TKITFrank
RouterOS 5.1 is out!
Fri Apr 08, 2011 6:20 pm
What's new in 5.1 (2011-Apr-08 12:55):
*) ipsec - fix SA lifetime display when timezone offset does not equal 0;
*) ipsec - now default DPD interval is 2 min for new configurations;
*) webfig - make bandwidth-test work;
*) fixed problem - wireless package got disabled after upgrading from v4;
*) sstp - fix problems on multicore systems;
http://www.mikrotik.com/download.html
MTCNA
"I don't believe UNIX is Utopia. It's just the best set of tools around."
Chupaka
Re: RouterOS 5.1 is out!
Fri Apr 08, 2011 6:25 pm
any success on torrent?.. %)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
SeaburyNorton
Fri Apr 08, 2011 6:28 pm
Nothing yet.
It's the typical 4-5 hour wait between the time they release it and it actually becomes downloadable.
willy
Fri Apr 08, 2011 6:34 pm
No success on torrent, no success on web. Maybe this is a "early" release :)
willy
Fri Apr 08, 2011 7:15 pm
Product available on torrent now.
p.s.: after some test ROS terminal may fail on some commands.
Ivoshiee
Fri Apr 08, 2011 9:21 pm
p.s.: after some test ROS terminal may fail on some commands. please install only in testing environment.
It is not possible. The changelog didn't say anything about such changes.
How it is possible to introduce bugs into the code when some one is hacking away on totally other part of it?
It does not show bugs as accidents of coordinated programming, but chaotic messing with the code. Too bad.
willy
Fri Apr 08, 2011 9:58 pm
This bug related to switch chip, maybe another elements not affected (but not tested) cli died after specify a specific command (winbox connection works and i see in profiler the "console process" eats 100% of cpu)
sergejs
Fri Apr 08, 2011 11:42 pm
We are sorry about the HTTP downloads problem, we will try to restore it shortly.
Please, send problematic console commands to support (support@mikrotik.com), thank you very much.
wa4zlw
Sat Apr 09, 2011 12:36 am
FYI - 1736 EDT and can't get to .zips etc
leon
Insider
Sat Apr 09, 2011 1:52 am
ROS 5.1, HDAMA Board 2xCPU Opteron, 1 GB RAM, Intel cards on PCIX 133MHz, Both CPU load 100percent, thruput runs like 40Mbit FDX as max. instead of normal 100-120Mbits with load of some 30percent with 4.16
Something is wrong
Frequency microwave transvertors, design, development, manufacture
http://Pojitko.cz
avantwireless
Sat Apr 09, 2011 5:56 am
LOL, fixed bandwidth test in webfig.... Yep, now can't get into webfig at all.... Good fix... :lol:
normis
Sat Apr 09, 2011 6:29 am
which model of router? what happens exactly? any errors? send screenshot to mikrotik support please
zhhyl
Sat Apr 09, 2011 6:49 am
I can't open download page.. it said page not found.
it's there anyone like this???
avantwireless
Sat Apr 09, 2011 7:05 am
Happens on RB433 and a 450G... Just sits there with the busy bars never gets to the login prompt...
zhhyl
Sat Apr 09, 2011 7:20 am
On download page, there is a dropdown list described 'Please choose download site:'.
Select 'Latvia' instead of 'USA' then download.
HTH,
mmmigoro
Sat Apr 09, 2011 8:37 am
Happens on RB433 and RB750. Can't get in Webfig page.
After clicking Webfig icon in welcome page, it displays "Loading" and a progress bar. The page never loads.
yogii
Sat Apr 09, 2011 8:56 am
why always invalid when i enabled ip service > www in my BR750?
bda
Sat Apr 09, 2011 9:44 am
download is not possible. 404 error in usa site, latvia site - hangs up on download. Pls help.
God bless UNIX!
dhiles
Sat Apr 09, 2011 9:50 am
I upgraded to 5.1 and am still having problems with the wireless radios not working. I have been able to get the 5.8 mhz radio working but the 2.4 is not showing up. It looks like it is activated but it is not broadcasting.
