MUM Europe 2020
normis
RouterOS v5rc9
Thu Feb 10, 2011 1:19 pm
What's new in 5.0rc9 (2011-Feb-09 13:57):
*) wireless - fixed disconnect problem on long distance
802.11 40MHz links;
*) wireless nv2 - fixed station mode that broke when station-bridge
was introduced
*) wireless - more improvements for 11n compatibility;
*) kvm - fix guest starting;
http://www.mikrotik.com/download.html
struck
Re: RouterOS v5rc9
Thu Feb 10, 2011 2:17 pm
About my previous post from 5.0 rc8 ... The ROS with level 6 only supported 1500 concurrent PPPoE connections... why? Regards,
Adriano Struck
normis
Re: RouterOS v5rc9
Thu Feb 10, 2011 2:20 pm
It's possible that your hardware is not powerful enough. We have not heard such reports before
struck
Re: RouterOS v5rc9
Thu Feb 10, 2011 2:23 pm
Server Dell R410 with two processors Xeon quad-core 2.4Ghz (16 cores) with 32GB RAM DDR3... it is not powerful?
Adriano Struck
normis
Re: RouterOS v5rc9
what happens when you have 1500 connected, and 1501 tries to connect ?
struck
Re: RouterOS v5rc9
Thu Feb 10, 2011 2:26 pm
1500 connects. From 1501 only appears in the log: PPPoE connection established from (MAC).
Adriano Struck
laurinkus
Re: RouterOS v5rc9
Thu Feb 10, 2011 2:30 pm
routerboard upgrade doesn't work v5rc9
[admin@home] > system routerboard upgrade
Do you really want to upgrade firmware? [y/n]
y
firmware upgraded successfully, please reboot for changes to take effect!
< ... reboot ... >
[admin@home] > system routerboard print
routerboard: yes
model: "750"
current-firmware: "2.28"
upgrade-firmware: "2.32"
normis
Re: RouterOS v5rc9
Thu Feb 10, 2011 2:36 pm
did you send supout.rif file to support? what is the ticket number, I will check status. We need the file from the moment when 1501 connects. Preferrably with PPP debug logs enabled
normis
Re: RouterOS v5rc9
Thu Feb 10, 2011 2:37 pm
routerboard: yes
model: "750"
worked for me.
m4rk0
Re: RouterOS v5rc9
I've just installed 5.0rc9 and under "Files" [Restore] button is missing...
http://www.mreza-wisp.ba/
Please, give Karma if I fix your problem
Certified MTCNA
normis
Re: RouterOS v5rc9
Thu Feb 10, 2011 2:38 pm
known bug
laurinkus
Re: RouterOS v5rc9
Thu Feb 10, 2011 2:48 pm
worked for me.
[admin@home] /system routerboard> print
routerboard: yes
model: "750"
[admin@home] /system routerboard> upgrade
y
routerboard: yes
model: "750"
current-firmware: "2.32"
<... few minutes passed ... >
routerboard: yes
model: "750"
current-firmware: ""
<... some more minutes passed ... >
routerboard: yes
model: "750"
If I reboot the device I get 2.28 running on it.
struck
Re: RouterOS v5rc9
Thu Feb 10, 2011 3:28 pm
[Ticket#2011021066000502]
regards,
Adriano Struck
mihaimikrotik
Re: RouterOS v5rc9
Thu Feb 10, 2011 3:55 pm
A question about v5 features (btw I personally like the burst for PCQ and the gre for cisco compatibility):
In an article posted by Mikrotik (I do not have the link) it said that RouterOS supports 200 networks or aggregates in bgp announcement. Will this limitation be removed?
I haven't lost my mind, I have a tape back-up somewhere.
MTCNA, MTCRE, MTCTCE, MTCWE, MTCUME, MTCINE, MikroTik Trainer
normis
Re: RouterOS v5rc9
Thu Feb 10, 2011 3:56 pm
I don't know any such limits, where did you read it ?
exe
Re: RouterOS v5rc9
Thu Feb 10, 2011 4:01 pm
Struck,
Do you have problems with RX Drops like here: http://forum.mikrotik.com/viewtopic.php?f=3&t=38343
with that machine with 16 cores and 1500 PPPoE users?
