aries
problems with ssh
Wed Sep 28, 2011 7:09 pm
Still there is problem with ssh service. We use like api for variuos task. And after more extensice tasks it hangs.
normis
Re: problems with ssh
Thu Sep 29, 2011 12:48 pm
version, problem description, configuration?
aries
Thu Sep 29, 2011 1:18 pm
Version 5.7 and it is possible to reproduce it, 5.5 had the same problem.
normis
Thu Sep 29, 2011 1:21 pm
what do you mean same problem? what is the problem? start by describing it!
janisk
Thu Sep 29, 2011 2:02 pm
you can write to support, and i would like to know these details:
  • what tool you are using
  • what is debug output of the tool you are using at the time of failuer
  • support output file of the router after the failure
  • possibly debug output of ssh service from RouterOS (logging can be set to some larger volume than default and that will be included then in supout.rif file
  • description of what you try to achieve using this ssh script/tool
aries
Thu Sep 29, 2011 2:42 pm
After ssh service hangs, it is not posible to connet to router over ssh using putty. I'll try to get supout file then ssh is not responding.