Is anyone still having radio problems after upgrade to 5.1 ??
sobrado
Sat Apr 09, 2011 11:08 am
It happens on a RB750G using OpenBSD 4.9 and Mozilla Firefox too. It hangs on the "Loading..." page as described on this thread by other customers. No way to access webfig for me either.
edit: same on demo2.mt.lv too; tested with Gentoo Linux and Mozilla Firefox, Opera and Chromium.
Steve0
Sat Apr 09, 2011 11:23 am
Does the same for me on a RB450G.
Note: Should this not be RouterOS 5.12RC and not 5.1 Stable? :?
normis
Sat Apr 09, 2011 11:25 am
shouldn't you also use "stable" browser not 5 year old browser with hundreds of bugs? ;)
try Firefox 4, Chome 11, Safari 3, Opera 11 or any other browser from this century.
Steve0
Sat Apr 09, 2011 12:14 pm
Now what Normunds? :shock:
Blame the messenger... :o
Vitis
Sat Apr 09, 2011 1:02 pm
Does the same for me on a RB450.
suse
Sat Apr 09, 2011 1:07 pm
webfig continues loading on firefox4@win7 SP1
would you MT guys test more before release to public?
thanks
mmmigoro
Sat Apr 09, 2011 2:19 pm
If there's any help here is result of a telnet to port 80, and then just hit ENTER:
HTTP/1.0 400 Bad Request
Connection: close
Content-Length: 113
Date: Sat, 09 Apr 2011 11:16:50 GMT
Expires: 0
<html>
<head><title>Error 400: Bad Request</title></head>
<body>
<h1>Error 400: Bad
Request</h1>
</body>
</html>
Connection to host lost.
yogii
Sat Apr 09, 2011 2:24 pm
thanks
there is no one perfect in this wold, please downgrade your ROS if you are not comfortable. :lol:
i will be patient to wait for new release.
avantwireless
Sat Apr 09, 2011 4:57 pm
Well, we use what is "released" with the OS... So far Fedora is not putting out Firefox 4... and Chrome 11 shows exactly the same problem...
I know it hurts to have a bug like this in a bug fix... But I really don't like being told that there is a work around ( even in jest ) and it doesn't work either.
ojsa
Sat Apr 09, 2011 5:51 pm
Upgraded RB1100 to 5.1 worked fine, earlier problems with switch-chip and vlan are now gone.
RB800 (two of them) crashes every 30 second with kernel somthing. RB493ahg stopped responding (haven't checked this with console yet)
But on the brightside several RB450g worked fine.
All units upgraded from 4.17 or 5.0 and all packages without gps, ups and ipv6 enabled. All units with almost basic config.
Network professional - Certified MTCNA, MTCWE MTCTCE, MTCRE, MTCUME and MTCINE. - Wiki Profile
willy
Sat Apr 09, 2011 6:12 pm
Sergejs! I'm _always_ send detailed support request, and _if_ problem serious post here to prevent mass problems.
(a little bit upset)
In some cases if MT team not respond, and the problem important to me also post, but after a week or so.
But now i post, because sometimes devices unable tor reach with winbox (because this is a desktop tool(need graph terminal), and because windows only/okay okay run under wine/) and if anybody lost control of their device, will be a great problem.
I also send 3 of other tickets also unanswered, but not discussed here. Some of this tickets appeared in forum as bug report after i send support request from other users (mistake, forum is not official support, but now users can't see detected problems submitted or not -- a public bug reporting system welcome)
If i wrote a support request always get 3 types of answer:
1, problem is a hardware limitation (but this limitation never informed before)
2, "please test it in this situation" (but seems the problem reproducible) I really think: all report entered to PEBKAC state and after anyone could prove this problem is a real problem might be change this status)
3, problem reproducible, working on solution (but if completed this task not informed)
In this situation: This problem related to switch chip and i report a support request(first reply: please give a packet log(answer type 1) and after "yes reproducible, works on" (type 3). After two week silence i post here, and Normis promise looking into it. After i receive a message from Krishteins, this problem solved in 5.1, and ask i want to test pre release before release? I answered: yes, if possible.
After that i not received pre release, receive a release (5.1).
Im really happy, and will test it development environment. I found this console bug, immediately write this post above, and submit support request to mikrotik some delay after because i want to send supout.rif but generation never ending.
