jfrater
Listing the routing table via SNMP
Wed May 18, 2011 8:51 am
Hi, I want to get the routing table from a router but with no luck, everything else like IP and interfaces have no problem.
Is there a way to do that on routerOS? I've tried v 4.9 5.0 and 5.2 and nothing.... :(
Jorge Frater
jfrater
Re: Listing the routing table via SNMP
Mon May 23, 2011 1:36 am
Well to answer my own question, if I force the SNMP program to use SNMP v1 it works, it does detect the router to be v2 compatible and thats why I only tried v2, but at least on RouterOS 4.9 it works with v1
Jorge
dvop
Wed Jun 08, 2011 2:54 pm
Hi, I have the same problem:
If a fetch the routing table via SNMP a get an empty result.
# snmpwalk -v1 -c public 10.x.y.z 1.3.6.1.2.1.4.21
Problem appeared from RouterOS version 5.0 (tested on 5.0rc till 5.4). In RouterOS 4.x, everything works. Tested on multiple routers.
In 5.x version, when I perform snmpwalk, it seems both IP address table (1.3.6.1.2.1.4.20) and ARP table (1.3.6.1.2.1.4.22) are OK. Only routing table is not accessible via SNMP. Tried both version 1 and 2c.
Thanks for any advice.
Petr
davidsm
Tue Jun 14, 2011 8:25 am
I'm having the same problem. I'm trying to monitor my OSPF status by checking the default route.
In v4.17:
snmpwalk -v2c -c public 172.20.0.1 iso.org.dod.internet.mgmt.mib-2.ip.ipRouteTable.ipRouteEntry.ipRouteNextHop.0.0.0.0
RFC1213-MIB::ipRouteNextHop.0.0.0.0 = IpAddress: 202.168.24.69
v5.4:
snmpwalk -v2c -c public 172.20.0.2 iso.org.dod.internet.mgmt.mib-2.ip.ipRouteTable.ipRouteEntry.ipRouteNextHop.0.0.0.0
RFC1213-MIB::ipRouteNextHop.0.0.0.0 = No Such Instance currently exists at this OID
meshnet
Tue Jul 09, 2013 11:11 pm
I know this is an old post, but was there ever a working solution to this bug?
From a 5.25 router, I can only read about 320 routes from snmp.
From a 4.17 router, connected by ethernet to the same router, I can get all 632 routes from snmp.
Both show the same routes in winbox under /ip route...
Thanks,
Richard
meshnet
Tue Jul 09, 2013 11:22 pm
And what is interesting is that it looks like the results from the 5.25 router are
skipping every other route entry that should be in the snmpwalk.
It prints one, then skips one, prints one, skips one..
If I try to query the oid directly ( that should be there, and is on the other router ), I get
"No Such Instance currently exists at this OID"
Richard
meshnet
Wed Jul 10, 2013 4:54 pm
I recieved the typical "Upgrade to the latest 6.x version, and test it" from support...
Great..
Richard
normis
Wed Jul 10, 2013 4:56 pm
Great..
Richard
You are using an old version which is very unlikely getting any updates. All issues are fixed only in v6 now, so if there was a bug, it is very likely v6 has it fixed. "Please upgrade" is a very reasonable response.
meshnet
Wed Jul 10, 2013 9:33 pm
5.25 is not that old.
I have IPSEC tunnels on this router, also..
So, when I upgrade to 6.1, and it kills my IPSEC tunnels, that is a fix?
Thanks,
Richard
normis
Thu Jul 11, 2013 2:11 pm
If you have a SNMP problem in v5.25, and an IPsec problem in v6.1, you are really out of luck. Both these issues are very rare, and happen only in specific circumstances. v6.2 has the IPsec issue fixed.
v6.2 is here: http://www.mikrotik.com/download/share/ ... be-6.2.npk (MIPS-BE). Change the name to get other build files.
Numenori
Thu Jul 11, 2013 4:20 pm
Normis, what about changelog for 6.2?
semakka
Sat Aug 17, 2013 2:45 pm
have you tried commenting the
  • mibs :
line in
  • /etc/snmp/snmp.conf
in case of a linux machine from which you do the query.
had the same problem and that solved it.
Semakka
saturn
Wed Aug 21, 2013 1:33 pm
I have the same (can't get default route via snmp) problem on 5.11, 5.16, 5.24, 5.25, 6.1, 6.2 versions of RouterOS.
  • mibs :
line in
There is no effect after this.
semakka
Thu Aug 22, 2013 3:28 pm
can you give more info about how you do the query and what for?
saturn
Sat Aug 31, 2013 2:29 pm
Yes, I execute follow command and get:
root@ocs:~# snmpget -v 2c -c %my_read_comm% 10.10.0.10 .1.3.6.1.2.1.4.21.1.7.0.0.0.0
iso.3.6.1.2.1.4.21.1.7.0.0.0.0 = No Such Instance currently exists at this OID
chaigeo
Fri Mar 07, 2014 7:50 pm
Well, i have the same problem to all RB.
I can get with snmp only one route not all routing table.
Checked to v6.4 and 6.9 with snmpwalk snmpget whatsup,dude..only one route returns.
Tried everything.
The only tool i can get all routing table is Ipreasoning Mib Browser with getbulk. (not working either here with simple get).
any help will be appreciated..
G.
chaigeo
Mon Mar 10, 2014 11:39 am
Checked with v5.26 works!
Problem exists in v6.xx
G.
chaigeo
Mon May 26, 2014 6:36 pm
Any update from mikrotik?
thanks in advance,
George
Users browsing this forum: Bing [Bot] and 8 guests