Serbian Mikrotik Distributor - exeshop.rs
macgaiver
Re: RouterOS v5rc9
Thu Feb 10, 2011 4:05 pm
Struck,
16 real cores on 8 real cores with HT??? if 8 go to the BIOS and disable HT, RouterOS benefit more on that. Did you made your IRQ management?
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
exe
Re: RouterOS v5rc9
Thu Feb 10, 2011 4:14 pm
Yes it is better to disable HT, specially regarding rx drops.
Maybe 5.0 rc8 or rc9 can make better use of all cores ? Struck ?
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS v5rc9
Thu Feb 10, 2011 4:16 pm
IPSEC still no worky on RB1100. Works on RC7, but not 8 and 9. Doesnt matter really. Im sending it back.
struck
Re: RouterOS v5rc9
Thu Feb 10, 2011 4:17 pm
Struck,
I have no problem with RX drops on this machine, only PPPoE problems...
Adriano Struck
exe
Re: RouterOS v5rc9
Thu Feb 10, 2011 4:19 pm
Struck,
And what is the bandwidth on interfaces for this machine?
struck
Re: RouterOS v5rc9
Thu Feb 10, 2011 4:23 pm
Struck,
My machine is 8 real cores (2 processors Xeon 2.4Ghz quad core) and I don't made IRQ management.
Adriano Struck
struck
Re: RouterOS v5rc9
Thu Feb 10, 2011 4:24 pm
Struck,
Interfaces is 1Gbps full-duplex and the traffic is 75Mbps TX / 25Mbps RX.
Adriano Struck
exe
Re: RouterOS v5rc9
Thu Feb 10, 2011 4:29 pm
Yes, when you go up to 150M+ I am sure that you will notice "rx drops". But so far it is good.
jandafields
Re: RouterOS v5rc9
Thu Feb 10, 2011 5:14 pm
y
< ... reboot ... >
routerboard: yes
model: "750"
Same thing happened to me. I just kept trying it over and over and over. It finally stayed.
Stanislav Hrncir
Re: RouterOS v5rc9
Thu Feb 10, 2011 5:33 pm
With RC8 11n throughtput 227mbit UDP / 202 mbit tcp, with rc9 197mbit UDP / 163mbit TCP :?
fuzzbawl
Re: RouterOS v5rc9
Thu Feb 10, 2011 5:36 pm
Using Winbox, if I edit the last firewall rule in the list, then click OK or cancel, then double-click the rule again it will move itself to the top of the list. This is really bad if the rule that is last in the list is "drop everything". I am able to duplicate this every time in winbox on RC5 through RC9. I did notice that this only occurs if the list of firewall rules is longer than what can be displayed (so that there is a scroll bar). If the rule list is shorter so it fits in the Firewall window without scrolling, this issue does not occur.
uldis
Re: RouterOS v5rc9
Thu Feb 10, 2011 5:39 pm
how did you measure that?
What protocol, what boards used?
contact support and include detailed info with support output files.
NetworkPro
Re: RouterOS v5rc9
Thu Feb 10, 2011 5:58 pm
Hahah yes I have this problem as well. It happens very often over RDP session on a 1280x1024 resolution. I think I was running the latest WinBox exe Im not sure.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
WirelessRudy
Re: RouterOS v5rc9
Thu Feb 10, 2011 6:09 pm
802.11 40MHz links;
was introduced
- "station-bridge"? Is this a new kind of station? Never seen it before...
- what are these improvements fo r11n compatibility?
What about ros 4.16 NV2 package? Do we get an upgrade here as well? I use these and even I use some on a ´n´- link.
Are these upgrades helping on these links?
NetworkPro
Re: RouterOS v5rc9
Thu Feb 10, 2011 6:25 pm
Yes it seems this is a new feature introduced to the wide public with newsletter30.pdf:
http://wiki.mikrotik.com/wiki/Manual:Wi ... ion-bridge
marioclep
Trainer
Trainer
Re: RouterOS v5rc9
Thu Feb 10, 2011 7:52 pm
32GB RAM??? What does "/system resource" print?