(p.s.: vlans seems to still broken, but cannot test it)
Sanity
Sat Apr 09, 2011 7:24 pm
Connection: close
Content-Length: 113
Expires: 0
<html>
<body>
<h1>Error 400: Bad
Request</h1>
</body>
</html>
This is normal. HTTP does expect ou to isue a GET, not just a CRLF after connecting. This technically IS a bad request.
For the most basic HTTP 1 request telnet to port 80, then
GET /
Enter
Jeroen1000
Sat Apr 09, 2011 9:53 pm
I'll post my Q here too, has the VLAN-bug been resolved now (mentioned here)
babbage
Trainer
Trainer
Sun Apr 10, 2011 8:18 am
Download link http broken...
I have sent memory leak and unusual behaviour of MK reports to MK support though. Ticket numbers #2011041066000044 and #2011032666000151
I had a happier life with RC and beta versions of 5! As I have different HWs with lots of concurrent PPPOE users, I think it would be a good idea for you guys to be more cautious on upgrade though there is really no earlier stable version of 5 supporting multi core CPUs.
I see most of people upgrading to test the new v5 look for wireless features.
petst
Sun Apr 10, 2011 11:17 am
Here with RB450G, the LAN-LAN speed dramatically goes down from about 40-50Mbit to 3-4Mbit. I go back to 4.17 :shock:
engineertote
Sun Apr 10, 2011 12:27 pm
i have fool question :)
RB1100 i can not see it in the RB series selections in the download page ,, can i use same 1000 series ?
Ahmed
MTCNA , MTCTCE , MTCRE , MTCINE
babbage
Trainer
Trainer
Sun Apr 10, 2011 1:27 pm
It's all 1000 series works for 1100 as well.
babbage
Trainer
Trainer
Mon Apr 11, 2011 7:21 am
Download links working now...
kirshteins
Mon Apr 11, 2011 8:23 am
Please send autosupout.rif files to support@mikrotik.com
kirshteins
Mon Apr 11, 2011 8:34 am
What configuration, network setup and type of traffic?
sergejs
Mon Apr 11, 2011 9:06 am
Webfig issue is confirmed, it does not work on all boards. We are working on the fix.
Thank you very much for your reports.
ditonet
Forum Veteran
Forum Veteran
Mon Apr 11, 2011 11:51 am
@sergejs
What about bugs mentioned here:
http://forum.mikrotik.com/viewtopic.php?f=1&t=50744
http://forum.mikrotik.com/viewtopic.php?f=1&t=50697
Are you able to reproduce them?
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
sergejs
Mon Apr 11, 2011 12:00 pm
@sergejs
Regards,
I have replied to both forum threads. Thank you very much for your reports.
Please, contact our support department, as we need more information from you.
petst
Mon Apr 11, 2011 1:33 pm
Default config, with little changes:
Traffic is between ether2 and ether 3 port, type is video streaming (media player-ether2 and home pc-ether3).
killersoft
Mon Apr 11, 2011 2:37 pm
Just upgraded my 750G from 4.17 to 5.1 stable, and IE8 doesnt open the webconfig.
See attached pic, with the error that IE8 thinks the html page has..
MTCNA
MIT, BIT,CERT IV Electronics.
ITIL
sergejs
Mon Apr 11, 2011 2:40 pm
Thank you very much for the report.
Please, look for the previous posts to avoid dobleposting. The Webfig problem is confirmed and it will be fixed in the next RouterOS version.
edris
Mon Apr 11, 2011 3:38 pm
what about this problem ...
http://forum.mikrotik.com/viewtopic.php?f=10&t=50623
why user manager profile start just after assign it to user not after "user first loin" on 5.1 version??
sergejs
Mon Apr 11, 2011 3:44 pm
Currently there is only one option, that profiles starts "now", other options are not available.
alexspils
Tue Apr 12, 2011 10:10 am
when i do telnet(not mac telnet) from wireless registration table at AP side it shows this:
telnet: inet_pton failed for 00:00:00:00:00:00/telnet: Success
Trying 00:00:00:00:00:00...
Connected to 00:00:00:00:00:00.
Escape character is '^]'.
