beepee
Add profile to user via Console/API/Script
Tue May 17, 2011 11:18 am
Please I need to change/add profile to users in userman (over 5000users)
I know it is best to do this using scripting or API but I dont see any console menu to perform this.
Any way forward
OR
Should I downgrade to v4.17?
siprox
Re: Add profile to user via Console/API/Script
Tue May 17, 2011 12:31 pm
now you're in trouble, calm down, we are have the same problems :D
normis
Tue May 17, 2011 12:37 pm
are you using v5.2?
*) user manager - added /tool usermanager profile;
beepee
Tue May 17, 2011 1:23 pm
are you using v5.2?
Yes profile menu is available, but how do U assign any of the profile to users in console?
i.e
in menu /tool usermanager user, there should be a menu or option to select a profile for the specified user.
normis
Tue May 17, 2011 1:39 pm
yes, we will add that feature later
beepee
Tue May 17, 2011 3:03 pm
But for now, I guess we can downgrade to v4x where such is available
Right.
siprox
Wed May 18, 2011 12:59 am
Right.
i think version 5.2 still can't use for real production, at least till mature. They heavy developing nv2, etc but maybe forgot usermanager.
fabiosara
Tue May 31, 2011 3:45 pm
Right.
Hello all,
I have the same problem.
Are there any news?
Is there a way to assign profiles to user via web?
Eg http://www.yourradius.com/userman/mwt/x ... =myprofile
Or is there a way to query directly to usermanager database?
Thanks a lot
Fabio
fabiosara
Mon Jun 06, 2011 6:39 pm
I found a workaround to assign a profile to a user:
I created a profile like this (2 hours per day)
/tool user-manager profile
add name=2hperday name-for-users=2hperday override-shared-users=unlimited price=0 starts-at=logon validity=0s
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name="" ip-pool="" name=Limit2h transfer-limit=0B upload-limit=0B uptime-limit=2h
/tool user-manager profile profile-limitation
add from-time=0s limitation=Limit2h profile=2hperday till-time=23h59m59s weekdays=sunday,monday,tuesday,friday,saturday
Then I created a user "master"
add customer=admin disabled=no name=user2h password="aseGD73??!jksghrf" shared-users=unlimited wireless-enc-algo=none wireless-enc-key="" wireless-psk=""
and via webmanager, I assigned the profile I want (in this case, "2hperday")
Now, I create the user via script / shell / api using this command
add customer=admin username=USERTEST password=PASSWORDTEST location=test phone=01123456798 email=test@test.com first-name=USER last-name=TEST name=test copy-from=user2h
The key is the copy-from= parameter
So, we can create a "master user" for each profile, and create many users as we want using "copy-from" and give the "master user".
I hope this could be useful until developers fix this bug.
I know it is not optimal solution, because the "total time left" is not diplayed in user manager, but the user statics are correct.
vdelarenal75
Tue Jun 07, 2011 7:12 pm
It works!!!! Thank you for sharing this, it really helped.
pljubas
Mon Oct 31, 2011 2:44 pm
Hi Normis,
I've upgraded my userman router from 4.17 to 5.7.
There are 1.400 users with different profiles.
In ROS 5.7 there is still no way to set profile to user from console. Or, I'm I wrong?
It is nearly impossible to set profile to 1.400 users from web...
Any help available?
Best regards,
Petar
neandero
Mon Oct 31, 2011 11:56 pm
This issue is now becoming very urgent with each user increase on the network.
Please admins, push developers for sooner feature addition and release.. :D
neandero
Tue Nov 01, 2011 12:10 am
Oh yeah, I forgot something...
while you do add this feature, if POSSIBLE, add another feature where UM can auto switch profile for a user based on download used per day.
example:
user1 basic profile is profile2 2M/2M
if user1 download so much per day say 5G to 10G
UM should auto switch user1 profile from profile2 to profile1 1M/1M
UM should reset user1 profile back to profile2 at Midnight each day.
something like this.. a little way to control who's download so much and who's not - and who should get more speed over the other.
tgrand
Long time Member
Long time Member
Thu Nov 03, 2011 6:15 am
Before they do any changes, they must first clean things up.