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
mihaimikrotik
Re: RouterOS v5rc9
Thu Feb 10, 2011 8:29 pm
http://wiki.mikrotik.com/wiki/Manual:BG ... _routes.3F
If your don't have many routes to announce and want the best control over them, use BGP networks or aggregates. Note that both maximal BGP network and aggregate count is limited to 200.
Otherwise use route redistribution options, configurable under BGP instance settings.
Is this not a 200 advertisments limit? The problem is we advertise a lot of /32 routes so it suddenly jumps from some prefixes to almost 180 in our case. We cannot use redistribution, it is not a viable solution.
Professional
Re: RouterOS v5rc9
Thu Feb 10, 2011 10:50 pm
so which RB is working well with at least 2000 active L2TP connection? ()
normis
Re: RouterOS v5rc9
Fri Feb 11, 2011 7:24 am
Like I said, there is no such limitation, it must be some other problem
normis
Re: RouterOS v5rc9
Fri Feb 11, 2011 7:40 am
If anyone else is having trouble upgrading RouterBOOT, please send supout.rif files to support. Make sure you use rc9
shade
Re: RouterOS v5rc9
Fri Feb 11, 2011 8:36 am
I successfully announced about 800-900 dynamic routers on 5.0rc5.
Нерешаемых проблем нет — есть проблемы, которые никто не решает
normis
Re: RouterOS v5rc9
Fri Feb 11, 2011 8:58 am
Which OS are you using? I can repeat this problem on Windows7 but not if using Wine on Linux, or Windows XP.
mrz
Re: RouterOS v5rc9
Fri Feb 11, 2011 9:52 am
Please contact support and send them supout file from the router.
normis
Re: RouterOS v5rc9
Fri Feb 11, 2011 9:57 am
restore button is not missing, it's moved to "right click menu", so you don't accidentally click it.
uldis
Re: RouterOS v5rc9
Fri Feb 11, 2011 10:13 am
802.11 40MHz links;
was introduced
Compatibility for N: when Intel chipset clients and Macbook Broadcom chipset clients connects to Mikrotik N AP.
station-bridge mode is for Nv2 if you want to bridge wireless clients but do not want to use station-wds. More infor here:
normis
Re: RouterOS v5rc9
Fri Feb 11, 2011 10:37 am
We just tested 1550 connections, and some more are still connecting, no problems. And we have lower power server than you, so it's neither RouterOS nor hardware problem. Maybe peculiar configuration, or maybe problem is simply not there? maybe you simply don't have more than 1500 active users?
duvi
Re: RouterOS v5rc9
Fri Feb 11, 2011 10:44 am
Does this mean that Intel clients are finally able to use speeds higher than 54 Mbit/s for uplink?
mrz
Re: RouterOS v5rc9
Fri Feb 11, 2011 10:52 am
This limitation applies only to bgp network entry count and aggregate entry count. If you are redistributing routes from the routing table then there are no hardcoded limitations. If you have specific problem write to support with detailed description of the problem and attached supout file.
uldis
Re: RouterOS v5rc9
Fri Feb 11, 2011 11:55 am
correct.
mangust
Re: RouterOS v5rc9
Fri Feb 11, 2011 12:16 pm
"right click menu" ?? Can't find it there :(
normis
Re: RouterOS v5rc9
Fri Feb 11, 2011 12:21 pm
normis
Re: RouterOS v5rc9
Fri Feb 11, 2011 12:23 pm
and also here
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Fri Feb 11, 2011 12:45 pm
Upgrading from 4.16 to 5.0rc9:
In Wireless/Registrations, when client connects,
1) it (sometimes) only shows one value in Rx/Tx signal strength for a few minutes before both values are displayed.
2) for a few minutes, you cannot right-click and ping registration, it only try to ping ip 0.0.0.0. Leave it for a few minutes and it pings again.
3) If I ping it from Tools/ping and manually neter the ip, then it pings and I can ping it from registrations right-click again.
I'll send this to support as well.
Ekkas
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Fri Feb 11, 2011 12:50 pm
Voip issues with 5.0rc9 (upgraded from 4.16).
