ekki
Bridging EOIP-tunnnel Problem
Thu Aug 25, 2011 11:18 pm
I got a problem connecting two parts of a network through the Internet using two Mikrotiks and an EOIP-tunnel.
On both sides I added the network-Interface and the eoip-tunnel to a bridge. The attached picture shows the scheme.
a, d = ethernet-ports to the Network
b, c = eoip-tunnel-ports through direct internet-port
a+b = bridge
c+d = bridge
Now my problem:
I can ping from:
1 to 2
2 to 1
2 to 3
3 to 2
3 to 4
4 to 3
I can't get packets from more than 1 hop. Whats my fault? I testet it with 4 Mikrotik-Boards on my desk and that worked fine - so it might has something to do widh the internet.
I use RouterOS 5.6 on x86 virtual machines (vmware esxi 4.1) and port a, c, d are virtual vlan-tagged vmware network-ports. (no vlan in RouterOS)
Hope somebody can help..
ekki
ekki
Re: Bridging EOIP-tunnnel Problem
Fri Aug 26, 2011 1:10 am
I also tried this:
http://blog.butchevans.com/2008/09/mikr ... pptp_eoip/
..but I got the same Problem there.
I cant ping through a bridge. When I sniff on the Interfaces, I see the ping-packages... but there is only arp :(
martini
Fri Aug 26, 2011 5:00 pm
you need to bridge eoip tunnel interface with A interface on 2 , and eoip tunnel interface with D interface.
netrat
Fri Aug 26, 2011 5:23 pm
Please post your config for /ip address, /interface eoip, /interface bridge, and /interface bridge port from both routers.
ekki
Fri Aug 26, 2011 6:30 pm
@martini
That's what I did.
And as I wrote: I get a connection through the eoip-tunnel from bridge on 2 to bridge on 3, but I can't get behind that bridge.
@netrat
Router 2
a= 192.168.0.40/24
b=eoip=192.168.1.40/24
eoip: id=101 remote-adress=external-ip from Router 3
bridge between a+b arp enabled, no stp, all default.
Router 3
d= 192.168.0.50/24
c=eoip=192.168.1.50/24
eoip: id=101 remote-adress=external-ip from Router 2
I also tried to add an IP on the bridge, only IP on the bridge, no ips, ... always the same problem.
I would use routing but I also couldn'd get that running until now.. -feeling stupid
netrat
Fri Aug 26, 2011 7:22 pm
In the terminal, telnet, or ssh you need to do /interface eoip export, /interface bridge port export, etc and post the results. We need to see the actual config on the router.
ekki
Fri Aug 26, 2011 7:28 pm
yeeeehaaaa... I got it!
It was a configuration in vmware esxi.
In the virtual switch options u need to enable promiscious mode! Never knew that RouterOS uses this.. :shock:
But now everything works fine :D
Thanks to all of you
ekki
Users browsing this forum: eworm, leor6br, MSN [Bot] and 133 guests
