jetsystems
Feature Request: IPv6 static neighbor
Sat Jul 16, 2011 6:40 pm
IPv6 with dynamic neighbors don't run over managed switches with poor support of multicast. For example on ZyXEL ES-2024A you can use IPTV (MVR+drop uknown multicast frame) or IPv6 (flood unknown multicast frame) but no both.
Solution for IPv6 no supporting switches generally can be static IPv6 neighbor. It's same as static entries in IPv4 ARP.
Does Mikrotik plan Static neigbors support and if yes, when?
Thank for your response
Chupaka
Re: Feature Request: IPv6 static neighbor
Thu Jul 21, 2011 10:01 am
what about client side? RouterOS should be on both sides of communication?..
jetsystems
Thu Jul 21, 2011 10:56 am
Yes, I want to connect two RouterOS routers trouhgt switch that is dropping multicast.
In linux is comand
ip -6 neigh add <IPv6 address> lladdr <mac address> dev <device>
but in mikrotik IPv6->Neighbor is not that option
tomaz_borstnar
Mon Nov 14, 2011 12:29 pm
This is the only thing holding me from getting native IPv6 from my provider (T-2 in Slovenia).
normis
Mon Nov 14, 2011 1:01 pm
we are planning to add it, it's in our list.
JanZorz
Wed Mar 14, 2012 3:54 pm
Any news on this topic? This is really needed...
Cheers, Jan
nejko
Tue May 15, 2012 1:18 pm
I would also really need this feature.
Thanks,
Nejc
urban
Thu Oct 10, 2013 10:17 pm
v6.4 SW and still without requested feature. Please do something.
Thanks,
Urban
mulaz
Thu Jun 11, 2015 6:59 pm
6.29 and still waiting.
Cray7
Wed Jun 24, 2015 3:44 pm
6.29.1 and still waiting ;-).
Was this feature cancelled?
Static ARP and neighbour entries seem to me like basic router functionality, I sometimes use it also as one of the "security features".
mulaz
Wed Dec 23, 2015 11:19 am
Any news? :)
Cray7
Mon Dec 28, 2015 6:57 pm
Any news? :)
Christmas arrived.......
.... but still no static Neighbor entries ;-).
I'm compiling a letter to Ded Moroz, maybe he can help....
savage
Mon Jun 27, 2016 7:04 pm
Almost 5 years later....
Cray7
Tue Jun 28, 2016 9:16 pm
I've solved my problem by complaining to ISP which upgraded me to a new CPE they just got. IPv6 ND works on the new CPE.
Still... this episode will reflect next month in my tender when I'll be purchasing ~300 routers. Guess what I'll require that they do on IPv6 ;-)))).
ZeroByte
Tue Jun 28, 2016 9:39 pm
Static neighbor = useful feature with lots of potential benefits.
Switch that fails @ IPv6, however.... I would get a new switch regardless, instead of pouring 4 quarts of oil into the old beater every Sunday afternoon just to keep it running, yaknow?
savage
Tue Jun 28, 2016 9:46 pm
A simple enough thing to implement (let's not even talk about the 5 odd years of waiting).
Extremely useful feature, especially in terms of PtMP security.
Enough reason to look at something other than Mikrotik, that's for sure.
ZeroByte
Tue Jun 28, 2016 9:51 pm
Let's be honest - 5 years ago, Mikrotik was essentially ahead of the curve by having a function IPv6 stack built right into the OS, even if disabled by default. I had to use someone's patched version of DD-WRT on my Linksys router in order to get v6 wsorking back then (I didn't have a Mikrotik at home).... but now, IPv6 is much more common, and the IPv6 functionality of ROS is working, but very much no-frills compared to the things it can do in v4.
I'm hoping that ROSv7 is bursting with new v6 functionality.
tomaz_borstnar
Fri Aug 19, 2016 11:42 am
After almost 5 years I had to solve this with different devices - some are more expensive than Mikrotik, while some are cheaper.
Come on, Mikrotik, what are you waiting for?
bekreyev
Mon Oct 26, 2020 6:39 pm
And I still can't do it, but without it I can't work...
fansari
Tue Mar 28, 2023 3:12 pm
This feature is exactly what we need now. We have version 7.6.
How can I assign a MAC to an IPv6 address without this feature when ND for some reason is not working?
baragoon
Wed Apr 03, 2024 3:44 am
13 years… and still no such option…
akrao
Thu May 30, 2024 2:16 pm
We cannot serve IPv6 over GPON to customers using RouterOS due to this feature (and /ipv6 dhcp-server set add-neighbor) missing.
