MUM Europe 2020
namo
Long time Member
Long time Member
Winbox Safe mode
Sat Apr 09, 2011 1:32 pm
What is the Safe mode in Winbox do? I haven't notice something different when I click on it
SurferTim
Re: Winbox Safe mode
Sat Apr 09, 2011 1:35 pm
Any changes made is safe mode will not be permanent. When you log out or disconnect Winbox, the changes made during that Winbox session will revert back to the original values. It is used for testing things that might cause a lockout, like new entries in "/ip firewall filter".
normis
Sat Apr 09, 2011 1:42 pm
yes, basically if you break something during safe mode, it will undo all changes, so you don't lose access to the router. if you don't break anything, you can permanently apply the made changes by exiting the safe mode.
maxumi
Fri Nov 22, 2013 12:43 pm
it's possible activate the Safe Mode for all access in default. and take it out only on request?
sorry for my english
amt
Long time Member
Long time Member
Tue May 05, 2015 11:49 pm
hi normis,
is possible to get down undo time ? i think when lost the connection it 9 min to undo them... is possilbe to make it lower ?
prawira
Trainer
Trainer
Fri Apr 29, 2016 5:19 am
i am connecting via wireless to my CRS (RoS 6.35), open winbox and click Safe Mode.
than i do disable the interface wlan1 and surely i got disconnected with my CRS.
after long waiting (about 15 minutes), the wlan1 stay disable and i have to connect with cable to enable it again.
Q: how actually the safe mode works on winbox ? or is it one of winbox 3.4 bug ?
Paul
Fraction
Tue May 03, 2016 12:03 am
This definitely should be an default option. :)
nxs02
Tue May 03, 2016 5:33 am
Paul
yeah agree with u, sometime in some cases, safe mode doesnt help undo the problems
prawira
Trainer
Trainer
Wed May 04, 2016 5:30 am
the ROS used is 6.35.1
the "safe mode" work fine on console mode, but not on winbox.
hasn't try on webfig yet
P
Delete
Mon May 23, 2016 7:50 pm
I can confirm mikrotik 6.35.2 safe mode winbox does not revert changes even on restart.
normis
Tue May 24, 2016 12:40 pm
Can you both please describe which RouterOS version you used, and also which OS you used Winbox on (Windows, other)
DotTest37
Tue May 24, 2016 8:29 pm
On Winbox doesnt work well.
I was remotely logged in, used Safe Mode, deleted the WAN interface, obviously got kicked out.
Instructed a helper to reboot the Router (unplugging/plugging the PSU) and the WAN interface never came back.
Went physically next to the router and plugged an ethernet cable, used the LAN interface and I see the WAN interface is not there,
Added the WAN interface and everything came online.
Doesnt protect you much from deleting stuff and then asking a person on the remote site to reboot the router.
Im using Winbox 3.4 on RouterOS 6.35.2 running on a CRS125-24G-1S
haik01
Wed May 25, 2016 2:45 pm
I have the same problem. I was connected by a PPTP connection to a remote Omnitik. I enabled Safe mode, changed the IP address on an ethernet port, and Winbox disconnected after a couple of seconds.
Now I have no connectivity at all. :?
Winbox version 3.4, Router OS is 6.35.2
normis
Wed May 25, 2016 3:19 pm
and Windows version?
haik01
Wed May 25, 2016 3:23 pm
Windows 7 Proffessional, SP1
haik01
Wed May 25, 2016 7:12 pm
Well, the link came back after 20 minutes, and I was able to login.
It is a pretty long time. Can the time be set to lower that?
In my Ubiquity Nano station M2, the "timeout" is 15 seconds. Which is sometimes too short, but 1 minute would be fast enough for Mikrotik.
Can that be a setting added in Winbox in the next release? For example, if you press Safe mode button, a new window will appear where you can fill in the minutes (or seconds) to wait for a response....
freemannnn
Long time Member
Long time Member
Wed May 25, 2016 8:01 pm
i prefer a general way to set Safe mode time. and not to have to set it every time u press safe button.
