LatinSuD
Re: Webfig skins (tutorial)
Wed Aug 01, 2012 1:29 pm
In particular, is there a way to add columns like "to-address" in nat and all other firewall columns?
Without them, webfig is not very useful for firewall.
AnRkey
Thu Sep 27, 2012 1:11 pm
I love webfig, I just wish it was skinned to look exactly like winbox.
Also, an upload feature would be cool.
MTCNA
ABeepMike
Wed Dec 12, 2012 2:02 pm
hi,
I am running 5.16 on RB750GL boxes for some simple tasks.
I tried to disable ALL buttons in WebFig for the Read Only Group.
I left Tools: Netwatch
and
Logout
Works great except, from Logon...it shows IP Address' screen after logon...no matter what I do..
One click of the Tools Netwatch button , and it is gone , of course, and then cannot be accessed, .....
How can I make the first screen after logon go to the Screen I want it to, and not something that is disabled???
Confused. Is it the reseller package that adjusts this?
janisk
Thu Jan 03, 2013 10:39 am
please update to newer version of RouterOS, if i am not mistaken we where working on this issue, that when skin disabled a page, it was loaded as default.
Lakis
Forum Veteran
Forum Veteran
Sun Jan 06, 2013 4:06 pm
I want to ask something odd if this possible with Mikrotik CPE
I m sure almost every one have experience with UBQ CPE Nano Station Loco or Airmax or linksys
From remote site u can access in UBQ NStation/Linksys web witch is set to station(client) and than u can do Scan/Site Survey - Than Loco/Linksys will disconnect do the scan and
reconnect and will show u results (from scanning) in new tab
lukkes
Sat Mar 02, 2013 4:31 am
i want remove or add column in the wireless registration table, also i want to view inline comments, is's possible? thanks
If you found this post useful don't forget about the karma viewtopic.php?f=1&t=41148
Feed Your FAITH Then Your Doubts Will Starve To Death...!!!
tamilmaran
Sat Apr 27, 2013 10:40 pm
me too need the option for add & remove columns.
Any plan for this in future...?
If u like my post , then Hit the Karma! Thanks.
Thamizh Maran
RF Engineer
ZERONE Tech
India
HaPe
Sun May 19, 2013 7:33 pm
Have anyone any custom skin to share with other users?
In anticipation on new The Dude release.
plankanater
Wed Jun 26, 2013 10:59 pm
I have found a major security glitch in the webfig. Basically I have user with read - write access but I only allow them to have access into the IP - Hotspot tabs and the tools, nothing else. I want them to be able to log users off and kick macs out of the host list. I do not allow them winbox or access to any of the vital information within the router.
When I log in with the username they only get what I want them to get. However there is a small tab called "Design Skin" where they can click on this, simply select the skin that they have credentials too and select any or all of the tabs, save the skin and BOOM, they now have access to everything. Is there a way around this? Can I set skins to read only or something.
Anyone else discover this yet?
ditonet
Forum Veteran
Forum Veteran
Thu Jun 27, 2013 1:45 am
@plankanater
Disable 'policy' permission for this user.
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
Chupaka
Thu Jun 27, 2013 4:51 pm
according to http://wiki.mikrotik.com/wiki/Manual:Webfig#Skins,
It is not a security tool. If user has sufficient rights it is possible to access hidden features by other means.
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
plankanater
Fri Jun 28, 2013 8:29 pm
@plankanater
HTH,
Worked! Awesome, thanks.
pcunite
Forum Veteran
Forum Veteran
Thu Sep 05, 2013 7:40 pm
Need to be able to set columns.
mateuszb
Thu Oct 17, 2013 11:12 am
what I don't like about webfig is that it opens 8 connections to mikrotik while winbox only one. on the overloaded system/link webfig breaks a lot.
gulliverrr
Mon Nov 25, 2013 9:15 pm
First post :)
Short story:
The default (full) skin is loaded instead of the custom one I made.
Longer story:
I have a 5.11 configured as Hotspot and is working fine for some time now.
The problem is that I want to give the local IT admin, who is not very much into "IT", a skinned mode username to only access the Hotspot section to add and delete users.
I created a trimmed skin with only the Hotspot section enabled. If I enable it, while being logged in as admin, it shows exactly what I want them to see and change.
They have their own user group and this group has read, write and web permissions only and the above skin assigned to it.
