bestefan
deleting files with the sam extension
Mon Feb 07, 2011 9:44 am
hi,
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] ".rsc"]]!="nil") do={/file remove $i}}
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] ".backup"]]!="nil") do={/file remove $i}}
this script remove all rsc and backup files in Mt 3.x. Working nice.
But, in 4.x remove only .rsc, and the .backups are left over.
Any idea, how can i fix it?
Thanks, bestefan
janisk
Re: deleting files with the sam extension
Mon Feb 07, 2011 12:42 pm
on 5.0rc8:
/file remove [find type="backup"]
/file remove [find type=".rif file"]
have to check what type you want to find before.
this can be done this way as /file remove command supports multiple arguments.
ik3umt
Thu Sep 27, 2018 6:03 pm
janisk :
/file remove [find type=".rif file"] is OK
But what if I have to delete all .rif files that are into a directory ? Which syntax ?
P:S: I mean ONLY the .rif files that are inside a particular directory, not other .rif files
Users browsing this forum: No registered users and 10 guests