Delete
Wed May 25, 2016 9:55 pm
version 6.35.2, windows 10 pro 64.
I had access to mikrotik trough vlan i disabled the vlan by mistake while in safe mode and lost access
i waited 30 min still no access, i reboted the router still no access
had to use console to enable the vlan.
This was on CRS125-24G-1S.
prawira
Trainer
Trainer
Wed Jun 01, 2016 2:32 pm
dear normis,
i am using Ubuntu with wine, RB433AH and CRS125-24G-1S-2HnD-IN with ROS 6.35.2
on console, the config will revert after 20 seconds disconnected
on winbox (v3.4), the config never revert after waiting for 1o minutes..
P
ubimikro
Tue Jun 28, 2016 1:20 pm
same here with metal2 SHPn running 6.35.4 and winbox v3.4.
safe mode does not revert to previous settings (e.g. wlan client mode changed).
mikrotik please have a look at ubiquiti's solution for safe-mode. it's better in my oppinion.
wish:
-) safe mode by default
-) shorter/selectable timeout
-) bug-free implementation ;)
DotTest37
Tue Jun 28, 2016 3:57 pm
I dream too
lazerusrm
Tue Jun 28, 2016 9:42 pm
Seriously.. This just cost me 2 HOURS OF DRIVING.
Sheesh. fix the stupid button already. Wifi auto scanned, lost connection.
This is a joke guys, c'mon.
amt
Long time Member
Long time Member
Wed Jun 29, 2016 10:53 am
Im using Winbox V2.2.18 and Both of the version 6.35.2 and 6.35.4 there is no problem on Safe mode.
loma
Mon Jul 04, 2016 11:51 am
I had the same issue.
I was in Safe Mode, while testing I've disabled the WAN interface by accident, off course it disconnected me but never reconnected again. So Safe Mode doesn't work.
The router is 951G-2HnD, firmware v3.24, routerOS v6.32.4.
OS is Windows 7 Pro 64bit (fully updated), Winbox v3.4.
Please fix this, now I need to drive there and lose a lot of time...
el berto
Tue Dec 05, 2017 10:55 am
Any updates?
I'm working with different ROs versions (some RB using 6.19 and others 6.34), I have big troubles with RSTP and I'm not sure I can get connection with remote device if changing some parameter......
Why don't do this:
- Safe Mode OFF = pressing any OK or Apply buttons, configuration is stored
- Safe Mode ON = pressing OK configuration is set, but not stored permamently, pressing Apply configuration is stored permanntly
Or set a timeout somewhere....
sleerf
Mon Apr 15, 2019 4:40 pm
Planning to make some changes remotely and I need to know if this "bug" is still a problem or if safe mode working remotely in winbox 6.44.1 in win10 with a CCR 1009 8G 1S 1S+ is truly "safe". One thing I noticed is that by default "Autosave on Close" is checked and I'm wondering if this might be the root of the problems experienced by others.
Another question about this is how and where the settings changes are stored when in safe mode. I know there is a backup configuration but I'm using that as the primary because for some reason the primary config kept failing and "forgetting" it's configuration. So I set it to boot to the backup config by default. No problems since but if "safe mode" uses the backup configuration. that could be a problem.
I know this is an old thread but I REALLY need to know if I can trust this to work or not. I need to build a bridge across a couple ports and apply the changes and test it but if it breaks the configuration then 300+ customers will be down for several hours. If I can trust "safe mode" to revert the changes if I break it, then I can do this tonight. Otherwise it will have to wait several days.
icttech
Sun Sep 29, 2019 3:00 pm
Safe Mode: Can anyone respond as I have the same situation where we have routers that sit in Data Centers and can be an hour or 2 away in heavy traffic..?
(6.45.6)
Users browsing this forum: MSN [Bot] and 76 guests
