larmaid
[req] 2.9.6 spyware n virus ports
Tue Oct 25, 2005 10:31 am
anyone knows the spyware n virus port....?
and how can we block them in mikrotik....is it in forward...!
i like it
andrewluck
Forum Veteran
Forum Veteran
Tue Oct 25, 2005 1:19 pm
There are various lists of ports used by viruses and worms available on the Internet and they're getting longer by the day.
A far better approach is to determine the traffic that your network is legitimately using and then set rules to allow that traffic and deny everything else.
Regards
Andrew
larmaid
Thu Oct 27, 2005 12:22 pm
thx andrew....!
i ve blok every port except 80 for http..!
the script is like this
ip firewall>add src-address=10.10.0.0/16 dst-port=!80 action=drop chain=forward
why is port 80 also drop....?
i like it
yancho
Thu Oct 27, 2005 1:44 pm
Your internet is for free? Droping all except standart web port is very cruelly...
You should specify port, like /ip firewall filter add src-address=10.10.0.0/16 dst-port=!80 action=drop chain=forward protocol=tcp
lastguru
Trainer
Trainer
Thu Oct 27, 2005 1:58 pm
thx andrew....!
because you did not specify the protocol
International MikroTik Certified Trainer and Consultant form Latvia.
I do RouterOS Training and Certification worldwide!
skype: lastguru
normis
Thu Oct 27, 2005 2:01 pm
yes, you don't allow your users to use email and ftp? how about secure websites like banks?
larmaid
Sun Oct 30, 2005 4:05 pm
thx for the answer......im sorry i did spesifik the protocol soo this is my original script....:
ip firewall>add src-address=10.10.0.0/16 protocol=tcp dst-port=!80 action=drop chain=forward
still port 80 also drop......? :(
@normis yes i want to let other port to allow like 25 n 110 but i want some user cannot use anything except internet(80)...!
btw what is the diffrent input and forward.....and web-proxy...!
i like it
andrewluck
Forum Veteran
Forum Veteran
Sun Oct 30, 2005 7:17 pm
You need to allow the return traffic with rules similar to these:
28   ;;; Accept Internet Established
     chain=forward in-interface=Internet connection-state=established
     action=accept
29   ;;; Accept Internet Related
     chain=forward in-interface=Internet connection-state=related
     action=accept
larmaid
Sun Oct 30, 2005 8:07 pm
do i need to enable or disable ip proxy....?
i like it
wildbill442
Sun Oct 30, 2005 8:34 pm
Here's a list of protocols I allow for restricted free use areas...
add chain=guest-network connection-state=invalid action=drop comment="Drop Invalid" disabled=no
add chain=guest-network connection-state=established action=accept comment="Accept Established" disabled=no
add chain=guest-network connection-state=related action=accept comment="Accept Related" disabled=no
add chain=guest-network protocol=tcp dst-port=80 action=accept comment="HTTP" disabled=no
add chain=guest-network protocol=tcp dst-port=20-21 action=accept comment="FTP" disabled=no
add chain=guest-network protocol=tcp dst-port=110 action=accept comment="POP3" disabled=no
add chain=guest-network protocol=tcp dst-port=25 action=accept comment="SMTP" disabled=no
add chain=guest-network protocol=udp action=accept comment="UDP" disabled=no
add chain=guest-network protocol=tcp dst-port=5190 action=accept comment="AIM" disabled=no
add chain=guest-network protocol=tcp dst-port=443 action=accept comment="SSL" disabled=no
add chain=guest-network protocol=tcp dst-port=1863 action=accept comment="MSN Messenger" disabled=no
add chain=guest-network protocol=tcp dst-port=6891-6901 action=accept comment="MSN Messenger" disabled=no
add chain=guest-network protocol=tcp dst-port=143 action=accept comment="IMAP" disabled=no
add chain=guest-network protocol=tcp dst-port=993 action=accept comment="IMAP-SSL" disabled=no
add chain=guest-network action=log log-prefix="Guest Chain" comment="Log Dropped Packets" disabled=no
add chain=guest-network action=drop comment="Drop Everything" disabled=no
That will only allow those specified ports to be used on the guest network.. If you want to allow all outgoing connections, but block any incoming it would look something like this...
add chain=customer connection-state=invalid action=drop comment="Drop Invalid" disabled=no
add chain=customer connection-state=established action=accept comment="Accept Established" disabled=no
add chain=customer connection-state=related action=accept comment="Accept Related" disabled=no
add chain=customer in-interface="LAN" out-interface=WAN action=accept comment="Accept Outgoing Connections" \
    disabled=no
add chain=customer action=log log-prefix="Customer Chain" comment="Log Dropped" disabled=no
add chain=customer action=drop comment="Drop and log everything else" disabled=no
If you don't have the "accept established" and "accept related" your clients for example would be able to send packets out on port 80 but the packets returning would be dropped because they're coming back on a dynamic port that isn't allowed in the firewall...
jager
Trainer
Trainer
Mon Oct 31, 2005 3:31 am
I think that simply dropping all traffic on ports 135,137,138,139,445 (tcp and udp) will do the job :)
larmaid
Mon Oct 31, 2005 6:02 pm
thanx a million @wildbill442 n @jager.....!
