mistry7
RB1100 3xADSL bonding with MLPPP, Upstream Problem
Wed Sep 14, 2011 9:09 am
I want to use MLPPP for Bonding 3 ADSL Lines.
All is working if i only use 1 Line for the PPPOE Connection.
If i add more Lines the Upstream breaks down and the connection is not useable any more.
I Thing problem is MTU / MRU Provider says i have to set MTU to 1456 for Single Line and 1448 for MLPPP.
My probelem is, if i do that and RB1100 makes Connect the MTU i set gets changed.
WHY?
What can i do to get it work?
mistry7
mistry7
Re: RB1100 3xADSL bonding with MLPPP, Upstream Problem
Thu Sep 15, 2011 9:47 am
I Know it is discused 100 times,
if testetd so much but i dint find the right switch for me.
Here PPPOE Connection without MLPPP
14 R RH-TEC pppoe-out 1456
And here with 2 ADSL-Lines:
14 R RH-TEC pppoe-out 1524
Why ROS Changes my MTU to an bad one?
If i right for MLPPP it must be 1448. 1456 - 8 Bytes Multilink Header right? Not 1524
mistry7
mistry7
Fri Sep 16, 2011 1:21 am
i find it by my self,
For all having Problems with MLPPP ,
set MTU / MRU to Providers.
Change Mange Chain in Firewall to MTU - 40 Bytes
Set MAX Upload / Download in PPP Rule!
mistry7
milonic
Mon Oct 26, 2015 11:18 am
Hi Mistry7,
I know it's been a while since you posted this but I'm having the same trouble and not getting much help from Mikrotik tech support.
Would it be possible for you to explain in a little more detail what you did to get this to work.
When 1 line is connected, my MTU is 1480, but when 2 lines are bonded, MTU changes to 1520 and no matter what I do, it simply cannot be changed. This is causing upload issues.
I look forward to your response in anticipation.
Many Thanks
Users browsing this forum: No registered users and 38 guests
