MUM Europe 2020
saintofinternet
Forum Veteran
Forum Veteran
no speed above 1.5MBPS for file transfer....
Wed Jul 20, 2011 6:23 pm
hi friends,
today i setup a bridge between 2 RB711-5Hn-MMCX in a 22dbi antenna enclosure.
both in the same room a few inches away.
i then setup a MPLS transparent bridge using the steps given here : http://wiki.mikrotik.com/wiki/Transpare ... using_MPLS
now when i transfer data from one PC to another PC i don't get speeds above 1.5 MBPS at the most 2MBPS. Not above that.
anything i need to do more about this setup for gaining speeds above atleast 20MBPS....
-sid
by professionals, for professionals....
Don't forget to give KARMA!!!
poli5681
Re: no speed above 1.5MBPS for file transfer....
Wed Jul 20, 2011 9:11 pm
Hi saintofinternet,
Usually there´s no need for VPLS on PTP Links anymore; RouterOS V5 has a
native Bridge Mode without the speed tradeoff using WDS;
Said that, you won´t get good results at you test setup with 22dbi antennas just a couple of feet away...
It´s like staring into the sun. Ideal signal is around 60dbm.
saintofinternet
Forum Veteran
Forum Veteran
Thu Jul 21, 2011 3:41 am
any place where i can see the bridge setup?? without using MPLS.... because i somehow misreably fail when i try to do it using WDS and bridge. my RouterOS is Level3 hence i don't even have a AP mode.
poli5681
Thu Jul 21, 2011 12:09 pm
You dont´t need Level 4 for PTP Setup. Just set Mode "Bridge" on the first and Mode "station-bridge" on the other - no need for WDS.
http://wiki.mikrotik.com/wiki/Manual:Wi ... ion-bridge
Additionally you have to add a bridge and bind both wlan and ether interface.
saintofinternet
Forum Veteran
Forum Veteran
Fri Jul 22, 2011 6:48 am
today i enabled NV2 and the Bandwidth Test gave me speeds of 200MBPS
when i tried actual file transfer from PC to PC it was not above 700 KBPS...... :(
why is this happening??...
poli5681
Fri Jul 22, 2011 8:45 pm
Do you see any errors or drops at the interface statistics?
saintofinternet
Forum Veteran
Forum Veteran
Sat Jul 23, 2011 4:40 am
packet drops yes.... during the Bandwidth Test in UDP
either in RX or TX or Both
saintofinternet
Forum Veteran
Forum Veteran
Sat Jul 23, 2011 4:41 am
adding more images of the earlier chain.
Users browsing this forum: No registered users and 34 guests
