natanielklug
I need to updade RoS version in an old x86 Mikrotik box
Sat Oct 22, 2011 4:52 pm
Hello all,
I have a very old machine that runs Mikrotik since version 2.7 I think. This machine is running, now, v3.30 and I can updade it to v4.17 but I need to use some new functions that are just inside v5.x.
How can I updade it? I should buy a new license? How can I work this out?
Best regards,
José Nataniel Centeno Klug
Operation Manager Certto Telecom
+55 45 3333 2135 | www.certto.com.br
sadeghrafie
Long time Member
Long time Member
Re: I need to updade RoS version in an old x86 Mikrotik box
Sat Oct 22, 2011 9:19 pm
You can not upgarde to V5.x
L3/4 = current version + 1 = can use
L5/6 = current version + 2 = can use
eg. L5/6 = v3 + 2 = v5.21 you can
for more info visit http://wiki.mikrotik.com/wiki/Manual:License
It describe clearly.
Mikrotik Route My Life
Someone Says: Don't forget to give karma
natanielklug
Sat Oct 22, 2011 9:37 pm
Sade,
As I said in my message I KNOW that I cant upgrade WITHOUT paying for that. The question is: can I buy a new license over the same license ID?
I dont mind to pay again. I just dont want to change this box to another one.
Att,
Nataniel Klug
sadeghrafie
Long time Member
Long time Member
Sat Oct 22, 2011 9:45 pm
Oh sorry for my mistake. :D
you mean upgrade? or new license? Mikrotik doesn't support upgrade.
You can buy a new license and Enter that. just take a look at wiki!
fewi
Sat Oct 22, 2011 10:17 pm
Upgrade to 3, then 4, then 5. With the change of soft IDs from 7 to 8 digits you get a free upgrade, as far as I know.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
skillful
Trainer
Trainer
Sun Oct 23, 2011 1:33 pm
Hello all,
Upgrade the box to ver5 and check the licence. If you have the 24hours trial licence then buy a new licence based on the ver5 soft ID.
natanielklug
Mon Oct 24, 2011 1:12 pm
Thanks everyone that helped. I updade the box to version 4.17 and them to 5.7 and that's working fine.
Att,
Nataniel Klug
Users browsing this forum: Bing [Bot] and 99 guests