Although bandwidth tests and pings look ok, we are getting more and more calls coming in from clients on our wireless network that says either VoIP call quality is bad or that calls drop.
Anyone else have this?
On 4.16 all was fine, since upgrade this started.
I have almost 30 highsites and 200 MT CPEs, I'd hate to have to downgrade all of them, so if there is a quick fix or something, I'd be gratefull.
Ekkas
uldis
Re: RouterOS v5rc9
Fri Feb 11, 2011 12:57 pm
ekkas, try disabling compression.
Try to play with the hw-retries setting - lower or increase it.
Try disabling the adaptive-noise-immunity.
Norman
Re: RouterOS v5rc9
Fri Feb 11, 2011 1:16 pm
Any idea when you will support the standard SATA controller or USB in Dell Poweredge RX10 systems ?
We're having trouble in R210 and R310.
Tried CD installer and then also netinstall to USB memory card.
Both give the dreaded no hard drives found error and halts.
Tried emulating USB harddrive and setting to AUTO. Running multiple USB memory cards, nothing seems to help.
Would be good if the installer was a bit more verbose of the actual errors that the installer gets.
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Fri Feb 11, 2011 1:23 pm
Thanks Uldis,
On both AP & station?
...and, is it a temporary problem (fixed in later ROS5 release) or a permanent change?
Ekkas
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Fri Feb 11, 2011 2:23 pm
Major problem (for me) with 5.0rc9
Upgraded all highsites + clients.
Some (especially older RB133C3) connect, but can't ping.
If you MAC telnet to it it asks for UN/PW but then disconnect before you get the MT splash text.
Downgrade AP to 4.16, the client (RB133C3) is still on R5.0rc9 but now works fine, all clients connected again.
Ekkas
edit: It seems to be more of a problem on AP with PPC (RB333) than other.
NetworkPro
Re: RouterOS v5rc9
Fri Feb 11, 2011 3:37 pm
Ekkas
2) and 3) are normal behavior on low traffic times. Because the device that has connected and you see in registration table has not yet sent an IP packet revealing an IP address to ping.
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Fri Feb 11, 2011 5:21 pm
Don't have it on 4.16 though.
Also if the AP is 5.0rc9, then some (MT ROS 5.0rc9) clients wouldn't connect.
Downgrade to 4.16, all fine again.
nikolas
Re: RouterOS v5rc9
Fri Feb 11, 2011 8:31 pm
Torch is broken, when i double click the source ip to filter, Src. Address changes from 0.0.0.0/0 to 0.0.0.0 not the src ip.
here is a picture after i double clicked 10.10.23.4 on Src column:
Regards
chadd
Re: RouterOS v5rc9
Fri Feb 11, 2011 9:25 pm
Ekkas
What wireless mode are you running? 802.11?
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Fri Feb 11, 2011 9:32 pm
yes
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Fri Feb 11, 2011 10:45 pm
yes
Could it be that AP & clients was on 'unspecified' causing a problem. I would assume if 'unspecified' on AP is selected, it will default to 802.11?
mindragon
Re: RouterOS v5rc9
Sat Feb 12, 2011 2:14 am
Ekkas
Try making sure IP firewall service ports SIP is disabled.
VOIP over WiFi can be hard...
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Sat Feb 12, 2011 9:49 am
We do 1000s of VoIP calls a day for quite some time now.
Been through the learning curve. Paid the school fees.
The fact is that 4.16 works great, ROS 5.0rc9 still have major problems.
Also it seems the further the clients are from tower, the worse the problem is.
Also, the longer since last reboot, the slower far clients get. (Memory leak?)
I'd love to have ROS 100% taking in account that I just ordered 25 SXTs as a start for a NV2 network.
But I trust MT will find/fix the problem.
Only thing that concerns me is that noone else seem to experience this.
We had to downgrade all APs and busy downgrading CPEs as we get comments like :"These phones of yours is now crap!" lol
Ekkas
duvi
Re: RouterOS v5rc9
Sat Feb 12, 2011 10:08 am
correct.
