Mashimoto
[Solved] NE1 have success with MT Userman + Open-mesh OM1Ps?
Mon Mar 07, 2011 8:48 pm
I'm currently having trouble with the OM1P as it's redirecting traffic to the login page, but nothing shows up and then it reloads and reloads and reloads...
I got the setup working for 1 day, then it took down the whole hotspot setup to where the server couldn't be found. I had to system reset and restore a backup, but I'm in a foreign country where I can't buy replacements and all I have are these OM1Ps that aren't working just right all the time.
For it to be working for a day, means that it can work, just need to figure out how. Any suggestions? Anyone?
Mashimoto
Re: [Solved] NE1 have success with MT Userman + Open-mesh OM
Fri Mar 11, 2011 4:02 pm
with current stable firmware something was messing up with the open-mesh device doing it's own NAT/DHCP, so to let MT do it:
1) flash open-mesh device with beta-ng firmware r277
2) under advanced uncheck Gateway LAN block
3) SSID#2: check enable + check bridge
4) IP --> Hotspot --> walled garden list --> dst. host = add "dev.open-mesh" --> dst. port = 80
5) IP --> Hotspot --> walled garden list --> dst. host = add "checkin.open-mesh" --> dst. port = 80
