normis
Dude v4beta3 released
Tue Mar 08, 2011 11:16 am
*) fixed static object crash
*) changed icon
*) some minor fixes
http://www.mikrotik.com/thedude.php
Sandor1k
Re: Dude v4beta3 released
Tue Mar 08, 2011 2:56 pm
Good day! Still not updated charts through a Web page in one session!
tudorik
Tue Mar 08, 2011 4:41 pm
Any chance to be able to specify a different RouterOS port for monitoring Mikrotik devices?
lebowski
Tue Mar 08, 2011 5:20 pm
4b3 observations - Backup your dude folder before upgrading. Upgrade was smooth as usual.
As noted FIXED - If you click "add static" the dude no longer crashes.
Not Fixed - The remove resolved button on the outages tab of services doesn't remove resolved outages.
Other Features
1) Exporting a backup stops the polling process, any probes that time out while the export is being done will appear down soon after the export has finished.
2)Select a device then click the copy button all the history will be erased and graphs will be gone.
3)On the probe panel select a probe then click the copy button, the probe XML will include all the devices it is installed on.
NOTE: Care should be taken to remove the unneeded XML when copying and pasting or sharing probes through XML.
Still nothing to worry about KEEP up the great work!
MICPROF
Tue Mar 08, 2011 5:40 pm
any update about monitor network , and show usage graph for mikrotik ...
Thanks!
Best Regards.
If my answer helped you and my question good too, please give me karma
eivind
Wed Mar 09, 2011 7:22 pm
Some probes shown as "not available" in device services. New Function probe has a default text Available=1, Value=2+2.
If I delete the old probe and makes a new similar one it will work, but it gives me a lot to do... Fix in a hurry??
EMOziko
Thu Mar 10, 2011 12:33 am
Waiting for next release! thanks!
We want new versions of The Dude!!!!!!!
lebowski
Thu Mar 10, 2011 12:35 am
@eivind Don't delete the old probe. Wait at least 6 minutes to see if the old probe starts working.
"not available" can mean that the previous SNMP read did not work that would cause a "false positive". If the previous read did not work then the probe will not work for 5 minutes or more specifically the amount of time that is set in Negative Cache time of the function that grabs the OID. The default of which is 300 seconds.
You can modify the Negative Cache time but it takes a bit of work by modifying every function. If you do make it lower your false positives will not be 5 minutes long.
I hope that makes sense,
Lebowski
eivind
Thu Mar 10, 2011 11:51 am
Thanks Lebowski, I know. Some faulty probes did come up after five minutes. I did a test by making one new identical probe with a different name. It did work, but the old ones who has been OK since beta 2 arrived still don't work after 24 hurs. I'm testing if it is available with "function() >0" and have other probes who is working fine with exactly the same test on a close to identical function. I tried to set "" in the test but it still did'nt work. There might be a communication problem between functions and probes. As one said in this forum; It's a dangerous life to always use latest version, but since the Dude is free of charge I'm not complaining, just telling :-)
lebowski
Thu Mar 10, 2011 4:50 pm
"function() >=0" In version 4b3 the "Available" line is less forgiving.
If you take the probe that doesn't work and add one to the value that is being read the probe comes up but it will never appear down. I have solved this for my self by following gsandul's example of a function that returns "False" or a value and a probe with two if statements.
Function: if(array_size(oid_column("1.3.6.1.4.1.9.2.1.57", 10 ,29)), oid("1.3.6.1.4.1.9.2.1.57.0", 10, 29)+1 ,"False")
If the oid is available read the value and add one to it otherwise return false.
Probe: if(Cisco_CPU_a()<>"False",if(Cisco_CPU_a() -1< 70, "", concatenate("Warning: high CPU = ", Cisco_CPU_a(), "%")), "Cisco Device down")
If the value is not "False" subtract 1 from it make sure the value is less than 70 or complain about high CPU, If the value is False return "Cisco Device Down".
slech
Long time Member
Long time Member
Thu Mar 10, 2011 10:08 pm
sorry for my english
eivind
Sat Mar 12, 2011 3:24 pm
Solved it the easiest way! Migrating this formula into gsandul's solution would give me a real challenge:
Uncorrectables x 100 / (Unerroreds + Correcteds + Uncorrectables)
(oid("1.3.6.1.2.1.10.127.1.1.4.1.4.3")*100)/
(oid("1.3.6.1.2.1.10.127.1.1.4.1.2.3")+(oid("1.3.6.1.2.1.10.127.1.1.4.1.3.3"))+(oid("1.3.6.1.2.1.10.127.1.1.4.1.4.3")))+0.001
Maybe not the smartest way of doing it, but it does the job.
Because Dude don't graph under errors I have chosen to make a separate probe for "Data Correction Too High" , and using another single oid probe for down statement for the devices.
I'm trying as hard as I can to keep my networking knowledge at a minimum, and give myself more time to run my business.
Thank You for Your inputs :-)
mdaitc
Sat Mar 12, 2011 11:00 pm
is it released for PPC (RB1100)? - seems like only beta1 files are posted on the site.
If not, then is there an ETA (can you let us know what the issue is?)
thanks,
caterpillar
Wed Mar 16, 2011 9:41 am
Hi! I have some backup problems, after updating my dude from v3.6 to 4beta, 4beta2 and 4beta3. when i do backup (using dude client) dude server terminate my connection, and all connections from other users. Dude client runs on windows vista and windows xp...
lebowski
Wed Mar 16, 2011 3:25 pm
@caterpillar, The backup is taking too long to export, lower your raw keep time to make sure dude.db doesn't get bigger than 2GB. Use copy to make a backup of your dude folder for now. Hopefully they fix both the 2GB limit and the issue with IO affecting polling soon.
miahac
Long time Member
Long time Member
Mon Mar 28, 2011 3:05 am
Still no elbows in links?
Network Consultant in Wichita, KS
blackpaw
Wed Mar 30, 2011 6:03 pm
I use the "network" element without any data (creates a small yellow cloud that you can use as "elbow" (if you mean this...)
I am also having the "Not Available" services sometimes now... wonder what got changed, there...
Andreas
life is one of the hardest
blackpaw
For Lebowski: Re: Dude v4beta3 released
Fri Apr 01, 2011 4:48 pm
Lebowski, I would like to discuss using (partial) snmpwalks in functions.. as I am having severe CPU issues here.
Can we fork a new thread to discuss this, please?
My approach for a sanity-check in a function is:
never mind that, it doesn not work
Andreas
mramos
Sun Apr 03, 2011 4:21 pm
Hi ...
I went from 4b2 to 4b3 some days ago, no issues to upgrade.
Spent some weeks playing with ROS 5RC11, 5RC12 and now settle on 5.0.
My system is small, e.g. a 433UAH, a pair of 411ARs, 3 old WRAP X86, all loaded with ROS5.0 now. Around 70 CPEs (NS2 Loco & Bullet 2). There is 3 XR9 for NLOS path.
* Any card that run as client-bridge (R52Hn, XR9, R52n), after this double upgrade to 4B3 x ROS 5.0 missed the speed/signals levels at the labels. On the other side, if I create a link between any UBNT client and AP still showing signals levels (tx/rx), connection speed & etc. At the MT devices, does not matter if mastering is snmp or routeros. Just data speed shows up.
* Torch avialable at mouse over link lables + right click does not run.
* I'm using Dude to collect & graph some data volume info, as measured by "bytes" field on queue tree. Those queues are common low priority (priority=8) channels I set to those traffic which customers does not realize about, like Windows Update, several anti-virus update, adobe update, etc ... and Youtube/4shared. Each uses pcq and a max limit so customers share those channels. I expected a monthly basis graph, reseting all counters after 30 days by myself - but - most are reseting when the volume reaches 4.1 ... 4.3 GBytes. I guess this is not Dude related but ROS. Anyway.
PS: not Dude but 5.0 winbox ... torch on simple queues (mouse over a simple queue line) is not running too, the source address filter field on torch is not being filled with simple queue target address, as used to be on ros 4.17.
Regards
Marcus Ramos
Electronics Technician
(Microwave HW, RF, antennas, propagation)
S.Paulo - Brazil
phendry
Thu Apr 07, 2011 3:09 pm
So the 2GB DB size limit hasn't been fixed in this release? Has anyone confirmed this and have Mikrotik acknowledged this bug? This is the only thing preventing us upgrading from 3.6.
ARTUR
Sat Apr 09, 2011 6:41 pm
Lebowski, Thanks a lot for the software. I have used the software for 3 years and i like it.
I just upgrade to release 4, and
I have had some problems with the Outage Report, because doesn´t appear in the web page and in the left hand tree.
Perhaps because it is beta version but there are things missing like the snmpwalk to print or export to a file.
Best Regards
Fernando A
lebowski
Mon Apr 11, 2011 9:09 pm
I didn't write it :) mikrotik did.
craigmyster
Thu Apr 14, 2011 3:37 am
I run dude on routeros. My backups are not working as of Version 4.0. Is there a work around to get the backup to work? I don't want to risk loosing all the data.
Xymelin
Thu Apr 14, 2011 12:42 pm
I also use dude on RouterOS to monitor my network with ~ 3000 devices and I can't perform an export :? Maybe Mikrotik support can give some piece of advice how to export Dude.
mpaluck
Tue Apr 19, 2011 1:18 am
My functions don't seem to be working on 4.3 any thoughts?
maxrate
Thu Apr 28, 2011 10:38 pm
Could v4beta4 have support for the RB1000/RB1100 + Authenticated Email Support please? This is very important to us
Mikrotik everywhere!
normis
Fri Apr 29, 2011 7:58 am
what do you mean by RB1000/RB1100 support?
mdaitc
Fri Apr 29, 2011 2:36 pm
i'd imagine so that the PPC version of The Dude will run on the RB1100
normis
Fri Apr 29, 2011 2:38 pm
I see, you meant the RouterOS npk package. Yes, currently there is a problem with it.
iam8up
Mon May 16, 2011 8:38 pm
Not being able to back up is VERY MUCH something to worry about.
craigmyster
Wed May 25, 2011 4:23 pm
Is there any way to backup my graphs. I have many years worth of data in trouble now if something happens.
troy
Wed Jun 08, 2011 5:03 pm
When upgrading from b2 to b3, the server side went pretty well, though the service was not restarted when the installation was complete, but at the same time, "the dude server" wasn't even in the services list. I had to run dude.exe as administrator to get the service running again.
