bda
several interface problems on 5.0rc8 + intel Core i5+H67
Sat Feb 05, 2011 1:10 am
Dear Mikrotik Dev Team,
My device have:
CPU: Intel Core i5-2400S 2.5Ghz Soket 1155
MB: INTEL DH67CF (OEM) LGA1155 <H67> PCI-E+DVI+HDMI+DP+GbLAN SATA RAID Mini-ITX 2DDR-III
Additional Network Adapter: Intel <E1G42ET> Gigabit Adapter Dual Port (OEM) PCI-E x4 10/100/1000Mbps
I am in real big trouble. My new installed device has very strange behavior...
- integrated lan is not detected. Very bad for me
- After i am issued interface print stats - than interface is going down. After some time - it come up again. Winbox - connected, but if I go to interfaces menu - active interface go down again.
- Some other system cli commands turn interfaces down, for example - cpu information
Some details:
# DEVICE   VENDOR                                                        NAME                                                        IRQ
 0 03:00.0  NEC Corporation                                               unknown device (rev: 3)                                     10
 1 01:00.1  Intel Corporation                                             82576 Gigabit Network Connection (rev: 1)                   10
 2 01:00.0  Intel Corporation                                             82576 Gigabit Network Connection (rev: 1)                   11
 3 00:1f.3  Intel Corporation                                             Cougar Point SMBus Controller (rev: 4)                      11
 4 00:1f.2  Intel Corporation                                             Cougar Point 4 port SATA IDE Controller (rev: 4)            4
 5 00:1f.0  Intel Corporation                                             unknown device (rev: 4)                                     0
 6 00:1d.0  Intel Corporation                                             Cougar Point USB Enhanced Host Controller #1 (rev: 4)       7
 7 00:1c.1  Intel Corporation                                             Cougar Point PCI Express Root Port 2 (rev: 180)             11
 8 00:1c.0  Intel Corporation                                             Cougar Point PCI Express Root Port 1 (rev: 180)             10
 9 00:1b.0  Intel Corporation                                             Cougar Point High Definition Audio Controller (rev: 4)      3
10 00:1a.0  Intel Corporation                                             Cougar Point USB Enhanced Host Controller #2 (rev: 4)       11
11 00:19.0  Intel Corporation                                             unknown device (rev: 4)                                     5
12 00:16.0  Intel Corporation                                             Cougar Point HECI Controller #1 (rev: 4)                    11
13 00:02.0  Intel Corporation                                             Sandy Bridge Integrated Graphics Controller (rev: 9)        11
14 00:01.0  Intel Corporation                                             unknown device (rev: 9)                                     11
15 00:00.0  Intel Corporation                                             unknown device (rev: 9)                                     0
Please help...
God bless UNIX!
bda
Re: several interface problems on 5.0rc8 + intel Core i5+H67
Sat Feb 05, 2011 1:47 pm
Some addition detail: integrated lan chip is Intel 82579V.
Another news: after i turn off "Multi CPU" - the system goes without interface resets, but only pcie card. Integrated card - still not detected.
God bless UNIX!
mangust
Sat Feb 05, 2011 8:05 pm
Do not use "latest" hardware.
No chance ... At least now.
martini
Sat Feb 05, 2011 11:11 pm
а так же не стоит юзать последнюю бету, на ней багов уйма.
bda
Sun Feb 06, 2011 10:01 am
Спасибо за конструктивный ответ...
А как же быть с новыми драйверами?
God bless UNIX!
martini
Sun Feb 06, 2011 6:24 pm
а чем тебя 7-я и 5-я RC версии не устраивают ?? там все теже драйвера, но работают они месяцами без проблем
bda
Sun Feb 06, 2011 10:42 pm
Пробовал и 5 и 7 - теже грабли, если использовать указанное железо. При этом, на Core2Duo+chipset X58 - все нормально.
God bless UNIX!
martini
Sun Feb 06, 2011 11:34 pm
хмм.. а не пробовал в биосе отключить встроенную сетевую ?? или она нужна тебе ?
mangust
Mon Feb 07, 2011 4:08 pm
Я же написал - нет смысла ожидать поддержки самого нового хардваре (CPU: Intel Core i5 и соответственно motherboard + LAN к нему).
Я наступил на те-же грабли год назад. Купив "не ту" сетевую карту за 500$.
На вопросы (почти годназад) когда-же выйдет стабильная версия - был ответ "как-только так сразу".
