alfagius
[Solved] Expired user-manager users.
Thu Mar 03, 2011 11:26 am
Looked for his around forum but didn't manage to find anything about it.
Once an activated account is over its validity period, is it automatically removed from the userlist?
My issue is, I create around 200+ users a week on the system (it's a hotel) and I don't want to end up clocking 1000's of expired users.
If not, is there an easy way to clear them manually?
Thanks.
usmany
Re: Expired users
Tue Mar 08, 2011 5:11 pm
Thanks.
I am searching for same answer from the mikrotik gurus on how to automatically delete old/expired users account from database.
When the world turn back on you, you turn your back on the world...
alfagius
Re: Expired users
Wed Mar 30, 2011 4:08 pm
nothing from anybody?? :(
marioclep
Trainer
Trainer
Re: Expired users
Thu Mar 31, 2011 4:31 pm
When do you consider an account has reached the validity period? If it is by uptime, or some of the statics of the HotSpot User, then you can use some script to find those users who has reached those limits, and delete them automatically.
Regards
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
usmany
Re: Expired users
Thu Mar 31, 2011 5:51 pm
Regards
so how can we use the script and what is the script or look like (syntax) pls
fewi
Re: Expired users
Thu Mar 31, 2011 6:00 pm
That depends on your answers to his questions...
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
usmany
Re: Expired users
Thu Mar 31, 2011 6:03 pm
his question? we consider it by uptime of 3d period.
marioclep
Trainer
Trainer
Re: Expired users
Thu Mar 31, 2011 6:58 pm
I'm not expert in scripting, but you may need something which contains "rem [find (uptime=3d)]", under /ip hotspot users... (please scripting experts, forgive my syntax, Im just making the point)
Ing. Mario D. Clep
CTO - MKE Solutions
sleimanr
Re: Expired users
Sun Apr 03, 2011 1:48 am
hi all,
i'm using pppoe.
routik
Re: Expired users
Wed Jun 01, 2011 11:38 am
the solution of scripts that will be deleting expired/uptime tickets have not been provided. please i need it as well.
I enjoy building broadband network with @Mikrotik
alfagius
Re: Expired users
Thu Jun 02, 2011 2:59 pm
I have figured it out finally after a day of banging my head on the keyboard.
Working on a lengthy script that removes any user whos credit-till-time is less than today's date.
Still ironing out a few bugs, but will post it as soon as it's 100% working. :D
alfagius
Re: Expired users
Fri Jun 03, 2011 2:06 pm
And here you go.
Script finished and tested. Posted on the Scripting section for whoever needs it: http://forum.mikrotik.com/viewtopic.php?f=9&t=52261
Please note that this applies for users in the user-manager package database, not standard Mikrotik hotspot user lists.
nepal
Re: [Solved] Expired user-manager users.
Thu Apr 11, 2013 10:49 am
might be useful
:foreach a in=[/tool user-manager user find] do={:if ([/tool user-manager user get $a credit-left]=0s) do={
:log warning ("deleted Expired user.. $[/tool user-manager user get $a name]")
/tool user-manager user remove [/tool user-manager user get $a name]
gtpro
Fri Apr 12, 2013 2:49 am
If Nepals script does not work try this
Tested on version 5.24
:foreach i in=[/tool user-manager user find] do={:if ([/tool user-manager user get $i uptime-used]= 1h) do={
:log warning ("deleted Expired user.. $[/tool user-manager user get $i name]")
/tool user-manager user remove [/tool user-manager user get $i name]
It works for me deleting users with the uptime limit reached.
leemans
Sun May 12, 2013 2:24 pm
Dear Newbie,
Can you update your script that it can work with these parameters?
last-seen is < today
and Uptime-Used>0
and Till-time=Unknown
and Total-Time-Left=""
and Time-Left=""
Thanks in advance.
Patrick
Users browsing this forum: No registered users and 3 guests