On my workstation, when I ran The Dude again, it asked if I wanted to upgrade, I said yes. It downloaded everything, but then crapped out because it couldn't copy dude.exe.
Why not use a loader similar to Winbox so that the main binary can be upgraded from the server when the server is upgraded?
maxrate
Wed Jun 08, 2011 5:05 pm
I had a smiliar issue and was unable to rectify it unfortunately.
genPSI
Thu Jun 16, 2011 7:38 pm
Please resolve problems with backups :(
I am so waiting for 4 beta 4 =)
slech
Long time Member
Long time Member
Tue Aug 02, 2011 10:01 am
Note: v4beta3 PPC package is currently not working
Any plan for this ?
ITG
Tue Aug 16, 2011 11:26 pm
When you get a network map that's "stuck" loading like that, create a second map. If the second map works, delete the first.
ottoshr
Thu Aug 25, 2011 1:44 pm
I see BIG Outage problems:
1)couldn't find remove selected outage button, this means can't delete several outage only all
2)couldn't find add note to outage !!! for later review of current outage
3)after restore several outage is not change state to resolved but service is working - how to remove outage to normal state - resolved ? tried - reboot , delete service and run again , the same problem... see picture - ????!!!!
ottoshr
Fri Aug 26, 2011 12:46 pm
please help nothing changed still got these hanged outages... tried remove all , no response, removel all outage in each device trough decie settings only removes outages for this device, but these hangs are still active. try once more make backup and restore - the same. restarts many time OS and dude server - still the same...
is there possible to correct something directly into database sqlite3 ?
ottoshr
Fri Aug 26, 2011 12:58 pm
4)also tried delete device with service and as you can see still got - active outage !
ottoshr
Tue Aug 30, 2011 11:20 am
becouse no one is helping in this trouble, i try to d something i can. by the way remove resolved also didn't do anything in my case.
I download several sqlite3 tools and try to delete in table outages rows where status is 1, but this 10 rows that are stuck also can't delete in that way (delete from outages where status=1), several other outages where removed but not these.
after i truncate all table outages, - this process take several hours and after commit table was almost empty.
after copying to dude/data. and start dude 403 with crossed fingers ... and problem was solved, stucked outages doesn't showed again.
in sqlite3 tools see some message that these stucked records is with missing constraint...
lebowski
Tue Aug 30, 2011 7:49 pm
Good work Ottoshr! I had nothing!
ottoshr
Wed Aug 31, 2011 9:54 am
yes thanx sounds fine ... BUT anyway i had a some problem with database or table ... after restarting dude i see that only few outages are written in table !!!
WHAT should i do ??? i have around 200-300 services configured in dude and since in 4.0 version beta 3 is no XML backup how to move my services configuration to new database (if this is failed) ?
OR maybe someone new how to repair this sqlite3 dude database ? i try scnadisk, defrag and all report no errors or problem.
dude is strting fine, but even after i removed all messages from outages sometimes when i switch to outage it take about 60sek or more to show records...
Please help if someoine got ideas !!!! i don't want to create new services :) once again !
Problem is repaeating a got new outage that is pinging, but outage did not change state to resolved !!! how to change this situation!!!
ottoshr
Wed Aug 31, 2011 2:46 pm
Also there is something with memmory usage below 2 images before and after dude server restart, once more after restart server lost some outages records , and memmory usage is minimised.
use server as service. windows 7 on citrix virtualisation.
normis
Wed Aug 31, 2011 2:47 pm
do you use v4b3? how many maps and devices do you have?
ottoshr
Wed Aug 31, 2011 2:50 pm
yes dude 4.0 beta 3
29 maps, aprox 200-300 devices, donn't know how to calculate in dude
normis
Wed Aug 31, 2011 2:51 pm
in that case, that's normal, buy more RAM
ottoshr
Wed Aug 31, 2011 3:22 pm
but why use of memory when started use minimal and start increasing with usage? could you explain how memmory and maps and device count is connected ?
could you please help me with outage problems - that i describe above?
normis
Wed Aug 31, 2011 3:24 pm
all charts and graphs and polling results are stored in the ram, and saved periodically (can configure how often). when you restart the dude, it reads the previous status from the files, and then starts gathering new data, which it stores in RAM until it's time to save it. the more devices you have, the quicker this data grows in RAM.
ottoshr
Wed Aug 31, 2011 5:02 pm
can you help me repair database? or migrate to new one without data gathering but with all devices and settings !?
also data gathered saves only few records - how it is possible ? but for example saves new devices and etc...
phendry
Wed Aug 31, 2011 7:25 pm
Database size issue is something many of us have been waiting for Mikrotik to resolve. For now we have to restrict the usefulness of the Dude when it could have been so much more :(
normis
Thu Sep 01, 2011 8:49 am
To reduce the db file size you should open the dude.db file with sqlite3 and do "vacuum;" query. Dude server must not be using that dude.db file at that time.
ottoshr
Thu Sep 01, 2011 12:43 pm
i 'm not sure that problem is with database size, in my case it looks like something happen'd wit database itself, maybe problem with storage where it is stored or something like that. But some records ar commited and some are not - in result memory usage is growing and after dude service restart lot of information are missing ! If this was only outages it was not so big problem but yesterday i catch a problem that new device also is missing after restart.
today try to move windows 7 image to local storage to see whats will be next !
Mikrotik or any else DUDE programmers please help us - with what tool i can repair dude sqlite3 database ? or i need repar integrity or compact database ?
ottoshr
Thu Sep 01, 2011 1:13 pm
ok, i try do this but i got error when try launch vacuum.
Normis what tool do you recommend for vacuum sqlite dude database ?
normis
Thu Sep 01, 2011 1:24 pm
sqlite3
ottoshr
Thu Sep 01, 2011 1:56 pm
:) i run sqlitemon 1.2.2 and got error when try to vacuum, could you please give a name of proper utility ?
normis
Thu Sep 01, 2011 2:03 pm
ottoshr
Thu Sep 01, 2011 6:25 pm
1) I UNDERSTUD PROBLEM it was table chart_values_raw;
2)try to delete content didn't help get error see attachment pic.
3)please explain how to run vacuum into comand line shell ?
4)try backup restore - it helps - table now i can open , but when i copied it to dude directory and run dude it delete all info to default values !!!
what should i do next, - bu the way how tu run vacuum in comand line shell ? i found command to set vacuum auto for all database...
also table error from comand line shell
sqlite> .tables
chart_values_10min chart_values_2hour objs
chart_values_1day chart_values_raw outages
sqlite> delete from outages ;
sqlite> delete from chart_values_raw ;
Error: database disk image is malformed
lebowski
Fri Sep 02, 2011 12:45 am
The easy to vacuum the database is to put dude.db and sqlite3.exe in the same folder then make a shortcut to sqlite3.exe, edit the properties of the shortcut so that dude.db is on the command line.
"C:\Documents and Settings\person\Desktop\sqlite3.exe" dude.db
Then double click the shortcut, type VACUUM; A journal file will be created while it is vacuuming... I think that is how, it is still running ;)
craigmyster
Fri Sep 02, 2011 2:30 pm
please please please fix backups for dude running on routeros. no backups done for me for months now.....
lebowski
Tue Sep 06, 2011 4:27 pm
Just fyi, my 1.6GB database took a couple hours to vacuum and is 900MB now but I did have the chart values set fairly high. I didn't start using the vacuumed database since I was just testing.
ottoshr
Tue Sep 06, 2011 4:43 pm
Please help me to export from sqlite3 table objs, where is all dude403 devices and settings, becouse i coldnt repair this database file , after cleening broken table and starting dude it cleans all records to default empty without devicesw and settings !!!
