monolithelectronics
MC8705 and 411U setup isses
Sat Jul 30, 2011 2:43 am
Hi Guys,
My board died during upgrade, I had to do clean install with netinstall 5.5.
Since then my modem does not work.
Drivers shows up sierra wireless, ppp info does recognise modem (3,3) but shows PIN ERROR and LIMITED SERVICE,
when I turn ppp on I get this:
waiting for packets
then:
modem init
dialling out
and it rolles over and over
any clue is I need extra drivers, files, setup? It was running under 5.4.
Thank you
monolithelectronics
Re: MC8705 and 411U setup isses
Sat Jul 30, 2011 5:31 am
[admin@MikroTik] /interface ppp-client> info 0
status: ready
pin-status: ERROR
functionality: full
gprs-class: ERROR
manufacturer: Sierra Wireless, Incorporated
model: MC8705
revision: T0_2_5_2AP R263 CNSZXL00000968 2010/11/12 15:23:46
serial-number: 353567040044514
current-operator: Limited Service
access-technology: 3G
signal-strengh: 0
frame-error-rate:
-- [Q quit|D dump|C-z pause]
this is strange:
NAME CHANNELS USED-BY BAUD-RATE
1 usb2 5 PPP <ppp-out> 9600
as modem should be on ch3 not 5...
when I try to force it to 5 it says that there is such channel
/system serial-terminal usb2 channel=3 does not respond with anything but [Ctrl-A is the prefix key]
[admin@MikroTik] /interface ppp-client> print
0 X name="ppp-out" max-mtu=1500 max-mru=1500 mrru=disabled port=usb2
data-channel=3 info-channel=3 apn="yesinternet" pin="" user=""
password="" profile=default phone="*99#" dial-command="ATDT"
modem-init="" null-modem=no dial-on-demand=yes add-default-route=yes
use-peer-dns=yes keepalive-timeout=10 allow=pap,chap,mschap1,mschap2
monolithelectronics
Sat Jul 30, 2011 5:57 am
add this to Modem init:
ATE0V1&D2&C1S0=0+IFC=2,2;
and all rocks...
admin@MikroTik] /interface ppp-client> info ppp-out
status: ready
pin-status: no password required
functionality: full
gprs-class: A - GPRS & GSM simultaneous
model: MC8705
current-operator: YES OPTUS
signal-strengh: -63
frame-error-rate: unknown
monolithelectronics
Sun Jul 31, 2011 1:20 pm
There is a bug in the OS, on 5.5.
1. System does not remember init string after few reboot, it is losing it.
2. Constant dialling out is related to modem or RB itself, the system needs to be shutdown and powered down after change of simcard. Hot swap makes modem confused.
jjnz1
Sat Aug 06, 2011 6:52 am
Hi mate,
I too am using the MC8705, but on Telecom XT here in NZ.
But I do not have to put in any init commands to get it working, just using channel 3.
BUT: I am having one big problem. After a random amount of time, ie 1 week or 4 weeks, the 411 board looses connectivity with the modem and it requires a manual hard power down and then power up. This is difficult as the router is located at a remote site that doesn't see many people. The log says something along the lines of error connecting to usb modem.
I have set the router to do a soft reboot at 3am every night, and this had limited the problem to make it less frequent but it still occurs.
As of 3 days ago, my modem is offline, and I can't get someone there until the end of this month. Signal strength is normally around -82dBi? using a 5dBi external antenna, and get great speeds. I am also using the hotspot function, which I might stop because it seems to act weird when trying to connect a client and there is no 3G connectivity. It would be great if a landing page came up with a button which says 'press to try and reconnect as the 3G is down'.
I am using 5.5, but this has been happening since in the early 5's version. Can anyone help?
johnny
Wed Aug 17, 2011 10:23 am
I have the same problem with MC8790. did you solve this problem?
can anyone recommend a mini-pcie modem that works without this problem?
thanks
jjnz1
Wed Aug 17, 2011 11:01 am
thanks
Hi, there is no solution with the current hardware for any USB or pci based device. The problem is power still stays on the device even when rebooted. The only solution is to pull the power.
Apparently the new routerboard hardware will allow for USB Pci power reset commands but until then buy a plugin power plug timer and set it to reset once a day.
Apparently this happens with most device from what I have read.
uldis
Wed Aug 17, 2011 2:12 pm
Does it still happens in v5.6?
Can you reproduce this bug after each reboot?
Users browsing this forum: No registered users and 42 guests
