MUM Europe 2020
wireless12
help help help
Mon Aug 08, 2011 5:16 pm
any one can tell me how to get a decent through put using groove. i am only getting 12 Mbps one side throughput on a transparent bridge, using Ros 5.5 on both groove. and i use 29 dbi grid antenna in hope to achieve more throughput.
i have tried every possible settings... but all in vain.
i have another transparent link already running between same two points, i m hanging up groove to use it as an backup link.
the older link is has 411Ah both sides and compex 23 dbm a/b/g cards and i using 5GHz turbo and its pulling 36 Mbps in one direction. and 27 dbi grid on both end.
groove is a nightmare for me, kindly help
regards
sergejs
Re: help help help
Tue Aug 09, 2011 9:25 am
Please post your /interface wireless print and /interface wireless registration-table print stats from both routers.
wireless12
Re: help help help
Tue Aug 09, 2011 12:35 pm
CCQ = 70-90 sometimes above 90%
Data rates = default, tx power= default. WDS= dynamic
here are the pictures for Site -A
wireless12
Re: help help help
Tue Aug 09, 2011 12:45 pm
data rates = default wds mode = disable, tx-power = default
here are the pictures of site-B
normis
Re: help help help
Tue Aug 09, 2011 12:52 pm
you are running bandwidth test on the groove itself? this is the problem. bandwidth test generates a lot of random data, this impacts the CPU and you don't get any speed. correct way to test is:
[powerful pc] --> [grove] -- [groove] ---> [powerful pc]
wireless12
Re: help help help
Tue Aug 09, 2011 1:00 pm
i have done it too the results are the same, i already mention, the older running link is performing fantastically at same distance..with normal 5GHZ turbo. and in this older link when i run btest on the RB itself, then its easily push 36 Mbps in one direction with a problem.
Regards
some more picture of Site-B
uldis
Re: help help help
Tue Aug 09, 2011 1:08 pm
please upgrade to v5.6
Try using advanced rate-selection in the Data-rates tab (do that on both AP and station).
Enable the 20/40Mhz HT Above(Below) channel width to use 40mhz option cince you were using 5ghz-turbo in old setup.
Make sure you use the same frequencies.
Try disabling adaptive noise-immunity on both ends.
Try enabling Nv2 or Nstreme protocol to get more speed as with regular 802.11 with WDS you will not get the max speed.
wireless12
Re: help help help
Tue Aug 09, 2011 1:24 pm
i have already done all possible settings without any results. i have pour my 7 years experience into this link. enabling HT above/below downgrade the through put upto 3-4 Mbps. only in one direction. surprisingly when i configure these groove to traditional 5GHz 20 MHz then it give 14-15 Mbps in one direction and when i try to use NV2 or nstream on AP and leave the protocol mode to any in client side then the link wont connect even.
normis
Re: help help help
Tue Aug 09, 2011 1:27 pm
your signal is -50/-50, how can the link "not connect"?? either your nv2 settings were wrong, or some other reason. upgrade to v5.6 where we have more detailed logs, and make a supout.rif file when it doesn't connect
wireless12
Re: help help help
Tue Aug 09, 2011 1:35 pm
i dont know why, its a mere 6 km link but it appears to be 60 km link. one more thing the link only connect only on frequencies which are marked as bold in drop down list of frequencies. if i try to connect on any other frequency then also link dont connect... this is first time i m seeing this.
Regards.
normis
Re: help help help
Tue Aug 09, 2011 1:38 pm
bold means "in default scanlist". to use frequencies not in bold, you need to write this frequency in the "scan list" setting of the client
n21roadie
Re: help help help
Tue Aug 09, 2011 5:30 pm
Just noticed you have "no_country_set" and superchannel in frequency mode, have you tried selecting your country and manual tx power also wireless protocol is not specified
N21roadie,
Network 100% MT for Now?
normis
Re: help help help
Wed Aug 10, 2011 8:02 am
this is not a problem as long as the scan list setting is configured in the client.
yes, this is strange. try to set something there, on both ends. For example on client side "any" and on the AP side try out 802.11, then test with nstreme and also with nv2.
Users browsing this forum: No registered users and 79 guests