ottoshr
Thu Sep 08, 2011 1:45 pm
last corupted table 403 problem update , problem still not solved
C:\>sqlite3 "c:\program files\dude\data\dude.db"
SQLite version 3.7.7.1 2011-06-28 17:39:05
Enter ".help" for instructions
Enter SQL statements terminated with a ";"
sqlite> .databases
seq name file
0 main c:\program files\dude\data\dude.db
sqlite> .tables
sqlite> vacuum;
Error: PRIMARY KEY must be unique
sqlite> pragma integrity_check;
*** in database main ***
Main freelist: freelist leaf count too big on page 108379
Main freelist: invalid page number 218103808
On tree page 68452 cell 1: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 2: Rowid 0 out of order (previous was 2)
On tree page 68452 cell 5: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 6: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 7: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 8: Rowid 1 out of order (previous was 2)
On tree page 68452 cell 9: Rowid 1 out of order (previous was 1)
On tree page 68452 cell 11: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 12: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 13: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 14: Rowid 1 out of order (previous was 2)
On tree page 68452 cell 16: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 17: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 18: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 19: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 20: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 21: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 22: Rowid 1 out of order (previous was 2)
On tree page 68452 cell 24: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 25: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 26: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 27: Rowid 1 out of order (previous was 2)
On tree page 68452 cell 29: Rowid 0 out of order (previous was 2)
On tree page 68452 cell 31: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 32: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 33: Rowid 0 out of order (previous was 2)
On tree page 68452 cell 35: Rowid 2 out of order (previous was 2)
On tree page 68452 cell 72: Rowid 2 out of order (min less than parent min of 59
793659835144416)
On tree page 113323 cell 7: Rowid 60868063085036800 out of order (previous was 6
0899974691124480)
On tree page 58393 cell 63: Rowid 56361418325717216 out of order (min less than
parent min of 60899974691124480)
On tree page 113323 cell 23: Rowid 27965680134882677 out of order (previous was
60900030525800128)
On tree page 66272 cell 59: Rowid 27965680134882086 out of order (min less than
parent min of 60900030525800128)
On tree page 88058 cell 3: Rowid 49101592155516140 out of order (previous was 49
101592155516450)
On tree page 126676 cell 41: Rowid 34986796317645888 out of order (previous was
61135222934943488)
On tree page 58741 cell 55: Rowid 34986796317645338 out of order (min less than
parent min of 61135222934943488)
On tree page 6049 cell 62: Rowid 58599431294956533 out of order (max larger than
parent max of 9521398349263808)
On tree page 6133 cell 62: Rowid 9521398349264408 out of order (min less than pa
rent min of 58599431294956533)
On tree page 3889 cell 52: Rowid 30248670001075934 out of order (previous was 50
190778682110296)
On tree page 3245 cell 16: Rowid 30248670001075809 out of order (previous was 50
194639857520400)
On tree page 41634 cell 62: Rowid 49746601754770593 out of order (min less than
parent min of 53325924420004264)
On tree page 4481 cell 1: Rowid 227415537619785 out of order (previous was 13210
38765146936)
On tree page 1591 cell 2: Rowid 227415537618785 out of order (previous was 13210
38765146946)
On tree page 4482 cell 29: Rowid 1321038765234770 out of order (previous was 132
1038765263305)
On tree page 33382 cell 42: Rowid 1321038765234655 out of order (previous was 13
21399542401710)
On tree page 4482 cell 31: Rowid 1321038765234360 out of order (previous was 132
1038765264713)
On tree page 177053 cell 5: Rowid 1321038765232758 out of order (previous was 13
21399542401379)
On tree page 151854 cell 56: Rowid 9424856073867323 out of order (max larger tha
n parent max of 1321038765322350)
On tree page 138459 cell 43: Rowid 1321038765322355 out of order (min less than
parent min of 9424856073867323)
On tree page 6090 cell 62: Rowid 1321038765596042 out of order (previous was 132
1038765596047)
On tree page 27078 cell 23: Rowid 1321399542866598 out of order (previous was 13
21399542866959)
On tree page 4416 cell 5: Rowid 1335113285201290 out of order (previous was 1335
113285201290)
On tree page 4416 cell 6: Rowid 1321399542864216 out of order (previous was 1335
113285201290)
On tree page 85919 cell 45: Rowid 1335113285201290 out of order (previous was 13
35113285201290)
On tree page 2028 cell 32: Rowid 7797471490759408 out of order (previous was 779
7471490786364)
On tree page 8236 cell 49: Rowid 7797471490841712 out of order (previous was 779
7686239125544)
On tree page 8256 cell 22: Rowid 7797471490841862 out of order (previous was 779
7471490856808)
On tree page 28524 cell 2: Rowid 7797686239129265 out of order (previous was 779
7686239151014)
On tree page 1901 cell 1: Rowid 7797686239126110 out of order (previous was 7797
686239151015)
On tree page 51485 cell 17: Rowid 7798785750751887 out of order (previous was 77
98785750778867)
On tree page 139341 cell 8: Rowid 60899974692101724 out of order (previous was 6
0899974692101944)
On tree page 139341 cell 17: Rowid 7798785750852272 out of order (previous was 6
0899974692102014)
On tree page 139341 cell 31: Rowid 30248670001339912 out of order (previous was
60899974692102595)
On tree page 139341 cell 47: Rowid 7798785750853997 out of order (min less than
parent min of 7798785750895133)
On tree page 56280 cell 20: Rowid 7799953981885328 out of order (previous was 60
899974692102094)
On tree page 139601 cell 6: Rowid 60899974692101954 out of order (previous was 6
0899974692102635)
On tree page 139601 cell 12: Rowid 7799953981884067 out of order (previous was 6
0899974692102004)
On tree page 139601 cell 24: Rowid 7799953981884337 out of order (previous was 6
0868063085190935)
On tree page 140400 cell 59: Rowid 7799953981861083 out of order (min less than
parent min of 7799953981885328)
On tree page 18803 cell 28: Rowid 7800168730221930 out of order (previous was 78
00168730226002)
On tree page 175569 cell 23: Rowid 56463664317109005 out of order (previous was
56463664317109030)
On tree page 57045 cell 21: Rowid 7800383478307205 out of order (previous was 56
765574748128648)
On tree page 176111 cell 8: Rowid 7800383478307090 out of order (previous was 56
765574748131048)
On tree page 52427 cell 7: Rowid 9402956035444319 out of order (previous was 567
65574748133448)
On tree page 52427 cell 41: Rowid 7800383478305463 out of order (previous was 94
02956035444979)
On tree page 52427 cell 57: Rowid 7800383478305538 out of order (previous was 56
463664317109085)
On tree page 57045 cell 38: Rowid 49858910853927539 out of order (previous was 4
9858910853936298)
On tree page 177960 cell 20: Rowid 49858910853927521 out of order (previous was
49859220091487476)
On tree page 57045 cell 39: Rowid 7800383478307155 out of order (previous was 49
858910853927539)
On tree page 178005 cell 16: Rowid 7800383478307090 out of order (previous was 4
9858910853927571)
On tree page 14060 cell 52: Rowid 7800383478305568 out of order (min less than p
arent min of 7800383478307155)
On tree page 14060 cell 52: Rowid 7800383478338467 out of order (max larger than
parent max of 7800383478307345)
On tree page 166037 cell 54: Rowid 7800383478307350 out of order (min less than
parent min of 7800383478338467)
On tree page 179473 cell 51: Rowid 49858885084226186 out of order (max larger th
an parent max of 7800383478329117)
On tree page 130590 cell 58: Rowid 7800383478329122 out of order (min less than
parent min of 49858885084226186)
On tree page 57329 cell 38: Rowid 7800383478305388 out of order (previous was 94
02956035482917)
On tree page 179867 cell 5: Rowid 15325190 out of order (min less than parent mi
n of 9402956035482917)
On tree page 57329 cell 40: Rowid 7800383478305563 out of order (previous was 56
765574748131048)
On tree page 57329 cell 40: 2nd reference to page 52427
On tree page 57329 cell 40: Child page depth differs
On tree page 57329 cell 41: 2nd reference to page 14060
On tree page 57329 cell 42: Rowid 7800383478326959 out of order (previous was 78
00383478338467)
On tree page 40793 cell 2: Rowid 7800383478307360 out of order (previous was 780
0383478338477)
On tree page 57329 cell 42: Child page depth differs
On tree page 134404 cell 17: Rowid 7800383478338517 out of order (previous was 5
6463664317109095)
On tree page 134404 cell 19: Rowid 7800383478307160 out of order (previous was 7
800383478338522)
On tree page 57329 cell 44: Rowid 7800383478307345 out of order (previous was 49
858910853944930)
On tree page 16021 cell 17: Rowid 30250366513441123 out of order (min less than
parent min of 49858910853944930)
On tree page 16021 cell 17: Rowid 30250366513482318 out of order (max larger tha
n parent max of 7800383478307345)
sqlite>
iam8up
Mon Sep 19, 2011 10:33 pm
I found a log filling up in the Dude's files. Deleting this enabled me to do a backup. Unfortunately Dude still crashes just a few seconds after the download completes. I just hit alt+S to save it quickly and move it afterward.
SteveS
Wed Oct 19, 2011 10:06 pm
Hi I noticed that there has been very little discussion about the PPC version of Dude v4beta3. I have a number of RB1100 deployed and I would like to install v4 on them. I have been waiting for a year to get a PPC version of Dudev4. Can anyone give me an estimate of when this might happen?
mindragon
Fri Oct 21, 2011 8:11 am
To quote a very good acquaintance of mine, Derek Smart, "It will be ready when it's ready and right now, it ain't ready."
MD
sherman
Fri Dec 16, 2011 12:14 am
Hi all!!! Sorry for my bad english.
Database has more than 2 GB, and apparently this caused a crash Dude.
We rolled back the database and want to do VACUUM. But we had the same problem as ottoshr.
We can not do VACUUM:
sqlite3 /home/user/Work/Dude/dude_15.12.db
sqlite> VACUUM;
Dude does not clear the "Failure". Please tell me how to do VACUUM, if you need it and how to fix a hanging logs "Failure"? Thanks!