If I log in with their account, I can still see and change everything. What am I doing wrong?
gulliverrr
Tue Nov 26, 2013 7:33 pm
Found the answer myself :)
its probably a bug in 5.11.
Upgraded (manually as auto upgrade is not implemented in 5.11) to 5.26 and everything works fine.
False alarm after all...
spacemind
Sun Jan 26, 2014 9:23 pm
Hi MT guys, great work with webfig skins,
I had make a skin only to use bandwidth test, i tried to setup a default ip, user, password but i could not get it defined, when using that skin there are no details inserted.
Is there any way to define that fields and hide them, clients just click on start and stop to see speed.
Thank you.
P.s. Make new dude version ehehe.
gulliverrr
Sun Jan 26, 2014 9:32 pm
I dont have any access to an MT right now, but all the fields that can be hidden (not ALL fields can be hidden) have a little drop-down style arrow in skin edit mode. If you see one by the field you want to hide, just click it and you can take it from there..
paams
Tue Jun 10, 2014 9:20 am
Hello There!
I have designed the Webfig skin as per the tutorial with removing unnecessary interfaces and leave few ones as per the user requirement, but when user login through web interface he still gets full featured wefig with all normal deign as before. Please any help will be gratefully appreciated. Thanks.
gulliverrr
Tue Jun 10, 2014 6:38 pm
Did you try this?
paams
Tue Jun 10, 2014 9:11 pm
Did you try this?
I am using this with 5.26, but still not working. Any further help please
gulliverrr
Tue Jun 10, 2014 9:22 pm
Not sure I can help but if I were you I would clear the cache of my browser or try a browser I haven't visited webfig with before. Control+F5 is on my Firefox but other browsers may (will) have a different command. Similar effect is if you use "Incognito mode" or "Private browsing".
Please let me know if it worked.
paams
Thu Jun 12, 2014 4:14 am
Thanks for your suggestion, but i am sorry. I cleared the cache of my browser and try to open the winfig web browser and its still opening same normal winfig web browser and not specific designed one. I'm not getting why this is so? Any further help from anyone out there to fix this webfig skin designed issued?
jarda
Thu Jun 12, 2014 4:51 am
The skin has to be assigned to user group of the user.
paams
Thu Jun 12, 2014 6:07 am
Please refer to the attached screenshot. I have done the same as per the process, but nothing happened. Am i missing something to configure. Please any further assistance. Thanks.
paams
Thu Jun 12, 2014 6:11 am
Also these last two ones.
jarda
Thu Jun 12, 2014 8:04 am
Hi. I already showed you how to do it: http://forum.mikrotik.com/viewtopic.php ... 96#p426596.
Try the newer version, i am not going to install 5.x and check if it is possible or how it is possible. Unfortunatelly the pictures are damaged in my tapatalk client - will look later.
paams
Thu Jun 12, 2014 8:15 am
Thanks for keep supporting. I really appreciate. I am using latest version v5.26 and created skin as per the link you have provided and explained other ones on net. But unfortunately nothing happened. Created a new user group with restricted rights as much as possible and assigned this new skin to it. What i'm missing to cofig. the setting now? Please review the attached screenshort for more clear details and would heartily appreciated your further help on this to fix this.
gulliverrr
Thu Jun 12, 2014 9:43 am
if you believe that in your last image MT-Skin05.PNG you have logged in as user1, you are wrong.
If you notice the text on the tab of your browser (just below the menu: file, edit, view, history) it says:
Gateway - Interface List at admin@10...
which means you log in again as admin and not user1, probably automatically, so this means this is cached somehow. Try logging out first or even Chrome's incognito mode (Ctrl+Shift+N) and if even this does not work, change the admin password (or set one if you have it blank) so that anything cached is wrong.