Great! Can I expect it to be backported to v4?
petro25
Re: RouterOS v5rc9
Sat Feb 12, 2011 3:36 pm
VLAN after reboot doesn't work!!
You change number starts VLAN to work after reboot again doesn't work!
5RC9 (rb411,rb433 radio nstreme nv2 wds )
NetworkPro
Re: RouterOS v5rc9
Sat Feb 12, 2011 3:49 pm
I have experienced something similar or exactly the same, so I reconfigured the PtP link to Layer 3 instead of bridge-wds + VLAN.
petro25
Re: RouterOS v5rc9
Sat Feb 12, 2011 5:36 pm
As that not from a hand all to reconstruct
At me two flights on 70 km loading nearby 80 megabit. The processor is loaded on 80 % I think that ptp will kill him
VLAN nv2 station-bridge Doesn't work
If behind the bridge and in front of the bridge to put routers that VLAN passes
neandero
Re: RouterOS v5rc9
Sat Feb 12, 2011 6:49 pm
The log are filled within a minute - errors:
disconnected ok
connected
reassociating
these people are like 300 - 600 meters from the omni antenna and using 27db grid antenna.
when on 4.16, there was no problem at all with disconnected - reconnected, but RC9 is way beyond error disconnected.
@uldis
I did follow the above guide, but no help at all.
RB433 + R52Hn one chain.
hope for quick solution please...
petro25
Re: RouterOS v5rc9
Sat Feb 12, 2011 6:59 pm
Whether it is possible to add in following assemblages a variable on decrease in sensitivity of the receiver?? It is rather useful in зашумлёном an ether
chadd
Re: RouterOS v5rc9
Sat Feb 12, 2011 10:08 pm
yes
That is the problem, unless the MT guys have fixed it with the RC9 release the NV2 package won't run in 802.11 mode without the AP interface locking up after a random period of time. What happens is the AP will stop transmitting data, the clients stay in the registration table but you can't pass any data to them. If you disable/re-enable the AP interface the clients will come back and work normally for some random amount of time before the AP interface locks up again. This is a known issue and I am not sure why MT doesn't list it as a "known issue" in the release notes. For me it is 100% repeatable, if I run the NV2 package on any of my AP's in 802.11 mode they will stop working. The recommendation MT made was for me to swap my XR2 cards for a card with an N chipset. This doesn't seem to help though because there are others here who are having the same issue with the N cards.
It is definitely a problem with the AP side because you can leave NV2 package installed on the clients but roll the AP back to a version of the old wireless package and the problems go away. The last I heard from Uldis is that they were working on it but I haven't heard anything in several weeks. Is there any update on this Uldis?
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Sat Feb 12, 2011 11:57 pm
But to run a mixed Ubiquity/MT CPE network and ROS 5, what other option is there except 802.11?
Ekkas
chadd
Re: RouterOS v5rc9
Sun Feb 13, 2011 1:14 am
Ekkas
No there isn't. The only option you have is to roll back to V4.x and run the standard wireless package.
Ivoshiee
Re: RouterOS v5rc9
Sun Feb 13, 2011 7:18 am
yes
I have had similar issues with non-N wireless cards on my RB600A running 5.0betas. No NV or NV2 in use just a regular 802.11a/802.11b and in "any" mode. Only solution was to reboot the box as disabling/enabling the affected interface didn't do anything. Downgrade to 4.16 fixed that one for me.
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS v5rc9
Sun Feb 13, 2011 7:22 am
yes
FYI, I have been battling this problem at several locations with RB493AH/RB433AHs and R2n cards at several sites. Standard 802.11N, single chain, no extension channel. Even dropping down to G only doesnt fix it. The registrations are just locked and nobody can connect until the interface is stopped/started.
I just upgraded one of the sites to RC9 to see if that fixes it. But All the RCs so far have done this. I think it is only certain types of clients, but I dont know which ones. I havent ever had a problem in my office, even swapping the hardware with hardware that has exhibited the problem at a customer site. So Im leaning towards certain client cards. Non NV2, as a standard AP.
hajde
Re: RouterOS v5rc9
Sun Feb 13, 2011 3:42 pm
I also have same problem, without downgrade on 4.16 I can not solve it.