sqlite> PRAGMA integrity_check;
On tree page 1532217 cell 14: Rowid 159744042482606 out of order (previous was 159744042482606)
On tree page 1529865 cell 47: Rowid 161414784763142 out of order (previous was 161444849531610)
On tree page 1527120 cell 6: Rowid 161960245609737 out of order (previous was 161990310378473)
On tree page 2221 cell 32: Rowid 161870051294546 out of order (previous was 162050439920321)
On tree page 1524779 cell 29: Rowid 161870051294395 out of order (previous was 162050439921199)
On tree page 1474984 cell 1: Rowid 162144929203455 out of order (previous was 162394037304147)
On tree page 61829 cell 26: Rowid 162114864430459 out of order (previous was 162595900787603)
On tree page 422195 cell 18: Rowid 162050439921229 out of order (previous was 162660325276810)
On tree page 61829 cell 48: Rowid 162424102075619 out of order (previous was 162660325325665)
On tree page 1490887 cell 34: Rowid 162424102075409 out of order (previous was 162690390048183)
On tree page 61829 cell 50: Rowid 162424102075379 out of order (previous was 162660325276840)
On tree page 1401789 cell 42: Rowid 162394037304177 out of order (min less than parent min of 162595900769530)
On tree page 1490624 cell 23: Rowid 163132771681539 out of order (previous was 163222965992827)
On tree page 1536827 cell 2: Rowid 163222965992766 out of order (previous was 163222966004654)
On tree page 1513564 cell 46: Rowid 163253030764050 out of order (max larger than parent max of 163222965992766)
On tree page 1536827 cell 3: Rowid 163132771690841 out of order (previous was 163222965992766)
On tree page 820769 cell 46: Rowid 163102706908089 out of order (min less than parent min of 163253030764050)
On tree page 1507036 cell 14: Rowid 163454894239058 out of order (previous was 163454894251673)
On tree page 1513068 cell 9: Rowid 163454894228732 out of order (previous was 163484958997271)
On tree page 1459034 cell 40: Rowid 163484958999801 out of order (previous was 163515023768533)
On tree page 1514547 cell 51: Rowid 163768426838969 out of order (previous was 164459916573466)
On tree page 1499913 cell 15: Rowid 163738362068427 out of order (previous was 164459916573925)
On tree page 160298 cell 26: Rowid 163768426839692 out of order (previous was 163768426841366)
On tree page 1514547 cell 68: Rowid 163965995334574 out of order (previous was 163996060118294)
On tree page 1532126 cell 17: Rowid 163965995334363 out of order (previous was 164270938012779)
On tree page 1524964 cell 29: Rowid 166143543789784 out of order (previous was 166693299598985)
On tree page 1531000 cell 30: Rowid 166143543756041 out of order (previous was 166809263685037)
On tree page 1524964 cell 34: Rowid 166143543754159 out of order (previous was 166955292573160)
On tree page 1487502 cell 8: Rowid 165993219898928 out of order (previous was 166955292573402)
On tree page 1458980 cell 21: Rowid 166143543754492 out of order (previous was 166465666303235)
On tree page 1525187 cell 26: Rowid 166465666300786 out of order (previous was 166585925397702)
On tree page 1529009 cell 28: Rowid 166585925385315 out of order (previous was 166693299569913)
On tree page 1533702 cell 3: Rowid 166955292573433 out of order (previous was 166955292574969)
On tree page 1529462 cell 45: Rowid 167221580545725 out of order (previous was 167612421384495)
On tree page 1468703 cell 17: Rowid 167221580544912 out of order (previous was 167612421385010)
On tree page 1533625 cell 9: Rowid 171104230980315 out of order (previous was 171675461631144)
On tree page 1513512 cell 2: Rowid 170932432289087 out of order (previous was 171675461631204)
On tree page 1531067 cell 21: Rowid 171237374967214 out of order (previous was 171237374978504)
On tree page 1534464 cell 18: Rowid 171379108888073 out of order (previous was 171379108899104)
On tree page 1531256 cell 19: Rowid 171465008234062 out of order (previous was 171465008244987)
On tree page 1526826 cell 70: Rowid 172590285687862 out of order (previous was 88350759953603183)
On tree page 88335 cell 7: Rowid 172590285687380 out of order (previous was 88350759953603394)
On tree page 3355 cell 51: Rowid 173127156632167 out of order (previous was 208698078265517)
On tree page 1520548 cell 51: Rowid 173127156589248 out of order (previous was 64980554405870298)
On tree page 112609 cell 10: Rowid 173127156588434 out of order (previous was 64980554405870425)
On tree page 1436404 cell 39: Rowid 206997272684939 out of order (previous was 207920690642258)
On tree page 1054869 cell 20: Rowid 207920690658970 out of order (previous was 208191273581856)
On tree page 1462668 cell 6: Rowid 207920690642168 out of order (previous was 208191273582037)
On tree page 1054869 cell 56: Rowid 209063151954641 out of order (previous was 239205232425752)
On tree page 1535075 cell 3: Rowid 209063151944958 out of order (previous was 239205232425842)
On tree page 1521081 cell 47: Rowid 263050886885414 out of order (previous was 265181190671580)
On tree page 90324 cell 40: Rowid 99895309922712695 out of order (max larger than parent max of 263050886885414)
On tree page 77497 cell 44: Rowid 263050886885444 out of order (min less than parent min of 99895309922712695)
On tree page 1427796 cell 2: Rowid 4650321329011809 out of order (previous was 35273876236158265)
On tree page 1516373 cell 21: Rowid 4650321329011779 out of order (previous was 40208767889458494)
On tree page 1515346 cell 3: Rowid 4647186002886332 out of order (previous was 4650321329011899)
On tree page 1427796 cell 4: Rowid 4650321329012352 out of order (previous was 4650321329028762)
On tree page 1335155 cell 37: Rowid 4650321329012262 out of order (previous was 30368877555248901)
On tree page 1428300 cell 30: Rowid 4656235498978562 out of order (previous was 30370359318969919)
On tree page 1427796 cell 22: Rowid 24418616978467067 out of order (previous was 31707545846967544)
On tree page 1324279 cell 31: Rowid 4656501786950874 out of order (previous was 29278441193367803)
On tree page 1324279 cell 36: Rowid 4656235498978382 out of order (previous was 4656501786950994)
On tree page 1324279 cell 47: Rowid 4650321329024561 out of order (min less than parent min of 30386293647632883)
On tree page 1427796 cell 23: Rowid 4656501786963312 out of order (previous was 24418616978467067)
On tree page 1353556 cell 5: Rowid 4656501786951024 out of order (previous was 29179626880788730)
On tree page 1512471 cell 39: Rowid 24383174904354479 out of order (previous was 70987899392990747)
On tree page 1524262 cell 23: Rowid 24383174904350655 out of order (previous was 24383174904359119)
On tree page 83211 cell 60: Rowid 70987903687941503 out of order (max larger than parent max of 24383174904350655)
On tree page 61054 cell 45: Rowid 24383174904350685 out of order (min less than parent min of 70987903687941503)
On tree page 3435 cell 57: Rowid 22 out of order (previous was 24383174907048994)
On tree page 656608 cell 2: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 3: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 4: Rowid 20 out of order (previous was 21)
On tree page 656608 cell 5: Rowid 9 out of order (previous was 20)
On tree page 656608 cell 8: Rowid 20 out of order (previous was 21)
On tree page 656608 cell 9: Rowid 20 out of order (previous was 20)
On tree page 656608 cell 11: Rowid 20 out of order (previous was 21)
On tree page 656608 cell 12: Rowid 20 out of order (previous was 20)
On tree page 656608 cell 13: Rowid 20 out of order (previous was 20)
On tree page 656608 cell 14: Rowid 6 out of order (previous was 20)
On tree page 656608 cell 15: Rowid 0 out of order (previous was 6)
On tree page 656608 cell 17: Rowid 5 out of order (previous was 21)
On tree page 656608 cell 20: Rowid 20 out of order (previous was 20)
On tree page 656608 cell 21: Rowid 20 out of order (previous was 20)
On tree page 656608 cell 23: Rowid 17 out of order (previous was 21)
On tree page 656608 cell 25: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 26: Rowid 20 out of order (previous was 21)
On tree page 656608 cell 28: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 29: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 30: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 31: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 32: Rowid 14 out of order (previous was 21)
On tree page 656608 cell 34: Rowid 20 out of order (previous was 21)
On tree page 656608 cell 36: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 37: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 38: Rowid 11 out of order (previous was 21)
On tree page 656608 cell 40: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 41: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 42: Rowid 21 out of order (previous was 21)
On tree page 656608 cell 43: Rowid 21 out of order (previous was 21)
sherman
Sun Dec 18, 2011 6:07 am
Help, I need somebody!
I found are two identical index in the table objs.
Create a new database with empty tables chart_*, and delete duplicate records in objs results in resetting the base when starting Dude.
How can I be? Is it possible records with identical indices located in the objs or another tables?
lebowski
Mon Dec 19, 2011 4:36 pm
Sorry Sherman, you are probably going to have to do some experimenting and hopefully you get lucky. If you have some old exports maybe you could start from there? I have not heard of anyone recovering from having serious database trouble. Maybe instead of deleting table information just change the duplicate records to be unique?
Bummer :(
Lebowski
YU5R1L
Fri Jan 20, 2012 5:21 pm
leofilhopb
Mon Jan 23, 2012 3:49 pm
"the dude" is abandoned?
sparker
Mon Jan 23, 2012 5:57 pm
when is the next release? :(
Sorry for my English.
soosp
Thu Feb 16, 2012 10:47 am
Hi, Is Dude development stopped? And what about the v4 ppc version? We are still using v3.6 due to the lack os ppc version.
honzam
Mon Feb 20, 2012 12:28 pm
bump
LAN, FTTx, Wireless. ISP operator
Ciambot
Mon Feb 20, 2012 3:36 pm
I'd like to see it open source!
pospanko
Wed Mar 28, 2012 12:02 pm
MT, when new version will be available? Would there be new version?
Thx
Internet, Mikrotik & Network solutions
http://www.pro-ping.hr
randallr
Mon Apr 09, 2012 3:08 pm
Running 4.0beta3 on ROS 4.17 on x86
57.6GB total HDD
57.4GB Free
2.6ghz AMD dual core, 6-10% cpu
Backup restarts Dude service.
I've seen reference to backup up dude files with file copy. Is this possible from Winbox or otherwise?
Dude is awesome otherwise, and has become key piece of our operation. Just a few things and it's the perfect network monitoring tool..... I understand that it's hard to budget development time for free software. Perhaps time to either have a paid license version or maybe send some t-bone steaks to Normis?
AnRkey
Mon May 07, 2012 3:20 pm
Is The Dude still being actively developed?
MTCNA
benjamimgois
Sat May 19, 2012 4:45 am
I'm also having some problems with backups in 4beta3. I have 1 map with 403 devices, when i make a backup it exports the TGZ file perfectly and give no error messages, but when i try to import the TGZ file it says that the current "user or password" are wrong and do not let me log in, but i'm sure my user and password are correct. So i'm locked outside the program, to recover i have to delete dude.db and import an older backup version. Anyone had something similar ?
Telecomunications Engineer
Cisco CCNP, CCNA, CCDP, CCDA
joshaven
Thu Sep 13, 2012 3:14 pm
Can you release the Dude as open source so the development can continue. Sadly, we are going to have to move much of our dude usage to Cacti because we cannot get the Dude to be reliable. I have been woken up many times by the dude saying that everything in my network is down. After a reboot of the Dude I get another 250 text messages saying everything is up again. I'd love a stable version and a few improvements.
Joshaven Potter
Consulting and Business Services Available http://joshaven.com
zizobaddy
Fri Oct 12, 2012 10:03 am
My dude is not working with os6
okoun
Fri Oct 26, 2012 1:17 am
I turned on the dude server on ros 5.21 on the PC over the network does not detect my drive and cpu. what? a problem with snmp? on windows xp it worked
digicomtech
Mon Nov 19, 2012 6:10 pm
sqlite> VACUUM;
Probably you have done copy of device with older version of Dude and some have the same ID. As lebowski suggest change all duplicate key using SQLite and then retry vacuum;
Regards,
Michael
ottoshr
Wed Jan 23, 2013 10:44 am
When will be v4 stable release? when it is possible to remove selected outage from view Outages ? when export and import will work. stable release please !!!