Good luck
jarda
Thu Jun 12, 2014 12:07 pm
Guliverrr is right, you are logging as "admin", not as "user1". This is the reason. So, log in as "user1", and you will see...
paams
Thu Jun 12, 2014 2:25 pm
Hey Guys! You are really GREAT. Got it.... :D. Yes! i was login with admin not for the user created. Great Job. Keep it up to assist with MT support. Thanks a lot once again.
paams
Thu Jun 12, 2014 2:30 pm
Hello there! Please let me know could we edit webfig login page with just only username and password on the webfig login window with adding our own service promotional texts to the created login group users, same as like we can edit Mikrotik Hotspot login page? Thanks
jarda
Thu Jun 12, 2014 6:22 pm
paams, provide some e-mail contact...
paams
Thu Jun 12, 2014 7:09 pm
Okay Bro! Thank you very much.
bajodel
Long time Member
Long time Member
Fri Jun 13, 2014 7:00 am
absolutely ..even a simple find/edit/fix is hard on relatively complex firewalls without columns customization
maaroufs
Wed Oct 22, 2014 2:18 pm
can I disable access from webfig, and only access via winbox. in ver 6.7?
thanks
otgooneo
Trainer
Trainer
Mon Oct 27, 2014 8:54 am
thanks
Yes of course, just disable http access in /ip service
Want to learn more and more...
msolnicki
Mon Dec 01, 2014 12:22 pm
I have a little issue with my webfig desing skin feature, and i hope you guys will be able to help me. Problem is, that some parts work - and some dont. For example, i can hide everything from main panel located on the left, but when im trying to hide something specific, like wireless card options, it just wont save. I mean, im unchecking the box next to the option that i want to be hidden, click save, refresh the page and nothing happens. Same goes for translating. After save + refresh procedure, everything stays the same.
Im using RB 433 with v6.22 soft, firefox browser (but i have tested it with chrome also).
Any ideas ?
Cheers,
MS
hossain2004a
Wed Jan 14, 2015 11:45 am
Any ideas ?
Cheers,
MS
Clearing your browser's cache would solve your problem. Also you should try again. At least it works for me.
rower
Tue Feb 10, 2015 11:16 pm
before webfig everyone asked for an OS independent interface. now it's backwards again :)
pardon me, SSH ? secure, platform/OS independant, fast, clean... did i mention secure ?
and i still wish, there was a way to disable webfig completely. i'd like to show _only_ graphs to my users (and on non-default port).
infused
Sat Feb 14, 2015 1:31 pm
Would be nice to be able to add logos etc.
hossain2004a
Tue Feb 17, 2015 9:31 am
yes but maybe they think you should use Syslogs
Chupaka
Wed Feb 18, 2015 12:32 am
he said logos, not logs :)
hossain2004a
Wed Feb 18, 2015 10:19 pm
hahaha.
My fault.
checking forums in end of my work time and this is the result :D :D
hossain2004a
Mon Apr 06, 2015 11:07 am
Is there any way to adjust menu like in Winbox?
I'd like to add byte-out in specified place.
kraljek
Tue Apr 28, 2015 8:40 am
Hi all,
Designes is great options in web interface to remove some items for end users.
But i have problem with USERS panel.
I have two users admin and wifi user who can change only wifi SSID and password.
If I want that user with wifi can change password on account, I can only check or uncheck all users, but not individually.
I want hide all account, but show only acc who is loged to it?
Thx
Tomislav
marting
Mon Jun 15, 2015 1:17 pm
Love webfig, however I would like to see the ability to disable the "disable eable buttons" particuarly in "interfaces" you can click the "D" to disable the interface, would like a read-only or remove option for those buttons, either for individual interfaces or as a whole.
I also look for a way to disable these "disable" and "remove" buttons in the overview/table page. I tried to disable the "Enabled" field in the details page but this does not have an effect on the overview. It is a really big risk to accidentially disable a primary interface without safe mode.
Did I miss something or is there no way to do so?
David1234
Fri Sep 25, 2015 2:35 pm
I'm using the web-config for some time now , very good and helpful .
mu only question is -
how can I make a user that can't change the skin but can change the script?
if I allow some user policy in the user setting , he can change the skin - I don't want this
so how can it be done?
Thanks ,
Kunstovny
Tue Dec 15, 2015 9:32 pm
Hi, I have one question about webfig skin and radio buttons.
I solve problem with configuration wan in quick set function.
I want to have choice between Static, Automatic ip address. But no PPOE
When I use Limit see nothing
richk
Fri Feb 05, 2016 10:06 pm
How do I change the language or customize text on the columns.. as listed in the pic (in red circle)?
Also... how do I add tabs on the left menu... as listed in the pic (in green)?
Thank you
Rich
otgooneo
Trainer
Trainer
Wed Sep 14, 2016 9:28 am
Please make webfig as security feature. Then it will be veeery useful to offer our customers.
Users browsing this forum: Bing [Bot] and 16 guests