MikroTik v5.1
Login:
its normal?
ekkas
Long time Member
Long time Member
Tue Apr 12, 2011 3:59 pm
I had an issue with ROS 5.0 where when a hotspot was on a bridge with wlan and ether ports, some laptops would not see the hotspot. (no login)
Anyone know if this is fixed? I cannot test as it only happen with some (especially Vista) laptops, and the hotspot in question have many paid users with partially used vouchers.
4.17 works fine, but I need to upgrade soon as the uplink is nv2 ready.
With upgrade we'll have to bite the bullet but I cannot aford to upgrade/downgrade in case of troubles.
Freqman
Tue Apr 12, 2011 4:43 pm
Upgraded an rb800 from 4.17 with 2.30 firmware to 5.1 and radio board is completely unstable. It drops pings to the router it is plugged into has Kernel failures. Found "" as the current firmware and after a reboot it would show 2.30 and after another reboot it showed 2.29. had to take it to 4.17 after it hard locked and had to go powercycle it at a tower. Ticket submitted.
Had similar issues with another rb800.
ekkas
Long time Member
Long time Member
Tue Apr 12, 2011 4:48 pm
I had that missing firmware as well before. Either upgrade again and see, or do netinstall.
CristianDeluxe
Tue Apr 12, 2011 6:47 pm
I've updated from 5.0 to 5.1 this morning and now i have cpu 100% all time with low traffic, same config and clients working with 5.0 with CPU at 1-10%, i'am alone with this issue?
Freqman
Tue Apr 12, 2011 8:38 pm
The 2 RB800's that are giving me problems both have child AP's off a dedicated card using WDS.
I found that if I change the child AP to station WDS the reboots and dropped packets stop. I'm not using NV2. Just straight .11A
I upgraded about 5 other APs to 5.1 with no issues the same time yesterday but none of them are using a WDS bridge.
Hope this helps MT guys, please advise.
ekkas
Long time Member
Long time Member
Tue Apr 12, 2011 9:03 pm
Aha!
The problems I had with Hotspot on bridge (ports=wlan+ether) is also that the wlan is on WDS with another AP-bridge...
Maybe that is the issue... WDS!
Freqman
Tue Apr 12, 2011 10:00 pm
So is anyone using 5.1 with WDS and VLAN over it?... Ap Bridge>Bridge, Bridge>Bridge, AP Bridge> WDS Slave, Bridge>WDS slave? If so Board and Cards?
Solaris
Wed Apr 13, 2011 12:10 am
When issuing /export on the terminal it's completely locks up the terminal, both inaccessible on serial terminal or the winbox terminal, also cpu load goes sky rocket into 100% and stay on this state forever unless a hard-reboot(plugging off the power manually), iam on 450g.
Yet the internet access, filtering & logging pretty lag down to 5-15% when this happening.
ditonet
Forum Veteran
Forum Veteran
Wed Apr 13, 2011 12:29 am
This problem or potential bug was mentioned here:
http://forum.mikrotik.com/viewtopic.php?f=2&t=50744
HTH,
dainen
Wed Apr 13, 2011 4:43 am
Flashfig and webfig are also broken with 5.1
webfig seems to work perfectly on 5.0
dssmiktik
Forum Veteran
Forum Veteran
Wed Apr 13, 2011 7:25 am
As reported, I also cannot access webfig in v5.1 on x86.
Doug
sergejs
Wed Apr 13, 2011 11:05 am
Thank you very much for the reports about sup-output and /export.
We have found the problem and working on the fix, it will be fixed in the next RouterOS version.
ekkas
Long time Member
Long time Member
Wed Apr 13, 2011 8:46 pm
5.1 also definately have a problem with bridging.
I have RB493AH
to
SXT via LAN port
the SXT have bridge with the LAN and wlan as ports, connecting to a RB493AH+R52Hn
Ping times even to LAN is erratic, from 5-20ms, ave 15ms.
Winbox times out/disconnect every few minutes.
SXT is just a link between the two routers, the 'local' one via LAN, the 'remote' one with wlan.
removed the bridge, made two subnets and just routed it and all is fine, LAN pings 0 or 1 ms again.
ekkas
Long time Member
Long time Member
Wed Apr 13, 2011 10:21 pm
Also a small bug with MAC telnet.