Montana
Wed Feb 13, 2013 2:33 am
Sad to say, but I think the Dude is dead. Hope Im wrong but no one has heard anything about upgrades since 2011.
I have a rb1100x2 I would love to put it on. Oh well I guess it might get Aircontrol .
Sad very sad.
plankanater
Tue Mar 05, 2013 5:58 pm
Yeah I agree and it is a shame. I'm starting to look for a replacement but nothing is as polished as the dude.
ottoshr
Tue Mar 05, 2013 6:09 pm
Please keep inform others about possible replacement !
SamWCL
Thu Mar 14, 2013 12:23 pm
Also waiting!
fermintrv
Tue Apr 02, 2013 12:58 pm
We love Dude!! Waiting for a new versión!!
Regards.
AnRkey
Mon Apr 22, 2013 1:22 pm
When will there be a new version of The Dude?
MTCNA
benjamimgois
Tue Apr 23, 2013 5:16 pm
I´m sticking to the old 3.6 release. It´s a lot more stable than the last beta release.
AnRkey
Tue Apr 23, 2013 9:37 pm
MTCNA
benjamimgois
Fri Apr 26, 2013 4:15 pm
Wow, NetXMS seens like a very big project already. Thanks for sharing
AnRkey
Fri Apr 26, 2013 4:35 pm
My dude server crashed and I opted to rebuild using netxms. I'm quite happy so far as it is quite potent. Also, it has android as well as webserver support.
I love dude, but it's poor support makes it hard to use in a production environment. Backup and restore should work at the very least IMHO.
Anyhoo, let us know how you fair.
R
MTCNA
tripflex
Mon Jun 03, 2013 5:44 pm
We should convince Mikrotik to put The Dude on kickstarter so those who love it can contribute to enhancements, updates, and bug fixes :)
Chupaka
Mon Jun 03, 2013 6:33 pm
not kickstarter but github :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Diamond
Mon Jun 10, 2013 11:25 pm
Has copied the message here, just in case.
Good day!
I wrote above about router rebooting on rc12. So.
I have installed Dude4.0beta3 package on the device (rc11). Updating to rc12 brought to reboots. Router worked on rc11 before today.
Today I tried to upgrade to ROS6.0 release and the router began reboots again :D Next, router has netinstalled again for ROS6.0 - and all stayed ok! After this Dude4.0beta3 has installed and all work!
These all say that the dude package brought to reboots after upgrading a release, or the updating process goes wrongly=)
P.S. This post is also in rc12 thread, just in case.
I forgot to install ntp packet on previous state "all work" system. Did it, and RB951 began reboot. So this dude package damages the install manager? Don't uderstand.
Now I don't want install the dude because each upgrade of the system will occur rebooting...
bartjoo
Thu Jun 27, 2013 3:42 pm
Yeah, when is there a new (beta / final) release?
greetz
Bart
jmay
Wed Jul 10, 2013 5:56 pm
Glad I looked at the dude forums today! Looking at NetXMS right now! Droid support yeehaw!
kirlein
Thu Jul 18, 2013 6:34 am
is it possible to use Radius for Dude User Login ?
jmay
Thu Jul 18, 2013 11:46 pm
I guess I got a bit too excited too early, netxms SUCKS!!! Took me half the day to get the installer to work on server 2008. Finally got it installed and what a piece of garbage. Its really to bad us computer nerds are in charge of designing this crap because we really don't know how to make user friendly software.
SergePo
Fri Jul 19, 2013 1:54 pm
When prompted for the CCR DUDE?
normis
Fri Jul 19, 2013 2:02 pm
Dude has not been updated for years, so I can't promise anything
lebowski
Wed Jul 24, 2013 12:43 am
One last please! PLEASE open source IT or let us pay for The Dude! HELL! HIRE ME TO DEVELOP IT, I know the product the best. I will sign a NDA, work for beans, and make everyone happy.
angboontiong
Fri Jul 26, 2013 6:48 am
i tried the previous version it taking a lot of bandwidth...
may i know, if we going to monitor about 1000 devices, what's the minimum RAM and bandwidth required for the monitoring?
spacemind
Wed Jul 31, 2013 7:50 am
The great Mikrotik is getting behind other good brands with it´s own monitoring software.
Please Mikrotik, Give us the CODE :D or develop and get paid for that.
We need a mikrotik software/appliance to monitor MK devices (massive setup, massive manager) with easy setup for each MK model.
I can donate to the dude or other MK software development software for monitoring.
If MK has some huge money offer from big company´s to develop the dude, they would do it, but as we are only a few buyers in the world they are forgetting us.
LET US WORK !!!
leofilhopb
Fri Aug 02, 2013 3:24 pm
Please continue developing DUDE and we are willing to pay for it.
honzam
Fri Aug 02, 2013 4:59 pm
+ 1
azendre
Sat Aug 03, 2013 11:55 am
+ 1
atus
Sun Aug 04, 2013 1:15 am
rodolfo
Long time Member
Long time Member
Sun Aug 04, 2013 12:14 pm
+1
rodolfo
IZ0UQV
pagey
Mon Aug 05, 2013 3:00 am
+1
fermintrv
Tue Aug 06, 2013 11:53 am
+2.
gmeyer
Fri Aug 16, 2013 5:48 pm
+1 :)
Gabriel J. M. Meyer
CCNA, Red Hat Linux Administrator
ropeba
Fri Aug 16, 2013 10:51 pm
+40° :)
ayger
Tue Aug 20, 2013 9:35 pm
If ain't broken, dont fix it.
point
Wed Aug 21, 2013 2:38 pm
+100500
interprime
Fri Aug 23, 2013 12:06 am
+10000
ivtts
Thu Aug 29, 2013 10:42 pm
join, +1
slackR
Mon Sep 02, 2013 3:51 am
+++++ Dude could be so much more powerful if updated. Would pay $$$ for it!!!
kraker
Mon Sep 02, 2013 2:32 pm
we are waiting to pay $$$ for new dude...
spacemind
Mon Sep 02, 2013 2:35 pm
16 posts are not enought, lets go to 1000 posts asking for the new dude. :)
helectro
Mon Sep 02, 2013 3:41 pm
+1 another vote 1 less
digicomtech
Tue Sep 03, 2013 3:44 pm
+10 (we are 10 tech here @ Digicom that want an Updated Dude!
In the mean time what's the best alternative (Free or not) you Mikrotik Guru have found?
We are still using The Dude but with mitigated success now that our device pool that we have to monitor as grown in to 1000k +
slech
Long time Member
Long time Member
Wed Sep 04, 2013 10:52 am
as example:
1. 100$ - life license.
2. 150 copies * 100$ = 15.000$ - will permit you to arrange one developer for approximately 1 year for dude development.
aacable
Wed Sep 04, 2013 4:29 pm
+1
Please upgrade DUDE. The world is moving too fast, and dude is far behind :(
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
dave003
Sun Sep 08, 2013 8:24 am
+10$ :D
MTCNA - MTCWE - MTCUME - MTCTCE - MTCRE, to be continued...
nje431
Tue Sep 10, 2013 5:53 pm
To the good folks at MikroTik:
When you present a product to your customers or potential customers, whether it be free or paid, that is as buggy as Dude is, whether you realize it or not, you are sending a powerful message about your commitment to quality that no amount of advertising can overcome.
I am not an IT professional, but an RF engineer who needs to replace some routers with something very reliable and stable, yet something a non-IT expert can set up and maintain. Several IT professionals that I know have recommended your routers. But after struggling with the many bugs in Dude, I am hesitant to pay my company's money for a Mikrotik product (and my time fighting bugs).
You don't necessarily need to add features to Dude (although a few basic ones would be helpful), but you do need to address the bugs.
And I will add my support for a free lite version and a reasonably priced paid version.
Thank you.
andersm
Wed Sep 11, 2013 3:42 pm
Very happy to pay good money for an upgrade. Its become a vital part of our network now... such a nice, intuitive interface!
Please Mikrotik code monkeys, release a new paid version :)
randallr
Wed Sep 11, 2013 3:55 pm
I'd pay $100 just to be able to successfully backup my dude config. So close to being the perfect monitoring tool.
coylh
Thu Sep 12, 2013 6:57 pm
I discovered the Dude a few years ago (wanted a visual what's-up utility). This lead to looking at other Mikrotik products. I'm now at 60 routerboards and climbing...
pcunite
Thu Sep 12, 2013 7:04 pm
+1
derr12
Fri Sep 13, 2013 12:27 am
We love the dude! If developement started again, we would donate in a heartbeat. Fire up a Kickstarter campaign! guarenteed youd get some cashola for the project.
VagnerBecker
Sat Sep 14, 2013 5:18 am
+1
ariosvelez
Mon Sep 16, 2013 8:24 pm
+1
I have The Dude on my windows 7 PC 64, and it was working fine but recently I found that when I use winbox from The Dude tools it is not showing me the Hide Passwords check mark option also when I try to maximize the window it come as blank area arround and wont let me see anything out of the original area opened by the winbox trough The Dude. But if I open anything directly from my exe winbox it work perfectly. If any one have a clue on this let me know.
PSD I unistall it and reinstall diferent version and is the same, now I have version 4.0 Beta3. The windows UAC is correct I have full admin access.
Thanks in advance
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
MTCNA, MTCRE, MTCINE
benjamimgois
Mon Sep 16, 2013 9:17 pm
+1 !!!
Please Mikrotik give us the source ! i´m willing to work on it too ! The dude is the perfect tool ! We need it ! We love the dude !
jirkaehm
Tue Sep 17, 2013 6:10 pm
+10
honzam
Wed Sep 18, 2013 9:40 pm
+20
VagnerBecker
Thu Sep 19, 2013 11:35 pm
+1
Thanks in advance
Hey man,
For me is showing. What does not work for me are the functions with "ros_command" when a RouterBoard any loses connection "by getting off" ie the function (service) stops plot. This happens to anyone else?
Ex:
ros_command(":put [interface wireless registration-table get number=0 signal-to-noise ]")
Regards.
