maximan
Trainer
Trainer
2 server pppoe on the same Lan
Fri Jul 30, 2004 4:42 pm
Hi.
I have 2 leased line and i have 2 mikrotik box. I want to set both routers with pppoe server. The service's name: server1 and server2 .
How i can set on the customer that they connect with one router or the another with winpoet?? Can be there any problem if are 2 pppoe server on the same lan.
Regards
Maxi
[ASM]
Re: 2 server pppoe on the same Lan
Fri Jul 30, 2004 5:32 pm
Hi.
Regards
Maxi
On client computers install raspppoehttp://raspppoe.com/.
You can choose the server you want, and the proper serviec when you make the connection.
maximan
Trainer
Trainer
Fri Jul 30, 2004 5:57 pm
But i have about 200 pppoe customers with the 60% with winpoet.
I don't know if there will be problem with winpoet and 2 service pppoe
Regards
M.
Freman
Mon Aug 02, 2004 5:56 am
There should be an option IN winpoet that allows you to specify the service name (assuming you have configured it on your ACs)
http://www.carricksolutions.com/pppoe.php
http://www.carricksolutions.com/pppoe/windowspppoe.php
And a quick search on google should give you everything you need, including screenshots.
Users browsing this forum: Bing [Bot] and 237 guests