If I IP telnet and then close window, try to MAC telnet, it gives error MAC TELNET 192.168.0.2 (last IP), bad address. So it it trying to use the previous IP as a MAC address, not the MAC I typed in.
Freqman
Thu Apr 14, 2011 4:28 pm
I have RB493AH
to
SXT via LAN port
I 2nd this. I was having ether pings drop and kernel failures on an AP when it had a WDS bridge off one of the cards. Switched child to station WDS rather than WDS slave and all problems went away. MT please give us some assistance with a fix! Thanks!
nenapop
Fri Apr 15, 2011 10:17 pm
Simms to me, a version 5.0 is better then this 5.1
Freqman
Fri Apr 15, 2011 10:25 pm
I agree. 5.1 should not be used on an 800. I am going back to 5.0 I have 4 APs that have had Kernel failures. Not good not good at all.
duncrow
Fri Apr 15, 2011 10:31 pm
5.1 on a 750G
Connect via ssh/telnet and type "interface ethernet switch ?" and ALL(!) ssh/telnet sessions will freeze instantly.
No new ssh/telnet session possible, traffic keeps flowing through the box. Only solution I've found so far is to power-cycle the box. Can anyone confirm this behaviour?
tenenbaum
Sat Apr 16, 2011 3:18 am
In version 4 the torch window had a separate column for dest and src ports. Since version 5 it is combined with the address. When you use torch to research connections, it is very hard to see what is going on because of that.
Is it possible to add back the the two columns so that the ports can be displayed clearly and sorted by?
We asked this before and were told that Mikrotik would look into it. I talked with other users and they all seem to agree that it is missing.
nenapop
Sun Apr 17, 2011 6:06 am
Where can we find a old versions of RouterOS? On the download page, there is only 4,17v and 5.1. I need 5.0!!!
lkaroly
Sun Apr 17, 2011 7:37 am
Something not good in this version ,I upgraded two RB450G -s and all two freezes one about one hour later and the other one day later but all two did the same thing , not accesible ,abfter power cycle everything goes right , but i downgradet to ver 4.17.
duncrow
Sun Apr 17, 2011 7:45 am
Just copy the downloadlink for your device, paste it in your browser and change the version "by hand", e.g. from http://download.mikrotik.com/routeros-mipsbe-5.1.npk to http://download.mikrotik.com/routeros-mipsbe-5.0.npk and press enter.
prawira
Trainer
Trainer
Sun Apr 17, 2011 6:45 pm
Just upgrade my RB1100 with v5.0 and try webfig.
the configuration only "ip dhcp-client" and "system ntp-client"
and the traffic on the eth interface quite high (about 100K); not like what normis show us on MUM in Jakarta. I watch it about 5 minutes and it still stay above 100K and no winbox loaded.
ekkas
Long time Member
Long time Member
Mon Apr 18, 2011 5:08 am
Just had an issue where RB493AH after about 5 days uptime with ROS5.1 stopped responding i.t.o. login.
Could not log in via Winbox, Telnet, SSH nor API.
Traffic still flowed though.
Subsequently could not make new supout and a road trip followed by hard-reboot was only option.
I see there is an autosupout, sending to support...
uldis
Mon Apr 18, 2011 9:26 am
could you send your support output file to support@mikrotik.com and also the configuration of the setup so we could reproduce your problem?
Trisc
Mon Apr 18, 2011 2:31 pm
Just need to be sure - can I upgrade from 4.1x using wireless-nv2 package to 5.1 without having to install wireless package separately?
We had this problem before when upgrading - if wireless-nv2 was running the upgrade to 5.xxRC ignored it leaving wireless disabled.
arpadffy
Wed Apr 20, 2011 3:00 pm
5.1 on a 750G
This is exactly what happened to me (5.1 on RB450G) just I did not realize that in fact the last command was interface ethernet switch ?
http://forum.mikrotik.com/viewtopic.php?f=13&t=51059
Regards,
Z
thrower
Wed Apr 20, 2011 11:56 pm
I've just noticed a problem with firewall filter... ::edit:: which was caused by lack of sleep ;/
fewi
Thu Apr 21, 2011 12:03 am
Those rules would also block all return traffic to 192.168.1.114, since the source IP of a return packet would be whatever 192.168.1.114 contacted in the first place. Either also allow all traffic with dst-address=192.168.1.114, or - preferably - higher up accept all traffic with a connection-state=established and connection-state=related.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
thrower
Thu Apr 21, 2011 12:04 am
Yea, I just came with the same idea at the second when I pushed "Submit"...