Vagner Felipe Becker
tracktor
Sat Sep 21, 2013 11:23 pm
I'm using Dude for a few years and I'm greateful for the people who developed it….please guys don’t let it die open it to the world
CGirardy
Mon Sep 23, 2013 9:53 am
I agree with all latest comments : PLEASE... Start again development... pleassssseeeee
We love The Dude....
PLEASE... Release source code to the community and start developing The Dude again....
PLLLLLLLLLLLEEEEEEEEEAAAAAAAAAASSSSSSSSSEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE (big cry for help :))
iam8up
Mon Sep 23, 2013 3:43 pm
Please fix the Dude!!!
avolve
Mon Sep 23, 2013 3:55 pm
How about simple smtp auth for email alerts ?
jonashi
Wed Sep 25, 2013 10:50 am
just another 10 people here willing pay $100 for Dude. Now I can't do without Dude. I Have been using The Dude for three years on daily basis and I am really affraid of database overflow. Please release source code or -better way- let us pay for Dude! We gonna be happy to spend money on this.
MTCWE, MTCNA. Using Mikrotik ROS since 2003
CGirardy
Wed Sep 25, 2013 11:23 am
I'm starting to think that all the developers of The Dude left the company... which could explain this complete stop in the dev;
buset1974
Fri Sep 27, 2013 10:17 am
Dude is not dude anymore it's getting old.
so many request for improvement but no more updates :( :(
it worst, old v 3.6 dude installed on 5.x or 6.x routeros can cause high CPU load on router, even on x86 model.
itatwork
Wed Oct 02, 2013 9:32 am
+1!
jirkaehm
Mon Oct 07, 2013 12:13 pm
Anything new?
tomekmak
Wed Oct 09, 2013 3:29 pm
please fix dude...
LastResort
Sun Oct 13, 2013 2:32 am
Agreed. I like The Dude because I've been using MikroTik RouterOS since before RouterBoard made any products. Since v2. I went to the 2 day MUM precursor in Vegas, was that 2003? RouterBoard was making 4 port Ethernet cards and RouterOS on an IDE flash drive. Along with others here, I'd be pleased to contribute to the development of Dude monetarily. I also agree with others about what The Dude does for the image of the company. It is a, could be, a flagship driving sales. I'm even fine with branding like Spiceworks, where a request is addressed by vendors who pay the freight for Spiceworks. Clearly it is a business model that works.
Please, offer Mikrotik users the opportunity to support The Dude Project.
Or tell us to #sand and look for an alternative to The Dude so we give up hope and move on.
chepoek
Tue Oct 15, 2013 6:56 pm
Yes, we need last update for The Dude..
chimaster
Fri Oct 18, 2013 3:40 am
+1 Again.
Normis, When we talked at MUM in Sydney you said Dude would receive some love when CCR and ROS 6 were released.
I really think it's time you (Mikrotik) made a decision on the Dude. Either release an update, release it to the wild or let everyone know that development is over.
I'm now testing several other products to move to for monitoring as I can't deal with lack of development any longer. We have 150 Mikrotik Routers and I'll continue to use them. But to me Dude was a unifying solution to my network and monitoring that has glued me together and kept me Mikrotik. I still get WOW moments when I turn up on site for a customer and do a Discovery of their network, I explain it, then start talking about lack of development and bugs and they carry on with their Ruckus or Ubiquity products. I could integrate so much more Mikrotik based on the Dude alone...
You're doing yourself a dis-service (did you hire Steve Balmer?) by stagnating. Make a decision. Just read this thread again and make a bloody decision....
MTCNA - MTCWE - MTCRE - MTCINE - All round good guy and Linux nut
<plug>
HQWiFi making http://www.queenstown.com Wireless since 2001.
</plug>
kjagus
Fri Oct 18, 2013 3:47 pm
+1.
soulflyhigh
Sun Oct 20, 2013 5:33 pm
Bloody hell (please pardon my French and bad English).
If the number of developer's staff is the only problem find/hire one more (or two).
Even if they are novice they can do minor changes/bug fixes and will eventually make some real progress.
The effect of their work could be enormous for all of us who use your software/hardware products.
It's unbelievable that a company of such size as Mikrotik is today doesn't have enough resources to do it
(or wisdom to realize the potential benefits of bug-fixed/updated Dude).
The idea of opening source of The Dude (in my opinion) is unrealistic because of too many reasons.
So, dear Mikrotik, please hire someone to continue work on The Dude, there is a lot of us willing to act as a free beta testers.
Thanks in advance (for being reasonable).
Regards,
M.
MTCRE, MTCTCE, MTCSE
chimaster
Mon Oct 21, 2013 10:35 pm
Since my post I have been reviewing many other monitoring tools. After a lot of reading and testing... http://en.wikipedia.org/wiki/Comparison ... ng_systems I have decided on Zenoss, Nagios and ICINGA came close second equal. I'm currently installing and migrating my monitoring and mapping data across and exploring some of the other useful tools available in an actively developed and supported product.
500+ Devices, 30+ Maps, 20+ Subnets, SNMP, Graphing, Performance data and whatever else I can get across from 6 years of Dude Data. Along with the rapid growth we're having all based on Mikrotik kit.
The Dude does (did) so much for me and I may continue to use it for smaller sites and client monitoring but as my business grows I need the assurance of a product that is not only actively maintained and developed but where the operating comapny is honest and open with development to the community it is supposed to support.
A (great) Free product managed badly does more damage to your reputation than a good paid product. I always thought Mikrotik was better than that, It was exciting to be part of it (since ROS 2.9.?).. now I guess my opinion of Mikrotik is just another ho-hum hardware company with contempt for their customers and lack of engagement. It's not too late... Just reply and let your customers (supporters) know where you're at.
Sorry for the lecture, but really dissapointed.
<plug>
</plug>
elxer
Wed Oct 23, 2013 6:03 pm
When dude package will be available for CCR 1036
djmanu
Fri Nov 08, 2013 4:32 pm
waiting for a new version...
and CCR support
kaipr
Tue Dec 03, 2013 4:15 pm
Hello there,
I too, would love to see a new version of Dude out, and probing for example IPv6 devices (which would be very useful), as well as fixing bugs, and adding new features.
Thank you, best regards,
Vlasta
omidkosari
Trainer
Trainer
Wed Dec 11, 2013 11:05 am
+1
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
djmanu
Wed Dec 11, 2013 1:28 pm
+1
+6 Sysadmin customers
winet
Thu Dec 12, 2013 8:44 am
when the new version is released, it's gonna be like "BBM being released for Android/iPhone" :lol: everyone is gonna cheer up
pdf
Thu Dec 19, 2013 11:45 am
Hi guys
we need answers and honestly it looks like a suicide strategy:
1) there is the demand and I guess nobody would complain if you charge 100 Euros/year per dude license
2) there is the code base
3) you can find 2-3 engineers to develop the code and still be profitable
We still don't know the problem about a new version of the dude, and I guess we will never know but let us know what you want to do so everybody can reorganize to monitor our networks.
Let's us know what you want to do asap, or you will loose brand credibility and customer base.
See you in Venice!
benjamimgois
Thu Dec 19, 2013 12:53 pm
I think a crowdfunding model like indiegogo or kickstarter would be perfect for dude. The only complain is the lack of a official state from mikrotik.
Sandra
Fri Dec 20, 2013 4:11 pm
*) fixed static object crash
*) changed icon
*) some minor fixes
http://www.mikrotik.com/thedude.php
Mormis pode me ajudar na questão ?
Desejo saber se o dude tem alguma limitação de quantos host podem ser pendurados a ele.
I wonder if the dude has some limitation on how many host can be hung to it.
chimaster
Mon Jan 13, 2014 11:04 am
+1 crowd funding.
I've just been doing the rounds (again) as I always do after a decent network session with the dude, I just can't believe it's been left in the cold to die. If I were to see a roadmap and a new release I would gift Mikrotik $1000, that's what it would cost me per month for some commercial tools to do what I currently do with Dude. Mikrotik could really make some real $ with active dude development... more and more I look for alternatives that do what the dude can as simply and as easily and more and more I come back here to plea with Mikrotik to listen to their users!
nz_monkey
Tue Jan 14, 2014 12:44 am
In my opinion Mikrotik should fork "The Dude".
Leave the current version as-is and start a new version that has a commercial paid subscription model, this will allow them to fund full-time developers working on the product.
Because "The Dude" is free and does not generate revenue, the owners of Mikrotik are focusing resources on products that do generate revenue e.g. CCR/Routerboard while The Dude is being abandoned.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
chimaster
Tue Jan 14, 2014 12:50 am
Which is a shame, a license model would see at least enough revenue to fund 1 Developer. I've talked to many people who have played with it, liked it but been turned off by lack of release support and commitment.
rmmccann
Thu Jan 23, 2014 9:01 pm
Count me in as a +1 on licensing. I'd have no problem paying for a license for The Dude if it meant product updates and feature enhancements.
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. --Douglas Adams
nz_monkey
Thu Jan 23, 2014 10:38 pm
Another couple of licencing schemes that work well for other Network Monitoring systems that Mikrotik might consider for The Dude:
- Free up to X number of devices, then paid per available in licence blocks of 10,20,50 and 100 devices
- Unlimited monitoring of devices but NO advanced features e.g. alerting/upgrading unless paid contract
- Unlimited monitoring of devices but only store 1 days worth of historical data unless paid contract
I guess they need a way to give people a "taste" of The Dude, but still make money from it.
chimaster
Thu Jan 23, 2014 10:42 pm
I've just been going through all the MSP RMM Platforms
Naverisk
N-Able
Kaseya
Centrastage
GFI
etc...
For a real simple real easy return, what about $1 per device per month. I have 200 devices on my Dude and for active development and bug fixing as well as a clear roadmap I'd be happy to pay per device.
syadnom
Fri Jan 24, 2014 1:07 am
Naverisk
N-Able
Kaseya
Centrastage
GFI
etc...
wow that's way to much for the dude! these RMM products do patch management, av monitoring, integrated backup etc between 1 and 3/m for the most part. The dude is just a snmp monitor with a graphical representation.
Anyway:
1) working PPC 4.x version?? ever?
