NathanA
ARP cache timeout?
Tue Aug 03, 2004 9:05 am
Is there any way to adjust the amount of time that dynamic ARP entries remain in the ARP table on RouterOS? I can't seem to find any such setting if it exists...please tell me that I'm just blind. :wink:
Thanks,
-- Nathan
NathanA
Hello? Is this thing on?
Thu Aug 05, 2004 9:09 am
Uhhh...I'll take that lack of response as a "no"...?
-- Nathan
cmit
Thu Aug 05, 2004 9:38 am
Hi Nathan,
yes, this thing is "on" :D ...
I'm not aware of a possibility to change the timeout of dynamic ARP entries.
xOr
Re: ARP cache timeout?
Mon Nov 25, 2013 9:32 am
Hello!
Are it possible now?
After RouterOS was positioned as CoreRouter.
I see timeout = 1 minute on my border router, with Internet Exchange it is too little time.
That does not allow to use the blackhole service.
normis
Mon Nov 25, 2013 9:44 am
Hello!
How does the blackhole route relate to ARP cache timeout? Please clarify why you would need such feature?
xOr
Mon Nov 25, 2013 6:11 pm
Hello, Normis.
This feature needs in many cases.
Our network ARP timeout standard is 4minutes (1 minute less, that CAM timeout). I want to adjust it on RouterOS too.
Low value makes high level of broadcast flood.
This tunable on most of network devices.
MSK-IX service 'Blackhole for attack protection' sends ARP announces every 5 minutes. If timeout is less - ARP to become obsolete.
It is only one case of many.
Also for network engineer would be very convenient command for cleaning ARP table without using scripts or complex commands.