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Sun Feb 13, 2011 4:09 pm
I suspect it is distance related. Even with VoIP problems we have on 5.0rc9, the further the client, the worse the problem.
It also seems that further clients have higher probability to connect but not pass traffic.
All nearby clients have neither problem(bad VoIP call quality nor stale connection).
I suspect that is why same hardware in office setup would not show the same problem.
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS v5rc9
Sun Feb 13, 2011 4:48 pm
Well, when it happens, NO clients can connect. What kind of signal are you seeing when it happens, ill check.
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Sun Feb 13, 2011 4:58 pm
Seems like there are a few issues still unresolved.
I upgraded because I read it is final RC and my impression was that basic issues are resolved.
Problem is clients tend to remember a few hours or day offline, but doesn't remember the 24/7 reliability they've had the other 364 days. ;-)
I even have users that run permanent ping software and want discount for the hours they were offline in a month!
Damn 'users'. If only everyone was geeks... lol
Edit: I still think ROS 5 & NV2 will be fantastic once wrinkles are ironed out. Waiting in patient anticipation.
NetworkPro
Re: RouterOS v5rc9
Sun Feb 13, 2011 6:14 pm
Yes, I totally understand your point. End users are very demanding. And in turn, we also demand rock-solid networks to give them service with :)
Have you tried to convince with "good" those users who monitor with permanent ping, not to do it?
ekkas
Long time Member
Long time Member
Re: RouterOS v5rc9
Sun Feb 13, 2011 7:01 pm
PRoblems still with ROS5 is just on (some)wireless links?
So I can leave wired routers on ROS5 safely?
Got a few hotspot/usermanager routers that I'd hate to downgrade again.
chadd
Re: RouterOS v5rc9
Sun Feb 13, 2011 9:18 pm
It isn't a client problem it is an AP problem, as I mentioned you can leave the clients running the NV2 package in 802.11 mode and roll back the AP to 4.x or earlier with the standard wireless package and the problems go away. I gave MT support access to one of our AP's running 4.16 while it was in this locked up state they said the AP interface wasn't moving any data but didn't know why.
There are still some severe glaring issues with the new wireless package, especially with 802.11 mode. They have known of this issue for over a month now and still haven't resolved it. Why, I don't know but I do know they could save a lot of people a lot of time and frustration if they would just add it as a known issue until they can get it fixed.
On a side note I do have an AP that I have been running 4.16 in NV2 mode with a few clients on it that has been performing very well for the last month,. The caveat to running NV2 for me has been that clients have to have a SNR of at least 30db to avoid having issues with timing related disconnects. Even with an SNR of 25db clients will chain disconnect with timing error messages in the log. It seems like 30db is the magic number for some reason.
Skaught
Re: RouterOS v5rc9
Mon Feb 14, 2011 12:33 am
I have a 17km 5ghz link. I get near 100% ccq in A mode. Enabling any Mimo based modes drops ccq to <35% and I get lower throughput and connection drops.
The problem is, a 54mbit A mode link is too slow to handle the load I need and enabling mimo and extension channel makes it worse.
The Mimo capable cards will not do turbo mode.
NetworkPro
Re: RouterOS v5rc9
Mon Feb 14, 2011 12:41 am
Yes, Atheros f**ed us by not including turbo mode.
When you enabled the MIMO modes, what antennas did you use and how were they set up? Have toy tested each set of antennas with A mode?
fuzzbawl
Re: RouterOS v5rc9
Mon Feb 14, 2011 7:46 am
I am also using Windows 7. I also just tested on Mac OS X and Linux both with Wine and both seem fine. Problem only occurs in Windows 7.
mindragon
Re: RouterOS v5rc9
Mon Feb 14, 2011 8:23 am
I'm having stability issues with 5.0RC9 and a 493AH with one R52n using any mode (802.11, NV2 or anything in bridge mode) ... After about an hour or two it will lock up completely requiring a power off / power on. Anyone else having a stability issue?
uldis
Re: RouterOS v5rc9
Mon Feb 14, 2011 10:10 am
everyone who has problems with wireless in RouterOS v5.0rc9, please contact the support@mikrotik.com about it - include the support output file from RouterOS v5.0rc9.
