MUM Europe 2020
oreggin
v5.1 hangs in /export
Sat Apr 09, 2011 9:52 pm
I have two routerboard. RB433AH and RG450G. Both hangs when I issue the /export or /interface export command:
[admin@RB433AH] > /interface export
# jan/02/1970 07:36:19 by RouterOS 5.1
# software id = XXXX-XXXX
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526 mac-address=00:0C:42:2F:8A:8F mtu=1500 name=ether1 speed=\
    100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=yes full-duplex=yes l2mtu=1522 mac-address=00:0C:42:2F:8A:90 \
    master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=yes full-duplex=yes l2mtu=1522 mac-address=00:0C:42:2F:8A:91 \
    master-port=none mtu=1500 name=ether3 speed=100Mbps
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes disabled=no forward-delay=15s l2mtu=1526 max-message-age=20s mtu=\
    1500 name=bridge priority=0x8000 protocol-mode=none transmit-hold-count=6
/interface ethernet switch
...hang...
Then I can't login to the routerboard with any method:
$ telnet 192.168.5.2
Trying 192.168.5.2...
Connected to 192.168.5.2.
Escape character is '^]'.
MikroTik v5.1
Login: admin
Password:
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 5.1 (c) 1999-2011       http://www.mikrotik.com/
...hang...
What happens?
ditonet
Forum Veteran
Forum Veteran
Re: v5.1 hangs in /export
Sun Apr 10, 2011 11:37 am
Confirmed on my RB433AH
Console process eats up to 100% CPU and make router unresponsible to telnet and SSH.
Only reboot via Winbox helps in this case.
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
sergejs
Mon Apr 11, 2011 11:58 am
For support from Mikrotik staff, write to support@mikrotik.com - Mikrotik does not generally offer support on the forum, this is a user forum.
Please, send us report with your configuration support output file.
I have tried export on my RB433, it works fine for me. So there is specific configuration, which does not work properly on export.
janisk
please send supout.rif files to support.
ditonet
Forum Veteran
Forum Veteran
Mon Apr 11, 2011 12:51 pm
I started creation of 'supout.rif' 30 minutes ago and I'm still waiting for finish.
How long this process could be?
Regards,
alexspils
Mon Apr 11, 2011 12:52 pm
do it from telnet
ditonet
Forum Veteran
Forum Veteran
Mon Apr 11, 2011 1:01 pm
It's ready, after 40 minutes :)
Regards,
sergejs
Mon Apr 11, 2011 1:03 pm
I did it from telnet on my RouterBOARD 433.
Both commands worked without any problems.
export
system sup-output
ditonet
Forum Veteran
Forum Veteran
Mon Apr 11, 2011 1:33 pm
Maybe this is a relation between these two problems.
During creation of 'supout.rif' file and after finish, 'console' process was 99-100%.
There was need to restart router.
Regards,
sergejs
Mon Apr 11, 2011 1:37 pm
ditonet, yes you are correct.
We need to find out, which piece of configuration causes the particular problem.
dataway
Mon Apr 11, 2011 7:57 pm
I have the same issue (RB450G), should I also send in the supout.rif?
oreggin
Mon Apr 11, 2011 10:39 pm
I started the sup-output process for 2 hours. I hope it will finish till I should go to work...
oreggin
Tue Apr 12, 2011 12:26 am
It's still running...
oreggin
Tue Apr 12, 2011 11:19 am
I can't generate supout.rif but I will try again today...
nz_monkey
Tue Apr 12, 2011 11:33 am
Not sure if it is related, but RB1100's spike to 100% when generating a supout.rif and do not appear to go down
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
sergejs
Tue Apr 12, 2011 3:23 pm
oreggin and nz_monkey, please contact support with support output file from the router.
oreggin
Tue Apr 12, 2011 3:51 pm
Ok, I will send e-mail to support soon.
Solaris
Wed Apr 13, 2011 9:28 am
My 450g also got this problems, support.rif sent.
oreggin
Wed Apr 13, 2011 11:02 am
I can't generate supout.rif :(
I was tried over SSH and serial console...
sergejs
Wed Apr 13, 2011 11:03 am
Thank you very much for your reports.
We found the problem and working on the fix. It will be fixed in the next RouterOS version.
ditonet
Forum Veteran
Forum Veteran
Wed Apr 13, 2011 12:06 pm
@sergejs
Thanks for information.
Regards,
Cupholder
Sun Apr 17, 2011 11:51 pm
I registered on the forum to report hitting this bug as well on my 750G. Glad that Support was able to reproduce the problem.
tanjil
Sat Apr 23, 2011 10:06 pm
cant reboot the Os properly.. it takes 10 or 20 mins time ... after restart the router /sys log Kernel failure....
how to solve this...
i have send the supout file already
thanks
Mrvn
Tue Apr 26, 2011 3:10 pm
I can confirm that on RB750. You can't do /export or support.rif -> router hangs.
normis
Tue Apr 26, 2011 3:11 pm
it's a known issue confirmed many times here. v5.2 will fix it.
arpadffy
Tue Apr 26, 2011 3:15 pm
do you have any estimation when the 5.2 will be released?
Thank you.
Regards,
Z
normis
Tue Apr 26, 2011 3:19 pm
we will try to release it this week, if all known issues will be fixed and tested
tanjil
Fri Apr 29, 2011 3:54 am
same problem occured on 5.2 version .. its not fixed yet
normis
Fri Apr 29, 2011 7:47 am
what is not fixed? export works fine now.
Users browsing this forum: MSN [Bot] and 60 guests
