mon Feb 07, 2011 7:57 pm
LAN, FTTx, Wireless. ISP operator
Rafaela
Mon Feb 07, 2011 8:30 pm
I have this manuals, and others. But have some problems that have another solution.
Sometimes I tested until the 'The board is unrepairable' and after I find the solution.
I wanna know about the hardware problens that are out of this repair manual.
:D
Rafaela
Fri Feb 11, 2011 8:24 pm
Any ideia for when the RB is on, and after a time the RB shutdown? And don't turn on more?
GuJack20
Trainer
Trainer
Sun Feb 13, 2011 12:39 pm
Yeah Rafaela. You are right. There are plenty of problems i run into that are not covered on the repair manuals of the distributors.
The question you are asking (about nothing showing in winbox) has happened to me many times with the new version of the RB411. I solved it by changing the ether chip. Even if it connects (green led on ether connector turns on), it doesn't really work.
Mostly of the times is a damaged ether chip that looses packets in rx, tx or both ways.
The simplest test i do about the state of the ether chip is trying to boot the routerboard via ethernet with netinstall. If it doesn't connect, even if the led is lit, i proceed on changing the ethernet chip..
After repairing i test with speedtest of MT and see if there is any packet loss.
Do you know a better way??
Rafaela
Mon Feb 14, 2011 3:32 pm
No... in the mostly of times, the buzzer(B1) of the board don't honk. So I can't boot the RB via ether with netinstall. :(
Do you have any ideia? *-*
FIPTech
Tue Feb 15, 2011 3:10 am
No boot is often a power problem. Check chemical capacitors. 90 % of problems do come from them.
Dissolder and check the value. 1/2 original value is generaly ok. 1/5 or 1/10 is not ok...
Rafaela
Thu Feb 24, 2011 2:19 pm
In my city I don't find any capacimeter. So I'm buying by a store in anothe city.
When the capacimeter arrive, I'll test and post here.
More any help?
:D
FIPTech
Thu Feb 24, 2011 10:15 pm
If you want more help, you need to remove the bra :=)
Ibersystems
Thu Feb 24, 2011 11:53 pm
xDDDD
man..
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
FIPTech
Fri Feb 25, 2011 10:42 am
Generally bad capacitors have a curved top, or they can even explode. This is why there are small breaking marks on the top, to avoid too powerful explosions.
If electronic circuits didn't had chemical capacitors, they would be at least ten times more reliable in the long term.
Rafaela
Fri Feb 25, 2011 8:26 pm
Remove the Bra of Brazilian?
rsrs
sorry, but why?
Ibersystems
Fri Feb 25, 2011 9:12 pm
Fiptec, I can show you my nipples if you want to... xD
Martín
Rafaela
Fri Feb 25, 2011 9:16 pm
Ow.. now I understand, bra (sutiã in portuguese), rsrs.
If someone help, who knows.
rsrsrsrs
Rafaela
Fri Feb 25, 2011 9:22 pm
I've found some bad capacitors that explode. But I never found in a RB433.
GuJack20
Trainer
Trainer
Fri Feb 25, 2011 11:19 pm
I have repaired "no boot" RB450 by changing the capacitors. I think that series had this problem quite often
Ibersystems
Fri Feb 25, 2011 11:53 pm
I hve a rb1000 that don't boot.. What can I do?
Martín
FIPTech
Fri Feb 25, 2011 11:56 pm
I've changed recently capacitors on a RB750G. Capacitors did not resist to the last summer where we had about 35 degrees during one week.
The client site was hot. I suspect about 38-40 degrees.
GuJack20
Trainer
Trainer
Sat Feb 26, 2011 11:18 pm
The same for me :(:(:(
Any solutions on this??
FIPTech
Sun Feb 27, 2011 11:55 am
Rafaela, wich equipment do you have to change Red and Green components ?
GuJack20
Trainer
Trainer
Sun Feb 27, 2011 5:08 pm
For the red ones i use
http://www.collectibles-articles.com/an ... 29465.html
Something more professional though would be really nice :):)
trk40
Sun Feb 27, 2011 5:49 pm
I have RB433 flooded by water, there is a little marks of corrosion.
Of course when I connect power plug nothing happens.
I checked by meter capacitors and none seems to have short-circuit to gnd.
Q801 have short circuit between 3 and 4 pins which are connected together.
U803 - according to data sheet I have 1,5V between Vdd and gnd pins.
Any ideas what else I can check ?
Rafaela
Mon Feb 28, 2011 5:05 pm
I use Hot Air and a Soldering Iron.
The red I remove with the hot air, and soldered a new component using the soldering iron.
The green(CPU) I just warmed the component.
I helped you with something? *-*
Rafaela
Mon Feb 28, 2011 5:16 pm
They aren't connected together.
Q801 have pins 1, 2 and 3 together, and they are connected in katodo of the zener diode D803, and the pin 4 is connected to anodo.
trk40
Mon Feb 28, 2011 7:30 pm
I know, I meant short-circuit between pins 1-2-3 and 5-6-7-8
but know I see that 1-3 and 5-8 are connected together when I plug power jack and later without external power until 811 have electrical charge left. Is is correct?
Rafaela
Mon Feb 28, 2011 10:47 pm
I just know that in the output of Q801 need to be with 12V.
Less than this i change the faulty component.
Rafaela
Wed Mar 02, 2011 2:27 pm
Someone knows what do when the slot card don't work?
In some cases is just one slot, but when is the 4(for RB800)?
YuSHa
Wed Jun 29, 2011 7:36 pm
Hello! can you send me all repair manual? did you have a repair manual for ubnt devices?
Users browsing this forum: glueck05 and 72 guests