For those that have problems with 802.11 protocol mode (isn't working in RouterOS v5.0rc9 and v4.16 with wireless-nv2 package) please check if the problem begins when client with a big distance connects, check if you remove form the registration table the situation improves. If you already downgraded your router to v4.16 regular wireless package, check if those clients that had big distance has also big ack-timeout values.
One fix/workaround would be to lower the hw-retries setting to 4 or 7 and check if the situation improves when those clients with big distance connects.
Please report with all that information to support.
uldis
Re: RouterOS v5rc9
Mon Feb 14, 2011 10:51 am
Just tested and it works in both cases if the Nv2 bridged interfaces passes Vlan traffic and also if the Vlan interface is on the wireless interface.
Please contact support about your problem.
mihaimikrotik
Re: RouterOS v5rc9
Mon Feb 14, 2011 1:45 pm
Is there no way to bypass this limit? As I was saying we cannot redistribute as the routes go into the bgp network entry count. Why is there such a limit?
Thank you.
mrz
Re: RouterOS v5rc9
Mon Feb 14, 2011 2:43 pm
I cannot imagine any setup where you would need more than 200 BGP network entries. Typically you have assigned one to two address block not hundreds.
mihaimikrotik
Re: RouterOS v5rc9
Mon Feb 14, 2011 3:48 pm
Well, is that a really a valid point for the limit?
In our case we announce /32 IP blocks from the network area. That is the setup, that is what we need, and that is why we do not use Cisco, but Mikrotik, as we have the flexibility to use scripting to our own interest, so it is automated by scripts. So if we have a /20 IP block and we get 100 IPs which have to be announced as /32 we suddenly get a +100 on the 200 maximal count. If we segment the /20 to /27 blocks, and we want to null route the gateway IPs without redistribution (as that WILL result in loops if IGP is involved) so they cannot be reached from the Internet, imagine that we already broke that 200 limit.
So, can't it simply be removed for flexibility of such setups?
saaremaa
Re: RouterOS v5rc9
Mon Feb 14, 2011 5:36 pm
When will function for the System Health Routeros x86?
CMDR Saaremaa (Gutamaya Sierra Alpha Alpha)
Ivoshiee
Re: RouterOS v5rc9
Mon Feb 14, 2011 5:43 pm
What does these settings should to do to eliminate total radio freeze?
My RB600A just had that wireless interface lockup (tried scanning for other APs and frequency scan, all returned "silence") running ROS 4.16 even without any clients connected to it nor likely not even attempting to do so, so that retry/ack-timeout/distance is likely not the root cause of it.
A suppout.rif file:
http://ra.vendomar.ee/~ivo/mikrotik/4.1 ... supout.rif
And the same system after reboot (wlan2 is working again):
uldis
Re: RouterOS v5rc9
Mon Feb 14, 2011 5:49 pm
Ivoshiee, please upgrade the Routerboard bios to v2.27.
Are you using RB604 board or RB502?
wlan2 wireless card failed to respond and also RouterOS wasn't able to reset the card. In which slot the wireless card is seated? As it looks more like hardware problem as it is also happening for you in v4.16 with regular wireless package.
alexspils
Re: RouterOS v5rc9
Mon Feb 14, 2011 6:14 pm
I have 7 x86 routers with different motherboards and health is running only on 4. Mikrotik says try to upgrade bios, but i cant do it now beacause it is production routers and i dont have replacement.one of them had showed health with 4.16 but after upgrade to 5rc9 system health show nothing
mars
Re: RouterOS v5rc9
Mon Feb 14, 2011 7:22 pm
we would like to know as well
looks like health only shows for old m/boards
honzam
Re: RouterOS v5rc9
Mon Feb 14, 2011 8:39 pm
RB532 - No routerboard info
LAN, FTTx, Wireless. ISP operator
gustkiller
Re: RouterOS v5rc9
Mon Feb 14, 2011 8:49 pm
the routing process crash / restart have been fixed?
the last version i tried was 5.0rc7 , on x86 the ospf / bgp process restart just after some ospf neighbor goes down, and the routerboard version mipsbe the routing process gets 100% and nevers came back..
