MUM Europe 2020
proweb
How to Upgrade without Buy Again and again...
Tue Oct 18, 2005 1:02 am
I have lincese for Mikrotik 2.8.6 with 6 level key but 3 months ago (2003) i Buy Mikrotik 2.8.9 with lv 2 key.(2004)
Now new Mikrotik with 2.9.6...How can so fast...
how the way, i upgrade my mikrotik without payment anymore. Thanks
mfennell
Tue Oct 18, 2005 2:33 am
I think you get a free updates for a year after you purchase your license. Generally upgrades are fairly easy and painless, but you may have a few issues going from 2.8 to 2.9.
Go to the downloads page and choose the appropriate software for your needs. Make sure you get the correct package for your hardware.
proweb
What should I do after I install Mikrotik 2.9.6 without ....
Tue Oct 18, 2005 5:34 am
What should I do after I install Mikrotik 2.9.6 without ....License Mikrotik
Bro..i had download img 2.9.6. Now tonight i want to install this program, so how bout to upgrade my license?? I still don't get it....after I install my program, what should I do>???
Please help me...
normis
Tue Oct 18, 2005 9:53 am
simply upgrade the 2.8 software to 2.9 software. to upgrade the software version, upload the new NPK packages to the router with FTP and then reboot the router. it will be upgraded.
you do not need to buy a new license!
by the way, 2.8.9 was released in April 2004, which is 1.5 years ago. It is not `fast`
lastguru
Trainer
Trainer
Tue Oct 18, 2005 1:15 pm
well, if it was 1.5 years ago, then he might need to extend his license, as it was probably was bought with upgrade term of a year
International MikroTik Certified Trainer and Consultant form Latvia.
I do RouterOS Training and Certification worldwide!
skype: lastguru
normis
Tue Oct 18, 2005 1:23 pm
if he `bought` it recently, maybe he has a new license. if not - why did he say he paid something ?
anyway - check what you have in `/system license print`
proweb
tonight I'll try to upgrade it
Tue Oct 18, 2005 4:16 pm
bro my system license until :
upgradable-until: jun/01/2006
level: 6
features: AP,syncrhonous,radiolan,wireless,extra-channels
So i can upgrade my OS Mikrotik without payment anymore...Okay tonight I'll try it. Thanks man
normis
Tue Oct 18, 2005 4:24 pm
won't work. write to support@mikrotik.com and I will tell you why
proweb
Please help me for upgrade Mikrotik from ftp
Tue Oct 18, 2005 4:39 pm
After i upload all file npk like the picture above, what should I do?
I had restart my server. But it dosn't change anythink....
Please guide me for the tutrial to upgrade...
To be honest I really thank full for all tutor from this FORUM. Cool....the best Forum
normis
Tue Oct 18, 2005 4:45 pm
picture doesn't show. what does it say?
i already told you it won't work, write to support
proweb
Please help me for upgrade Mikrotik from ftp part II
Tue Oct 18, 2005 5:06 pm
I really confused....please give me support tutor for it. I really stress now....
normis
Fri Oct 21, 2005 11:52 am
write to support@mikrotik.com please
cabana
Fri Oct 21, 2005 2:32 pm
By the look of it, when you uploaded the files the names got changed. For example on your system you have SYSTEM_2.NPK when in fact it should be system-2.9.5.npk, and ROUTING_.NPK should be routing-2.9.5.npk etc
If I were you I would delete all the files that relate to upgrading in your router and upload them again making sure that the names are correct, then when you reboot they should be recognised
normis
Fri Oct 21, 2005 2:35 pm
use normal FTP client
Users browsing this forum: No registered users and 100 guests
