MUM Europe 2020
petro25
v5.3 relised bug on rb 411
Thu May 26, 2011 4:43 am
It is observed such on rb411 in different places on v5.2 all well
07:23:37 interface,info ether1 link down
07:23:39 interface,info ether1 link up (speed 100M, full duplex)
07:26:27 interface,info ether1 link down
07:26:29 interface,info ether1 link up (speed 100M, full duplex)
08:04:27 interface,info ether1 link down
08:04:28 interface,info ether1 link up (speed 100M, full duplex)
08:04:35 interface,info ether1 link down
08:04:37 interface,info ether1 link up (speed 100M, full duplex)
08:07:32 interface,info ether1 link down
08:07:34 interface,info ether1 link up (speed 100M, full duplex)
08:09:12 interface,info ether1 link down
08:09:14 interface,info ether1 link up (speed 100M, full duplex)
08:12:09 interface,info ether1 link down
08:12:11 interface,info ether1 link up (speed 100M, full duplex)
08:28:57 interface,info ether1 link down
08:28:58 interface,info ether1 link up (speed 100M, full duplex)
mangust
Re: v5.3 relised bug on rb 411
Thu May 26, 2011 8:30 pm
Note: v5.3 contains a problem that affects RB400 series device Ethernet ports which are not connected to the switch chip. The ports could lose link for a fraction of a second. A fix is scheduled within a few hours
wait v5.4?...
AbSSoLuT
Mon May 30, 2011 2:35 pm
i have the same problem with RouterOS 5.4 :(
I use RB411AH
any idea ?
normis
Tue May 31, 2011 12:41 pm
I use RB411AH
any idea ?
what is on the other end of the cable? maybe cable is bad, or other end of the link is acting up
rini
Tue May 07, 2013 12:15 am
i have RB1100AHX2 10 ethernet ports
i have connected here 411AH, 433AH RB711 all same problem. i have PPPOE server running on all these ports
and pppoe clients disconnect for this problem
i am running version 6.0rc14
samsung172
Tue May 07, 2013 3:01 am
check cable, poe and... that you have power enough trough poe.
rini
Tue May 07, 2013 11:26 pm
I use RB411AH
any idea ?
in the other end is RB1100AHX2 and i have a pppoe server running in ether1 to ether10
all ten ethernets same problem
honzam
Wed May 08, 2013 12:23 am
Try change ethernet cable
LAN, FTTx, Wireless. ISP operator
Users browsing this forum: CZFan, Google [Bot], MSN [Bot] and 123 guests
