iDen
some problem with routeros update
Wed Jun 29, 2011 9:31 am
hello
i've suddenly updated routerboard 493ah with routeros-mipsbe package.
now in system packages there is tree;
routeros
-system
how can i return view of packages to normal view ? is it possible
for sure i can't remove package system even if i have uploaded system package on routerboard before restart.
Thanks in advance.
MTCNA
mrz
Re: some problem with routeros update
Wed Jun 29, 2011 1:51 pm
There is tree view by default. If packages are installed separately then you simply can't see tree, because there is no hierarchy. When you install combined package it shows that other packages are installed from combined package.
iDen
Wed Jun 29, 2011 2:14 pm
so is it possible right now to install system package separately like it was before, and not under routeros package like now ?
MTCNA
mrz
Wed Jun 29, 2011 2:20 pm
Yes. Download all packages and from the archive install only packages you need.
iDen
Wed Jun 29, 2011 3:46 pm
i've tried but system package remains same under routeros package.....
i'll try to downgrade RoS now
MTCNA
iDen
Wed Jun 29, 2011 3:59 pm
downgrade helped
MTCNA
Users browsing this forum: crazyperson, sumranutadu, txfz, zakynthoswifi and 108 guests