В результате уже почти год жду пока 5-ка станет стабильной.
Поэтому - не наступайте на мои грабли - Юзайте 4.16 и железо, которое его поддерживает.
martini
Mon Feb 07, 2011 7:45 pm
ага, и при трафике в 1 гигабит 4.16 версия загнется уже на 300 мегабитах.. Может всетаки ковыряние в биосе даст результат. Нужно попробовать разные варианты..
bda
Tue Feb 08, 2011 6:49 am
Да как-то не хотелось бы отключать встроенную сетевую. И особенно я горюю, что пришлось отключить многоядерность... просто катастрофа... Даже не знаю что и делать-то...
God bless UNIX!
normis
Tue Feb 08, 2011 8:11 am
this forum is in english, please switch to english
bda
Tue Feb 08, 2011 8:24 am
Sorry, but the initial questions was in english... Our conversation on russian was about new hardware and ROS5.
Could you please help me with my question?
God bless UNIX!
shade
Tue Feb 08, 2011 3:56 pm
I fell that this problem related to my http://forum.mikrotik.com/viewtopic.php ... =1#p248880
After upgrade from 5.0rc5 to 5.0rc8, I don't see interfaces in winbox, first time I was able to see them via ssh, but now I cannot see them. Some interfaces still works, some doesn't.
Нерешаемых проблем нет — есть проблемы, которые никто не решает
shade
Tue Feb 08, 2011 4:13 pm
загибается? а что такого появилось в 5.0 от чего не будет загибаться? Нам сейчас предстоит до 300 мбит прокачаться =)
bda
Tue Feb 08, 2011 5:31 pm
Thanks for the info! Do you have any progress on your ticket?
God bless UNIX!
shade
Tue Feb 08, 2011 5:51 pm
I recived 5.0rc9 preview, same thing + now IP protocol doesn't work =(
janisk
Wed Feb 09, 2011 9:47 am
what you mean by that? IP is OSI layer 3, if it is not working anything else is not working on upper layers for example, ICMP, TCP, UDP
shade
Wed Feb 09, 2011 10:30 am
[test@MikroTik] > /ip address print
75   192.168.6.6/16     192.168.0.0     ether1
[test@MikroTik] > /ip route print
[test@MikroTik] >
janisk
Wed Feb 09, 2011 11:34 am
Please create supout.rif file and send it to support
edit:
also, if you want to try - 5.0rc9 note that in e-mail as there where changes done to routing.
shade
Wed Feb 09, 2011 12:18 pm
I sent it, I will glad to see fixed 5.0rc9 or special build 5.0rc5 (x86) with ssh problem fixed =)
alexspils
Wed Feb 09, 2011 1:12 pm
IRQ balancer, RPS
bda
Wed Feb 09, 2011 2:19 pm
What do you mean? Balancer works? Or what? And RPS?
God bless UNIX!
janisk
Wed Feb 09, 2011 2:43 pm
these are 2 features that greatly increases throughput of multi-core hardware.
bda
Wed Feb 09, 2011 8:15 pm
Oh... Thanks. But as I said before - multicore - is not possible on rc8 and Core i5+H67. Maybe Mikrotik developers help me...
God bless UNIX!
bda
Thu Feb 10, 2011 11:57 pm
After installing 5.0rc9 - nothing changed... Very bad...
God bless UNIX!
alexspils
Fri Feb 11, 2011 12:03 am
did you tryed to install latest bios for motherboard?
janisk
Fri Feb 11, 2011 4:08 pm
Intel Core i5 CPU 660 @ 3.33GHz
this is my x86 test router cpu. So what problems exactly you are having with router sporting this CPU?
defekt
Fri Feb 11, 2011 10:10 pm
@janisk, what is model of your motherboard ?
martini
Fri Feb 11, 2011 10:54 pm
ну например 100 правил в mangle цепочке и 10 в nat и 1000 в роутинге + 300 мегабит трафика - и тебе обеспечена загрузка процессора 50% (если двухядерный проц), так как в версия до 5.х многопроцесорность не работает.
rzirzi
Sun Apr 10, 2011 10:37 pm
Is there MikroTik 5.0 final supporting Intel 82579V LAN and Intel P67 Chipset?
bda
Thu Apr 14, 2011 5:46 pm
Multicore is working for now... but i have no load tests on this chipset. On board Ethernet is not supported.
God bless UNIX!
Users browsing this forum: genesispro, jebz, oppermanr, pe1chl, StevenHunt and 180 guests
