MUM Europe 2020
arpadffy
ROS 5.0rc9 system reset problem
Sun Feb 13, 2011 11:40 pm
I experienced a strange problem.
After performing a system reset on a RB450G with 5.0.rc9 ether1-gateway is not able to get IP address by DHCP (that otherwise works OK)
Can anybody find from the attached full export what is the problem?
Thank you.
Regards,
Z
sergejs
Re: ROS 5.0rc9 system reset problem
Mon Feb 14, 2011 11:47 am
Configuration is fine, I do not see any problem.
Do you have established link on Ether1, when you check /interface ethernet monitor ethe1x?
arpadffy
Re: ROS 5.0rc9 system reset problem [solved]
Fri Feb 18, 2011 12:24 am
you had right. The reset is OK... once I tested on another uplink (read ISP) worked perfect.
Thank you.
Regards,
Z
Users browsing this forum: ebbarkj and 26 guests
