MUM Europe 2020
wireless12
RB7115-Groove5 40 Mhz
Sat Jul 23, 2011 10:53 am
hello friends.
when we use groove & RB 711 sereis in orthodox 5 GHz we can see & use only 5Ghz-5Mhz and 5GHz-10 MHz where is 5GHz-40 MHz is missing how to enable and use 5GHz-40MHz in regular 5 GHz band,
note i know that in 5GHz-N i can enable 40MHz by setting above control or below control in HT settings i need to use 40 MHz in regular 5GHz without N .
regards
wireless12
Re: RB7115-Groove5 40 Mhz
Sat Jul 23, 2011 10:55 am
hello friends.
regards
only these channel width are available
herbicidal
Mon Jul 25, 2011 9:41 pm
Short answer
5ghz 40mhz is not supported on N based cards.
However, you can use 5ghz-N Mode with a Channel-Width of 20 and then use the extension channel feature to get a 40mhz equivalent.
Both ends will need a N-Based card.
Users browsing this forum: No registered users and 75 guests
