MUM Europe 2020
el berto
Creating network indoor: simple antenna or cable?
Mon Feb 14, 2011 6:44 pm
Hi, I would like to make an indoor network for test.
Let's image this would be my future network (using routerboards instead PCs):
I would like make this network indoor, so I would ask this:
1) can I use a piece of wire as antenna (I think use 14 dB antenna in a room is not suitable)?
should I set some particular configuration to use several antennas in a room?
2) if I connect directly the n connectors through cable and I set the tx power to 0, would I damage pci radio modules?
Thanks.
rodolfo
Long time Member
Long time Member
Re: Creating network indoor: simple antenna or cable?
Mon Feb 14, 2011 11:26 pm
you must connect your pc (or routerboard eth) to a revolutionary new device, called switch :lol:
rodolfo
IZ0UQV
el berto
Tue Mar 01, 2011 6:38 pm
Sorry, I'm not explained: this would be a future wireless network, but I have to test it indoors.
I haven't enough antennas for indoor (I have only 18 dB panels).
Users browsing this forum: No registered users and 17 guests