2) The Dude *is* effectively dead, it's abondonware.
chimaster
Re: Dude v4beta3 released
Fri Jan 24, 2014 2:20 am
I know, but with a little effort the dude could do much much more... I said with a decent roadmap.. maybe not immediately... ;-)
tracktor
Wed Feb 05, 2014 1:31 pm
Well, it's a real shame, no respond from the dev team, a great tool that goes to drain.....please release the code or start to charge for support so the tool wont die.....
AnRkey
Wed Feb 05, 2014 4:12 pm
Naverisk
N-Able
Kaseya
Centrastage
GFI
etc...
http://www.netxms.org/
Truly the best NMS ever and it runs on Windows or Linux with native builds and agents for each too.
nuf said!
MTCNA
syadnom
Wed Feb 05, 2014 4:18 pm
there's nothing quite like the dude. it's limited in scope, but what it does, it does well. the map with lines representing bandwidth and link status is extremely useful for a micro-noc. I've used 'tik routers to build VPN clouds for business and put a small atom box with a big LCD and dude running in for this purpose.
AnRkey
Thu Feb 06, 2014 11:19 am
NetXMS does all that and more. You can even build a custom dash or put dials and graphs for disk, cpu and traffic monitoring.
Also, it has native agents and clients for Linux, Windows and Android.
There is a web interface for the Linux and Windows builds that I have not used yet, but it looks good.
The support is impressive and you can buy support contracts if needed (in my budget this year).
The developers are serious about the product and they release regular updates.
I have found it to be a very good replacement for Dude.
Screenshots can be found here: http://www.netxms.org/screenshots/
Features list: http://www.netxms.org/details/
I was really angry that MT did not support Dude properly. I am OK again now that I have found NetXMS, it solves all my problems.
Lastly, the software is free and open source!!!!
MTCNA
chimaster
Thu Feb 06, 2014 9:53 pm
That's a nice list of messages to come to work to after a day off. I'm definately going to try NetXMS. Visually it looks less mature / impressive than the dude, but I can see some quick releases and good support on it.
Cheers for the heads up!
AnRkey
Thu Feb 06, 2014 9:58 pm
pm me if you get stuck. Its harder to use than Dude, but well worth the effort.
MTCNA
guatiki
Tue Mar 18, 2014 11:12 am
We use The Dude as a primary tool for real-time monitoring from version dude-install-0.1beta15 2005.
Currently we monitor a lot of systems of a CPD 1000 square meters and communications equipment from more than 200 clients.
It's a shame if it is abandoned. I think a large majority would be willing to pay to ensure the continuity of the product.
We would, of course.
Why you do not do a survey? I think the result will be surprised.
Rergards from Spain !!
kellogs
Sun May 11, 2014 7:12 pm
I am willing to pay for thedude...
come on mikrotik ... do something about it!
Brazd
Mon May 19, 2014 6:21 am
+500 to all....
Special for old latvians, who was born in USSR and undertand what i mean:
"... и тишина" (с) "Неуловимые..."
But if seriously: it's very bad idea to killing good product.
We all waiting Your reaction on our posts and continue of Dude developing.
mauricioisp
Tue May 20, 2014 7:21 am
normis and sergejs please hear us. We would really like to see (and even pay) for a new The Dude version.
Thanks,
dmcdon
Wed May 21, 2014 7:22 pm
+1
Please let us know what we can do to move the Dude forward. It is a great tool, with a lot of features that anyone running a MikroTik network can find very useful.
We received the new product flyer today. We are looking forward to the new mANT30 dish with the precision alignment mount.
The Dude is more than a device monitoring tool, it gives us a quick look into the Mikrotik equipment configs along with their status.
Please continue to upgrade it, release it SAAS, License it, or release it to open source. Just let us know if we can continue to count on it.
otgooneo
Trainer
Trainer
Mon Jun 02, 2014 2:23 pm
+1 for new version of Dude.
Want to learn more and more...
jarda
Mon Jun 02, 2014 3:04 pm
Everyone wants the dude to be resurrected. Only mikrotik does not.
chojrak11
Wed Jun 11, 2014 8:07 am
The Dude doesn't even install on MIPSBE with RouterOS 6.14.
I think that sources of The Dude have been lost, that's why there are no updates, not even minor, for such a long time. The Dude used to be the best monitoring software ever. But it's now dead.
Anybody in charge care to respond?
CCIS
Fri Jun 13, 2014 4:19 am
Just another +1 hoping the Dude development lives on. We use the dude every day for our 1500+ device mikrotik network.
Have a free version and then a pay version for larger networks to recoup costs @ programmer time.
Or, let us at the code .. open source :D
A few updates that would save us hours daily:
*highlight a bunch of devices on map, and execute cli commands on them all (mass config changes)
*backup config per device easily, automatically
*scheduled auto upgrades
*100 more..
:o
tomekmak
Fri Jun 13, 2014 9:04 am
Reading this topic there is one thought: MT staff don't care about Dude. Dude is dead. There is no reasonable response from them about that.
chojrak11
Fri Jun 13, 2014 11:32 am
I'm telling you, there are no Dude sources anymore. I can find no other reason for missing such a business opportunity.
omidkosari
Trainer
Trainer
Wed Jun 18, 2014 3:05 pm
Also it has been removed from downloads http://forum.mikrotik.com/viewtopic.php?f=8&t=86094
normis
Wed Jun 18, 2014 3:09 pm
Dude has not been removed. Just non-working RouterOS packages
xtsoler
Sat Jun 21, 2014 7:29 pm
Does anyone else have a problem with the link colors? They are not updated properly when for example the link is full and the full color is set to red, parts of the link become red and not the whole link. It's frustrating. I hope they pick up the development of dude.
Also here's an old attempt of a dude inspired project that I tried:
http://www.jnodes.net
you can create a map and if you allow snmp queries from the ip that the site is hosted, you can get live data.
Scott
Sat Oct 11, 2014 6:32 pm
Give it up people. This thread has been +1'ing for more dev on the Dude for well over a year, on top of all the other "please update" topics.
And MT's *ONLY* response is to some passing comment to say it is still available for download while managing to ignore every other post? Amazing.
angboontiong
Thu Oct 16, 2014 4:30 pm
How can we add the device with GPS coordinates then dude will draw on map?
iam8up
Tue Oct 28, 2014 6:19 pm
3 and a half years =P
nimbo78
Sat Nov 01, 2014 8:22 am
Normis, can you comment on the company's position in relation to the Dude?
barkas
Re: AW: Dude v4beta3 released
Sat Nov 01, 2014 10:31 am
Kicking a dead horse.
joemenrod
Mon Nov 03, 2014 3:08 am
MT said at the latest US MUM that The Dude "is not dead".
nimbo78
Mon Nov 03, 2014 9:46 am
and that's all?.. ))
normis
Mon Nov 03, 2014 9:47 am
We have a plan to make a completely new dude, that would work with CAPsMAN and have better web interface. Project is still in planning stage.
nimbo78
Mon Nov 03, 2014 9:50 am
AVE, Normis!! AVE, MikroTik! :)
jarda
Mon Nov 03, 2014 6:03 pm
Plans. Planning stage. No road map. None can expect anything.
SystemErrorMessage
Tue Nov 04, 2014 1:26 pm
How long before the next dude would be out? I am looking forward to it. Is mikrotik expanding their programmer base to cope with the workload of handling routerOS variants, dude and possibly other things mikrotik has?
rmmccann
Wed Nov 05, 2014 11:20 pm
So, in other words "don't hold your breath" :lol:
chimaster
Mon Nov 17, 2014 5:02 am
Nothing wrong with current dude. Just needs updates, bugfix, roadmap and communication. I don't think it needs re-created. It's a network tool, dedicated server, doing its thing. You could add a webinterface on it, but why go back to the drawing board?
SystemErrorMessage
Mon Nov 17, 2014 8:31 pm
maybe because theres a bug in the core of the program/design or perhaps it is just not competitive. Free software doesnt actually need to stand out, it just needs to be easy to use and work. I really do like to use Dude but i really want there to be server for routerboard such as the CCR so it can be the center of the network and map out networks more effectively while saving power by not having your standard desktops to be kept turned on for monitoring and mapping.
Routerboards use very little watts.
rmmccann
Tue Nov 18, 2014 9:35 pm
Dude doesn't use much for resources. No reason you couldn't run it in a virtual machine on one of your existing servers.
partovi64
Sun Dec 14, 2014 7:17 pm
we waiting for new ver dude,it have any problem with restore database(above 100 m in ver 3.6 ) so crash in 4.3
Aveyer
Tue Dec 16, 2014 1:31 am
I really hope Mikrotik resumes development of The Dude, out of all the network monitors I have tried, The Dude is still by far the best and easiest to use.
icecybe
Thu Feb 19, 2015 12:46 am
Greestings.
For the first of all Dude is the real THE DUDE, easy, fast, and verry functional monitoring software. I try'it and in few hours server are up and monitoring a few hundred of devices. What about bugfix is there one that i can't see here on forum explanation. It : charts, monitoring of the data are almost real time (verry fast) but drawing charts take's a while in i5 core machine is a problem with soft or nework. It there any help for the moment to draw chart's or waiting for bugfix. Also maybe this problem aren't on 3.6 version, but i'm stuck with back-up on 4 version. Any help ?
abis
Sat Mar 07, 2015 3:46 pm
R.I.P. or we need to wait more years?
Image Image
jarda
Sat Mar 07, 2015 4:24 pm
You know mikrotik. They do things when they want to. Seems they don't want yet...
fabrix
Wed Mar 25, 2015 11:36 pm
Nothing about Dude ???
Normis can you help the community ?
Thanks a lot !! :D
makenadenica
Wed Apr 01, 2015 3:30 pm
Interesting.. Comes In time!
[url=http://квартири-велико-търново.com/]квартири-велико-търново.com[/url]
honzam
Sat Apr 04, 2015 8:20 pm
The latest version is more than 4 years old. :arrow: Please rebirth DUDE. We need it
syadnom
Wed May 06, 2015 6:10 pm
I quit using the dude for lack of updates, perpetual beta status, etc. wish there were a v5 coming
meconiotronic
Fri May 15, 2015 11:27 am
Please we are waiting for a new version.
jarda
Fri May 15, 2015 2:55 pm
... and we will be waiting till the death.
snowy1364
Fri May 22, 2015 10:00 pm
The Dude for Android:
Any one who is using the Dude and has an Android phone should really check this out:
https://play.google.com/store/apps/deta ... wy.thedude
nomercy14
Wed Jun 03, 2015 4:11 pm
Normis, are there news about the new version of Dude?