the script works....... :D
i like it
larmaid
Mon Oct 31, 2005 11:30 pm
@wildbill442 >
1. chain=forward ; connect-state=invalid ; action=drop
2. chain=forward ; in-interface=wan ; connect-state=established ; action=accept
3. chain=forward ; in-interface=wan ; connct-state=invalid ; action=accept
4. chain=forward ; protocol=tcp ; dst-port=80 ; in-interface=lan ; out-interface=wan ; src-address=x.x.x.x/x ; action=accept
5. chain=forward ; in-interface=lan ; out-interface=wan ; action=accept
6. chain=forward ; action=drop
7. chain=dst-nat ; protocol=tcp ; dst-port=80 ; in-interface=wan ; action=redirect ; to-port=8080(proxy)
port 80 still wont work.....something wrong.....!
i like it
nowoxi
Tue Nov 01, 2005 1:45 am
well i can see you have everything all joggled up. you see the way the table works is if a packets comes in throiugh a partucular port the header and a few other stuff are compared with each rule in the table and once one rule is carried out it wont go to the next rule thats the end of it another packet is picked and if no rule corresponds then it takes the default policy of the chain.
so looking at what you have there
  • line 3 is useless cos you already dropped everything invalid in 1
    then the spellin in 3 is even wrong
    then you have to accept both related nd established coming from both sides of the network which u didnt do.
yeah also on line 4 make the in-interface is the internal interfaceand vice a verse
thn following the theory i put up 4 n 5 v conflicting interest (there is no need for 1 of them)then i dont think ur data is flowing in the right direction(correct with previous direction)[/list]
i think u should getting workin after that. ps i need help with hotspot
larmaid
Tue Nov 01, 2005 4:34 pm
@nowoxi im sorry my script should be like this.....:
3. chain=forward ; in-interface=wan ; connct-state=related ; action=accept
4. chain=forward ; protocol=tcp ; dst-port=80 ; src-address=x.x.x.x/x ; action=accept
@5 my in-interface is my local network....!
still port 80 drop....!
i like it
nowoxi
Tue Nov 01, 2005 6:56 pm
well i think the problem is that you should accept established and related connections in all directions. i think its dropping replies to connections made to 8080. so if u accept related and established in both directions the problem should be solved
2. chain=forward ; connect-state=established ; action=accept
3. chain=forward ; connct-state=related ; action=accept
that should be ur new line 2 n 3
wildbill442
Tue Nov 01, 2005 8:01 pm
Yeah you do not need to specify the interface..
You could've just copy and pasted the rules i had on there to your router (as long as your using 2.9.x) and then just added this rule to the forward chain:
add chain=forward action=jump jump-target=customer comment="Jump to customer chain"
Or rename the chains to whatever you'd like.
ALSO MAKE SURE YOU TAKE NOTE...
where ever I specified an interface make sure that the interface name matches the interface you're trying to apply the rule to, otherwise you'll get an error, or the rule just wont do anything.
Oh, another thing, why are you redirecting incoming port 80 traffic (from the WAN) to your proxy server? Shouldn't it be the other way around ?
Do this first.. disable the proxy server and related rules for now, get the firewall working and test it make sure you can make a connection on the ports you need (80 and whatever else) THEN once you've verified that everything is working without the proxy, enable it and then test...
You've got too many things going on which is going to make it difficult to troubleshoot and figure out the root cause of your problems...
larmaid
Tue Nov 01, 2005 9:02 pm
okay i did like this:
4. chain=forward ; protocol=tcp ; dst-port=!80 ; src-address=x.x.x.x/x ; action=drop
5. chain=forward ; action=add src to address list ; address list=…. ; timeout=00:00:01
6. chain=dst-nat ; protocol=tcp ; dst-port=80 ; in-interface=wan ; action=redirect ; to-port=8080(proxy)
in proxy:
src-address=x.x.x.x/x ; dst-port=80 ; action=allow
src-address=x.x.x.x/x ; action=deny
and i dont know its working very well all ip that r not specific in proxy will be blok by mikrotik httpProxy...!
i like it
wildbill442
Tue Nov 01, 2005 10:32 pm
So its working or you're still having problems? I didn't quite understand your last post...
larmaid
Tue Nov 01, 2005 10:37 pm
i mean its 100% working....!
no problem until now....!
my questions is why i cant just drop all other port insted moving to src-address-list.....!
makes me so confused..... :evil:
i like it
nowoxi
Wed Nov 02, 2005 5:04 pm
i also didnt understand ur last post. then line 4 on the post before the last is either uselss if ur policy is drop then u dont need it then if its not its better u perform drops at the end of the scripts not before the end so u dont get undesired effects
NEED HELP WITH HOTSPOTS. IF YOU KNOW AN ARTICLE OR TUTORIAL INEED TO KNOW ITS CAPABILITIES AND USES.
larmaid
Thu Nov 03, 2005 11:21 am
okay nowoxis what is ur problem ill try to crack it...!
i like it
Users browsing this forum: akakua, dalami, eworm, Google [Bot], Majestic-12 [Bot], N2B, stevefxp and 108 guests