The User-Manager still continues to use 2 databases.
Try clearing stats in web, and you will notice the stats in the console continue to accumulate without having been cleared.
Lots and Lots of clean-up to do.
As well User-Manager development would appear to be of LOW priority.
Percanta
Fri Nov 04, 2011 3:18 pm
i was thinking what it uses 2 database too, as the search of sessions in webUM is good but in API-CLI is very poor performance
jdevora
Tue Mar 27, 2012 6:35 pm
Any news about this issue?
Cheers
JD
aysan
Fri Mar 30, 2012 12:29 am
I was so happy with UM 4.17. But now I cannot work with UM 5.x because of bugs.
I am using UM php & cli, I solve some problems on v.5.x but still more... For example, if I assing an user to 1 hour profile, UM should throw out after 1 hour but user still continuous to use internet.
Another problem is credit-left. I cannot find with cli users credit-left as v.4.17 on v.5.x.
The biggest problem is, I can use 4.17 with no problem but new routerboards doesn't support ROS 4.x. I cannot use ROS 5.x beacuse of new UM so I cannot use new model routerboards. I bought RB1100AH and I have so many RB1200, RB750GL etc. doesn't support ROS 4.x.
I don't understand why new model boards are does not support ROS v4.x and Mikrotik doesn't solve UM v5.x bugs.
athome
Tue May 21, 2013 9:54 am
Thank you MTIK developers for this:
/tool user-manager user> create-and-activate-profile user="UUUU" customer="CCCC" profile="PPPP"
ojeysky
Wed May 22, 2013 5:35 pm
This will only be applicable to already existing user. So i guess the problem still exist. Something like below is required:
/tool user-manager user add username=test password=test customer=test name=sample profile=double
ojeysky
Wed May 22, 2013 5:37 pm
Best Workaround so far! Thanks!
mousa1983
Mon May 05, 2014 9:17 pm
Version 6.12 and This problem is still not resolved
rore
Mon Oct 06, 2014 1:12 am
still no solution since Version 4.xx and since 2 years for that?
nothing
Wed Jul 13, 2016 1:28 pm
Few years later you still can't add user-manager profiles from CLI...
Geez...
alisss54
Fri Jan 13, 2017 3:28 pm
you can do it easily using this code
/tool user-manager user add customer=ali  username=uuuuu password=test  ;/tool user-manager user create-and-activate-profile customer=ali profile=ppppp "uuuuu"
ADahi
Fri Dec 08, 2017 3:16 pm
via Script/CLI
suppose username is "111"
suppose profile is TRIAL
To remove user profiles try this
/tool user-manager user clear-profiles numbers=[find username="111"];
To add profile to user try this
/tool user-manager user create-and-activate-profile profile=TRIAL customer=admin numbers=[find username="111"];
Best Regards
Abdulrahman
Sun Apr 08, 2018 7:01 pm
Thank you very much. This command works well on the CLI:
But unfortunately, it doesn't work when using the api to send the command, because "find" is not supported through the api.
So please, what is the alternatives that work through the api.
Thanks in advance
ADahi
Mon Apr 09, 2018 2:20 pm
you can get sequence number of the user
/tool user-manager user print
Flags: X - disabled, A - active, I - incomplete
 0     customer=admin username="111" password="" shared-users=1 wireless-psk="" wireless-enc-key="" wireless-enc-algo=none last-seen=never
and use it like:
/tool user-manager user create-and-activate-profile profile=TRIAL customer=admin numbers=0;
Abdulrahman
Great! it works, thanks millions
Mon Apr 09, 2018 5:37 pm
and use it like:
ADahi
Re: Great! it works, thanks millions
Mon Apr 09, 2018 11:24 pm
and use it like:
millions welcome :wink:
paramex
Thu May 17, 2018 12:29 am
Thanks in advance
use this char "?"
/tool user-manager user create-and-activate-profile profile=TRIAL customer=admin ?numbers="111"
Users browsing this forum: No registered users and 5 guests
