MUM Europe 2020
avious
email notification problem
Wed Aug 17, 2011 8:13 pm
I've got thedude 3.6 installed on a dual xeon pc ROS router.
I've got the ROS correctly configured to send email through an authenticated server which works fine.
The email notifications from thedude work fine if I send them to the same IP as the authenticated server set up in the ROS.
For the life of me though I CANNOT get the Cc field to do ANYTHING with Thedude's email notifications.
It sends to the single address in the address field fine but it WILL NOT send to the Cc address.
I need it to send to two email addresses at the same time.
Is there anyway to do this with Thedude?
Is this a known bug?
For some reason I can't find any info on this out on the web.
lebowski
Re: email notification problem
Thu Aug 18, 2011 6:42 pm
Not elegant but you can duplicate Notification to say Notification2 and enable it with a different first user...
ibermi
Thu Jun 07, 2012 5:48 pm
Although it's not working mailCC do not send, is there any solution?
miguelbatista at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Expert in Wireless, Hotspots, Linux and Radius Servers
normis
Fri Jun 08, 2012 2:15 pm
please post all your configuration, maybe mail configuration is not correct?
Users browsing this forum: Jusufs and 12 guests
