MUM Europe 2020
el berto
How make redundant link network?
Fri Feb 04, 2011 8:37 pm
Hi, I would like to make a redundant network like the following diagram:
In this example I need to have k.o. all five center RBs to stop communication between left and right radio.
How can I configure my RB433AH to do this?
Thanks.
chadd
Re: How make redundant link network?
Sat Feb 05, 2011 3:02 am
With that setup it looks like you would be best off running WDS with RSTP bridging or in mesh mode. There are some examples on the Wiki.
Thanks.
el berto
Mon Feb 28, 2011 7:12 pm
I've found these notes on wiki:
http://wiki.mikrotik.com/wiki/Mesh_wds
if them are the right ones.
So it's just to set the bridge to run in SRTP mode?
Step n°2: I have to make this connection to have a redundant, safe connection between 2 PCs, so I should use the same configuration? I think yes......or not?
SOR.TIF
el berto
Mon Feb 28, 2011 7:25 pm
And if I have a cable link with a redundant radio-link, is it still the same bridge configuration?
SABO.TIF
el berto
Mon Feb 28, 2011 7:51 pm
Sorry, I have problems with attachments; let's say my complete system would be this:
http://www.crs.inogs.it/telemetria/supersafe.TIF
Where my main connection is through optic fiber (in the schematic is a long ethernet cable), then I would place 4 radios.
So the link is if the fiber optic link is BROKEN and, at AT THE SAME TIME I have AT LEAST 3 radios broken on 4 available.
Is the RSTP mode correct or have I to do something more?
Thanks.
normis
Tue Mar 01, 2011 2:52 pm
don't use TIF, use JPG or PNG for attachments in the forum
el berto
Tue Mar 01, 2011 6:40 pm
Ok, so that's my betwork:
el berto
Fri Apr 22, 2011 9:51 am
Ok, let's take this:
http://wiki.mikrotik.com/wiki/Testwiki/ ... s_networks
Let's image in Figure 14.3 I have routers C and D connected also trough ethernet cable (so wireless + cable).
How can I setup ethernet port to work correctly?
Just set bridge in RSTP mode or anything else?
Thanks.
Users browsing this forum: dylan2228, Lifz, vstrkz and 37 guests