Mikrotik Certified Consultant
ighnantaka
Re: RouterOS v5rc9
Mon Feb 14, 2011 9:06 pm
may be I'm off from the topic here,
but I do have problem with UserManager on v5.0rc9, i don't know its is a bug or just am miss setting something.
the major problem is, when i active the payment gateway (in this case i use paypal) and everytime the user try to buy
credit from me via paypal on user-manager and click purchase button and it proses to paypal account, the router/usermanager
automatically accept the user with status "started" even the payment not accepted yet (not approved yet) and the worse here
even the user not made any payment at all (not go to paypal to pay it bill, but just ignore it and get back to login page and login and enjoying internet in free). I already disable accept pending option on payment gateway setting. is anyone here have the same problem or it just me? could all you guys give me a hand here... T.T
i'm use RB750 | v5.0rc9
Ivoshiee
Re: RouterOS v5rc9
Tue Feb 15, 2011 8:03 am
Done that. Does older ROS work with newer firmwares and vice versa?
I have a RB502.
wlan1 and wlan2 are on that very same RB502.
What piece of hardware is to blame? RB600A, RB502, wireless cards, power, ...?
mrz
Re: RouterOS v5rc9
Tue Feb 15, 2011 9:45 am
Please contact support about this problem.
uldis
Re: RouterOS v5rc9
Tue Feb 15, 2011 10:18 am
I have a RB502.
please check if you have this fix on RB502:
http://forum.mikrotik.com/viewtopic.php ... 34#p218834
gustkiller
Re: RouterOS v5rc9
Tue Feb 15, 2011 1:07 pm
Ticket#2011021566000226
Ivoshiee
Re: RouterOS v5rc9
Tue Feb 15, 2011 5:38 pm
I have a RB502.
Interesting. I'll try to implement that fix and report back any improvements. Still, it does not explain my other RB433AH similar radio freeze issue under ROS 5.0betas.
neandero
Re: RouterOS v5rc9
Tue Feb 15, 2011 8:09 pm
ok, well, I rolled back to 4.16 but now my wireless card functions very weak!
Customers nearby that were -55 db is now -89 db, and card noise floor were -79 is now -51!
what might be wrong here?
I even did card "Reset Configuration"
Card is R52Hn
thanks,
chadd
Re: RouterOS v5rc9
Tue Feb 15, 2011 8:17 pm
Are you running the NV2 wireless package? If so do you have a noise floor threshold set?
Card is R52Hn
thanks,
neandero
Re: RouterOS v5rc9
Tue Feb 15, 2011 8:23 pm
No i ma not running "NV2 wireless", I tried to run it on 4.16, but again I got disconnect, reconnect problem so I left that and went to regular wireless package.
If I run the "NV2 wireless", the noise floor is like -90, but the regular wireless package is like -50. Total Noise!!!
wispwest
Re: RouterOS v5rc9
Wed Feb 16, 2011 6:42 am
That is really good throughput. Can I ask what setup you have? Our best link is at 270/270Mbps, with throughput of up to 150mbit. I have to use NV2 on that, because with regular Nstreme, it will only link at 65/65Mbps, even with 2 chains.
janisk
Re: RouterOS v5rc9
Thu Feb 17, 2011 10:35 am
small workaround for '/system ssh user% problem'
use
/system ssh <host or address> user<tab>
that way auto-completion will work correctly
Ivoshiee
Re: RouterOS v5rc9
Fri Feb 18, 2011 12:14 pm
I have a RB502.
I haven't managed to implement that fix yet, but now the affected interface is wlan4. I expect any RB502 issues not to affect any other interfaces not connected to it, so that RB502 is not to be blamed at this case.
Supout.rif files as well:
What is the official stance of MT about that issue? For me personally it is a showstopper bug. How to mitigate that issue?
uldis
Re: RouterOS v5rc9
Fri Feb 18, 2011 12:27 pm
first you need to implement that fix in order to use PCI correctly. After that test again.
Users browsing this forum: Google [Bot] and 48 guests
