piwi3910
dual antenna
Wed Nov 02, 2005 9:34 am
hi i have a RB500 running the MT 65mw atheros card.
no i first did a setup with a small 6dbi antenna connected to ant-A
i did some tests... connection dbi and different distances, thruput tests ad different distances.
then for test i connected another 6dbi antenna to the ant-B
and set the antenna mode to use them both.
one for tx and ne for rx.
and guess what...
did al the tests again, and got the exact same results.
so why would i use this???
is a dual setup of use in a PtMP situation... or only in PTP?
andreacoppini
Trainer
Trainer
Tue Jan 31, 2006 3:16 pm
Old question, but still valid. And since nobody bothered to answer, I will.
the tx-a/rx-b (or vice versa) option is there to connect two different antennas, one for transmitting and another for receiving. It does not change the speed or capacity directly, since you still only have 1 radio which is doing all the transmitting/receiving.
This is normally used due to transmit power limitations, where you would put a medium-gain antenna on the TX side, and a very high gain antenna on the RX side, increasing your receive strength, but not your transmit strength.
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
pd
Tue Jan 31, 2006 7:35 pm
Is diversity supported ?
andreacoppini
Trainer
Trainer
Tue Jan 31, 2006 7:40 pm
nope (not yet??)
Alessio Garavano
Mon Feb 06, 2006 11:06 pm
what is the antenna-a connector in a dual connector R52 minipci? in the board can`t see...is the more inside or the near the corner of the board? thanks
Alessio Garavano
http://www.isparg.com.ar
cibernet
Long time Member
Long time Member
Mon Feb 06, 2006 11:20 pm
Primary and Secondary port of antenna
Regards
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
Alessio Garavano
Mon Feb 06, 2006 11:49 pm
Yes, but my question is what is the primary(antenna-a) in the board? don`t have nothing writed in the board, thanks
Alessio Garavano
normis
Tue Feb 07, 2006 10:06 am
depends on the kind of miniPCI card
Alessio Garavano
Tue Feb 07, 2006 3:57 pm
It`s a Mikrotik R52 with Atheros AR5413 chipset.... have a connector U.fl in the corner and other in the middle... i think is the corner, but please confirm this to me...
Thanks, regards and sorry my bad english! i from Argentina
Alessio Garavano
normis
Tue Feb 07, 2006 4:04 pm
the one closer to centre is main.
Alessio Garavano
Tue Feb 07, 2006 4:13 pm
Now i have the RB532 in the tower, have connected the antenna to the U.fl most in the corner and selected antenna-a in the wireless setting, and all work very well, the noise floor is -98 and have my 86 clients connected at 11Mb, when select antenna-b, the noise floor go to -88 and only connect 50 clients... i have this card connected to an amp 1W teletronics with AGC and this to a omni...
Alessio Garavano
cibernet
Long time Member
Long time Member
Tue Feb 07, 2006 4:16 pm
Why do you use amp´s... it will amplifi noise too.. use SR2 it was 400mW :)
Regards
José Ignacio Acosta
Mikronet
Alessio Garavano
Tue Feb 07, 2006 4:32 pm
Is not easy buy this card here... only SR5 is easy, i think is very much demand.
Thanks and regards
Alessio Garavano
cibernet
Long time Member
Long time Member
Tue Feb 07, 2006 4:37 pm
Thanks and regards
Send me an email, i have them :)
José Ignacio Acosta
Mikronet
jo2jo
Forum Veteran
Forum Veteran
Sat Feb 24, 2007 10:21 pm
im using an r52 and i have the 2 ports plugged into different antennas, the advcaned-> mode is set to tx-a tx-b.
(im only doing this as i happen to have 2 antennas identical anteanns moutne at each of these locations)
is this working or is it still using just 1 for both RX and TX as i read on the fourms that diversity is not suppored by routeOS
tks
:beep :beep :beep
andreacoppini
Trainer
Trainer
Sun Feb 25, 2007 4:02 pm
tks
tx-a/rx-b works fine. it is not diversity. Diversity would be something like tx/rx-a + tx/rx-b, this is different.
jwcn
Sun Feb 25, 2007 5:08 pm
Diversity would actually be
tx/rx a
rx b
andreacoppini
Trainer
Trainer
Sun Feb 25, 2007 9:24 pm
tx/rx a
rx b
it very much depends on the wireless chipset. The old Hermes 802.11b chipset operates as yuo say, but most new Atheros-based interfaces adapt their TXs and RXs depending on which antenna was the most successful.
See the bottom of: http://www.simandl.cz/stranky/linux/ath ... herose.htm
... on that page you will also see how easy it would be for MT to allow diversity, by just adding another field to the 'Antenna Mode' drop down box and passing 0 as the parameter of RX and TX antennas to the madwifi driver.
jonbrewer
Sun Mar 04, 2007 10:58 pm
Why do you think that Mikrotik uses the madwifi driver?
Users browsing this forum: No registered users and 22 guests