Shame on me :shock:
jonmansey
Thu Apr 21, 2011 10:58 pm
seems bridge filters dont work in v5.1, anyone confirm this?
honzam
Fri Apr 22, 2011 2:26 pm
5.2 today? or?
LAN, FTTx, Wireless. ISP operator
mtmx80
Sat Apr 23, 2011 8:42 pm
I can reproduce this issue too. This is the console 100% CPU usage issue too. In such case you can still log in using WinBox and manage router from there. (reboot)
5.1 on a 750G
rboerom
Sat Apr 23, 2011 8:47 pm
I AM HAVING VERY SLOW PERFORMANCE ON THE NEW USER MANAGER ON 5.1
really nice new features, but very slow web performance.
ToMikaa87
Mon Apr 25, 2011 11:14 pm
5.1 on a 750G
The same here in serial console, ssh and winbox terminal too. Profiler says the "console" process is eating up the CPU.
Additionally I have the bridging problem (very slow LAN-LAN speed [~8 Mbits/s on gigabit]). Hardware switching speed is about 220 Mbits/sec instead of full line speed.
EarthStation
Tue Apr 26, 2011 10:59 am
http://download.mikrotik.com/all_packages-ppc-5.0.zip
http://download.mikrotik.com/all_packag ... be-5.0.zip
EarthStation
Tue Apr 26, 2011 11:20 am
When trying to run a snooper from the Wireless Tables interface dialog (v5.1 and 5.0), RB800 reboots and first log message after reboot is "System rebooted because of kernel failure"
This does NOT occur when the individual wireless interface is opened and the snooper is run from there. It only occurs when the Wireless snooper button shown below is used.
Webfig does not get to login screen when trying to load on this RB800. Using version 4.0 Firefox.
I have reverted to 5.0, will await 5.2 :)
honzam
Tue Apr 26, 2011 6:45 pm
Where is broadcast in release 5.x? It's very useful information
pbr3000
Tue Apr 26, 2011 9:50 pm
+1
It was striped out in v5, but the info was very useful sometimes.
kirshteins
Wed Apr 27, 2011 8:15 am
5.1 on a 750G
The problem with console consuming all the CPU resources will be fixed in v5.2.
kirshteins
Wed Apr 27, 2011 8:39 am
Please generate and send supout.rif or autosupout.rif file to support@mikrotik.com, right after kernel failure.
Webfig will be fixed in v5.2.
ToMikaa87
Thu Apr 28, 2011 9:37 am
And what about the very low bridging and switching speed issue? Will it be fixed soon?
kirshteins
Thu Apr 28, 2011 11:15 am
What are the steps to reproduce this problem? Please send this report along with supout.rif file to support@mikrotik.com.
ToMikaa87
Thu Apr 28, 2011 4:08 pm
I cannot create a supout.rif because console process hangs during creation. I think it's related to the console bug mentioned before.
The throughput bug can be reproduced by creating a bridge that contains all ethernet interfaces except ether1 which is the WAN port. The WAN-LAN connection is working properly (the internet connection's maximum speed can be reached, in my case ~20 Mbits/sec), but LAN-LAN speed is below 5 Mbits/sec between two hosts that are connecting via gigabit line.
The switching speed problem can be reproduced by setting up slave ports (ether3-ether5) and ether2 as a master port. In this case the ether1 was removed from the hardware switch and used as WAN port. The maximum LAN-LAN speed with this setup was ~250 Mbits/sec. With the legacy ROS (4.10) it was ~600 Mbits/sec with bridging.
kirshteins
Thu Apr 28, 2011 4:19 pm
Please upgrade to v5.2 and test again. It contains fix for supout.rif generation as well.
ToMikaa87
Thu Apr 28, 2011 4:57 pm
I can confirm that supout generation and console is working again. Bug report was sent with the support file.
Users browsing this forum: Edoras, poduck, sistelec and 106 guests
