nz_monkey
RB750GL and packets over 1500bytes
Mon Jul 18, 2011 6:58 am
We have a couple of RB750GL's running RouterOS 5.5 connected via ether1.
They will not pass packets greater than 1500bytes between them, even with an MTU of 1598 on eth1 they will only pass up to 1500byte packets :( Oddly, RouterOS thinks the packet was sent successfully as there are no fragmentation errors, the packet just never leaves the port!
I have logged a ticket with Mikrotik, so hopefully someone gets on to it before anyone else encounters this problem.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
blake
Re: RB750GL and packets over 1500bytes
Mon Jul 18, 2011 9:29 am
Are you adjusting the l2-mtu parameter, or just mtu?
IT consultant. Network manager. Packet junkie.
1-928-328-1509
nz_monkey
Mon Jul 18, 2011 10:40 am
I adjusted both MTU and L2-MTU
I can straight swap with RB750G units and they work perfectly (albeit with 1524byte MTU limit)
I factory defaulted them, then only put IP addresses on eth1 and set the MTU and L2-MTU and even then, could only send up to 1500byte packets.
nz_monkey
Tue Jul 19, 2011 9:41 am
FYI this is now confirmed by Mikrotik support, and will be fixed in the next release.
Thanks Mikrotik.
astounding
Tue Jul 26, 2011 9:56 pm
Anyone at MikroTik have an idea when a new release will hit the download servers to address this? (5.6?) I've got several 750GLs installed at a particular site that I cannot use until this is fixed.
Wondering,
Aaron out.
normis
Wed Jul 27, 2011 9:08 am
Wondering,
Aaron out.
email support to get the pre-release version, so you can verify the issue is fixed
astounding
Wed Jul 27, 2011 10:00 am
Thank you. I will follow your suggestion.
Aaron out.
astounding
Wed Jul 27, 2011 10:08 pm
The 5.6 prerelease DOES fix the 1500 byte problem on the 750GL boxes I'm using.
I can run packets cleanly as large as 4074 bytes.
Thanks!
I do wonder why the l2mtu by default is 1998 instead of 4074 on the GL...
Aaron out.
nz_monkey
Wed Jul 27, 2011 11:25 pm
Great, I cant wait to get the pile of 750GL's off my desk and in to production.
Users browsing this forum: No registered users and 25 guests