4 years is a very long time and million things have changed. We are a huge community waiting for something new here...
Please give us some updates...
jarda
Thu Jun 04, 2015 9:10 am
I have lost my faith.
jonashi
Thu Jul 02, 2015 8:49 am
Me too. Sorry to say that. I remember a lot. I was at the first MUM ever. I remember The Dude announcement on MUM Praguje. I remember silence about Dude at tenth MUM in Prague. I have been using Dude till today, however, it seems to be inevitable leave Dude for me now. As I wrote here before, I would be even paying 200 USD for new version and probably I'm not allone in this. I will have to migrate to another system this year.
Basdno
Mon Jul 13, 2015 11:08 am
We would also gladly pay an annual fee or something for an updated and maintained DUDE!
The DUDE is very nice to use, and I do not understand why Mikrotik does not give it more love!
If it is a cost issue, then just set aside/hire own group of developers for The DUDE and make it a separate product, I am totaly sure the userbase of Mikrotik products are big enough and willing to pay for a product like The DUDE if that is what it takes to reignite this project!
So please Mikrotik, RE-BOOT the DUDE PROJECT! It is a testimony in itself that you still have a lot of users YEARS after you stopped developing it!
And I personally do not want to have the hassle of migrating to another solution(But sadly will soon have to seriously consider it after all this time)!
I Love Mikrotik! I love The DUDE! Plz REBOOT! :)
jarda
Mon Jul 13, 2015 11:33 am
It is probably more question of willingness than budget on mikrotik side, I think. Or, they are prepairing some surprise for us. Like with android client - there were some requests for that, huge silence from mikrotik and now: Big bang! it is out, you can test the android client using winbox protocol...
Maybe one day, who knows, maybe there will be one big supersurprise with dude v.5.
I wish.
Basdno
Tue Jul 14, 2015 12:01 pm
We may wish! ;) And if we are lucky the wish might even come true?! :)
miko5881
Fri Jul 17, 2015 4:41 am
I have been monitoring the MikroTik Wiki and I have just noticed that The Dude change log page has just been updated by Krisjanis reverting the last update by Normis removing all the info related to the 4.0 beta and the info for 3.6. Could this mean something is going on?
http://wiki.mikrotik.com/index.php?titl ... ldid=21000
Basdno
Fri Jul 17, 2015 9:42 am
We are allowed to hope! ;) :)
itsupportschulen
Tue Jul 21, 2015 3:56 pm
:wink:
PLEASE open source the code or let us pay for The Dude!
Basdno
Tue Jul 21, 2015 4:51 pm
Awsome picture! :D lool :D :lol:
doush
Long time Member
Long time Member
Fri Jul 31, 2015 1:38 pm
I hope we get the new Dude version soon.
We need to see progress.
The Dude is even better than those paid solutions on the market.
Please put some resources on it.
ste
Fri Jul 31, 2015 1:56 pm
The latest ros packages are no longer upgradable with the dude [CRYING FACE]
jstump
Tue Aug 18, 2015 10:13 pm
Any updates on this?
fabrix
Sat Aug 22, 2015 1:05 am
I hope !!!
Any news ????
HaPe
Tue Aug 25, 2015 11:44 pm
Hi, any update?
In anticipation on new The Dude release.
jarda
Wed Aug 26, 2015 10:08 am
Nothing. Like always.
jebz
Wed Aug 26, 2015 4:12 pm
You need to put it on Kickstarter. I'm sure this would be a good indicator of desire.
jarda
Wed Aug 26, 2015 6:09 pm
They don't need funds. They need the will. None can source the will from kickstarter .
ste
Re:
Thu Aug 27, 2015 11:45 am
Yes. That's the problem.
But as all competitors start to offer cloud based monitoring/management solutions MT will have to have the will.
Newest announcement is from cambium. I prefer the dude and I prefer a local installed system.
But now I cant use the dude for upgrading as packages are no longer compatible ...
dzyan
Thu Aug 27, 2015 4:32 pm
Good day, Is there any way to generate ping graphs on the dude?
Cha0s
Forum Veteran
Forum Veteran
Thu Aug 27, 2015 5:09 pm
If you add the 'ping' service on the device you want, then it will generate graphs based on the ping rtt on the History Tab of the device.
Keep in mind though that it's pretty much not usable since if you have other services also it will monitor them too and the History graphs will become unreadable.
benjamimgois
Sat Sep 05, 2015 8:01 pm
Dear Network Engineers,
i am creating a online petition to ask mikrotik to release The Dude Source code. If you never heard of it, the dude is a extremely powerfull application to manage SNMP networks and devices of any brand. If you like the idea please sign the petition and help us spread the idea.
https://www.change.org/p/mikrotik-relea ... m=copylink
JanezFord
Tue Oct 13, 2015 2:29 pm
For some reason I cant seem to find the dude ppc and mipsbe versions on the download page anymore ... where can I download the dude for ppc and mipsbe?
JF
jarda
Tue Oct 13, 2015 6:02 pm
Dude packages for ros were retracted some time ago due to incompatibility with newer ros versions.
chechito
Re:
Tue Oct 13, 2015 7:07 pm
agree
i have to netinstall some rb2011 and 951g some months ago after installing dude, no more dude on routerboards
snowy1364
Thu Oct 15, 2015 4:30 pm
Any one who is still using the dude and uses an android phone should give this a try: https://play.google.com/store/apps/deta ... wy.thedude
cszolee79
Mon Nov 09, 2015 7:09 pm
Anyone checked The Dude 4b3 with newest ROS?
After upgrading from 6.32.3 to 6.33, the [Device.RosVersion] is missing in network map.
So I have a dozen of Tiks and no idea what version they are.
This makes me a very unhappy dude :(
One... Hundred... BILLION DOLLARS!
sagevorgyan
Wed Nov 18, 2015 8:51 am
Dear cszolee79,
Open Dude settings, go to "Map" tab, open "Device Appearance" and in "Label" part change "ROS:[Device.RosVersion]" to
ROS:[oid("iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrLicense.mtxrLicVersion.0")]
jarda
Wed Nov 18, 2015 1:42 pm
Not a problem with monitoring of 6.33 devices by dude 4b3.
I have just moved the dude from one server to another just by file export - import. It was smooth and without any problems.
abis
Thu Nov 19, 2015 2:25 pm
Dear cszolee79,
Any idea how i can solve this? :)
Image Image
cszolee79
Thu Nov 19, 2015 4:14 pm
Hello sagevorgyan,
Unfortunately this did do the trick :( Still empty. Even the device with 6.32.3
Do I need to download something (oid database?)
http://i.snag.gy/55zM1.jpg
jarda
Thu Nov 19, 2015 6:07 pm
Maybe the combined / individual packages can be the difference. I use individual packages only and do not see any such problem. Try it...
Cha0s
Forum Veteran
Forum Veteran
Re:
Thu Nov 19, 2015 6:25 pm
Same here.
sagevorgyan
Mon Nov 23, 2015 10:28 am
Hello sagevorgyan,
Dear cszolee79,
Yes You need to update "mikrotik.mib" file in "c:\program files\dude\data\mibs" folder.
Download it from Here
heydude
Wed Dec 02, 2015 5:46 pm
Hey Dudes :-)
We are using The Dude as a local monitoring tool for many devices and special snmp probes. It is really a great and very lean program for such a purpose. Since we started using the dude, its data base file got bigger and bigger and we experienced some missbehave of notifications and other stuff. Instead of a fresh clean install we tried to find a way to clean/repair the existing data base. Mainly because the effort for a full regonfiguration would be to high. So, thats how I found this thread, where at the beginning is described to vacuum the dude.db file (defragment it).
As I tried this with sqlite3, I always had the Error of "unique constraint failed". After some diagnosis, I found that the table <chart_values_raw> was corrupted and could not be editted.
So, I tried to get rid of this and found a way to clean it up.
Hope this will be helpful to anyone...
Dude database maintenance/repair describtion:
Preparation:
A1. Close Dude Service und Dude.exe
A2. Download sqlite3 and create the folder \Downloads\sqlite3 https://www.sqlite.org/download.html
A3. Search Dude database file, such as-> C:\Users\"user"\AppData\Local\VirtualStore\Program Files (x86)\Dude\data\dude.db
A4. copy dude.db in Downloads\sqlite3\...
Database maintenance:
B1. start sqlite3.exe
B2. execute <.open dude.db> (open dude.db)
B3. execute <pragma integrity_check;> (perform integrity check)
B4. execute <vacuum;> (defragment database)
B5. in case B3. and/or B4. fails -> go on to "Repair database"
B6. in case both commands run without Error, put dude.db file back in user folder
B7. in user folder, delete any existing <dude.db-journal> and <dude.view> files
B8. start dude and service
Repair database:
<<<All history data will be lost>>>
C1. run cmd with admin
C2. change into sqlite3 directory
C3. execute <echo .dump | sqlite3.exe dude.db > dude.sql> (export dude.db into sql text file)
C4. edit dude.sql file with notepad++
C5. save all lines starting with <INSERT INTO "objs"> into a new textfile <objs.sql>
C5. in user folder delete dude.db , dude.db-journal and dude.view files
C6. start dude (new empty dude.db file will be created)
C7. close dude and copy new dude.db file into sqlite3 folder
C8. start sqlite3 and execute <.open dude.db>
C9. execute <pragma integrity_check;> (check dude.db)
C10. with <delete from objs;> delete entries in objs
C11. with <.read objs.sql> data from objs.sql will be importet into dude.db
C12. <.quit> to close sqlite3
C13. put new dude.db file from sqlite3 folder back into user directory
C14. in user folder, delete any existing <dude.db-journal> and <dude.view> files
C15. start dude and service. all settings will be back, just without history values
C16. as soon, everithing works well, do a backup export out of dude. The new file should be much smaller in size
Users browsing this forum: No registered users and 18 guests
